Old 06-27-2022, 01:47 PM   #1
richards72chevy
richards72chevy's Avatar
66 spindle
I have a 66 half ton with a messed up spindle the only spindles I can find are on 3/4 ton and 1 tons.Are these spindles the same or am I going to have to hunt down a half ton?
richards72chevy is offline   Reply With Quote
Old 06-27-2022, 03:35 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 spindle
Stock height:
https://www.performanceonline.com/we...rake-spindles/
https://www.summitracing.com/parts/w...ckup/year/1966
https://www.summitracing.com/parts/c...ckup/year/1966
Old 06-27-2022, 03:59 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Re: 66 spindle
I believe the stock drum brake spindles are different between the series.
If you were thinking about going disc brakes, now is the time to do it. If you're planning to stick with the drums, you can check with Aspen Auto (https://www.aspenautoaz.com/) or you could become a subscribing member of the site and post a WTB on the parts section.
The stock drum spindle for a 1/2 ton is the same from 63-70, so availability is fairly decent with all the conversions to discs
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 06-27-2022, 04:00 PM   #4
richards72chevy
Re: 66 spindle
I'm sorry I left out the detail of these being stock drum brakes.
Old 06-27-2022, 04:03 PM   #5
richards72chevy
Re: 66 spindle
Yeah I have thought about going to disc brakes.I know I would have no problem swapping out the spindles It just seems like messing with the pedal assembly and push rod would be a pain.I will check out that website.
Old 06-28-2022, 08:12 AM   #6
SCOTI
SCOTI's Avatar
Re: 66 spindle
You don't necessarily have to change/mess with the pedal assembly push rod other than the initial adapting. Some of the more inclusive kits will usually have everything you need.
If you have a bad spindle, now is the time for the update to discs unless you have quick & easy access to a replacement unit.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-28-2022, 11:37 AM   #7
cwcarpenter98
Re: 66 spindle
I used a disc kit for my truck, but kept it manual brakes. The kit I purchased had the master and necessary push rod components to be a simple install to the stock pedals in the cab.
If you do decide to stay with the drums, at the very least, you should consider switching to the 67-70 master cylinder that has two lines if you haven't already. The additional safety from having separate lines for front and rear is worth the swap.
Christian Carpenter
Old 07-04-2022, 03:39 PM   #8
67C10Step
67C10Step's Avatar
Re: 66 spindle
Wish you were closer. I got a pair of stock drum spindles I took out of my 67. I’d give you what you need unless you want to do disc brake.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 07-06-2022, 01:05 PM   #9
richards72chevy
Re: 66 spindle
I wish I was closer to.I didn't know the 67 interchanged with the 66.
Old 07-06-2022, 02:14 PM   #10
SCOTI
SCOTI's Avatar
Re: 66 spindle
Drum brake 1/2 ton spindles for a C10 (63-70) should be interchangeable.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
