07-29-2022, 01:42 AM | #201 |
At the body shop.
Re: 2wd swap
Well then, I suppose this mocked up.
" That didnt make it any newer " " Dont antique the equipment " |
07-29-2022, 07:55 AM | #202 |
Re: 2wd swap
Looks good.
Nice & level lowers. Uppers appear right on the Camber curve.
07-29-2022, 12:54 PM | #203 |
At the body shop.
Re: 2wd swap
2° camber change thru the 7" of travel.
08-06-2022, 12:49 AM | #204 |
At the body shop.
Re: 2wd swap
Welded out the drivers side
08-06-2022, 02:09 PM | #205 |
Re: 2wd swap
Looking real good!
08-07-2022, 09:28 PM | #206 |
Re: 2wd swap
Yeah, nice work. Great to see your son so involved in the project.
08-08-2022, 02:43 AM | #207 |
At the body shop.
Re: 2wd swap
Thanks, been awesome to watch him learn and understand the dynamics of the steering geometry and suspension geometry.
08-09-2022, 11:43 AM | #208 | |
Re: 2wd swap
I only wish I had someone share this sort of knowledge & encouragement to soak up as much skills as possible when I was younger. He will reap the rewards now & even more as he grows.
08-09-2022, 09:01 PM | #209 |
At the body shop.
Re: 2wd swap
Thank you.
But at this point I'm just the enabler. The depth of his understanding is way beyond my knowledge. He was explaining to me how he may put the upper ball joint on the bottom of the upper arm to help the roll steer. So neat to see it all making sense to him. •Edit• Maybe posted this before. 2010 beginning of our dash swap. Never knew he was paying that much attention
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 08-09-2022 at 09:09 PM. Reason: Added a pic |
08-27-2022, 09:17 PM | #210 |
At the body shop.
Re: 2wd swap
Today we swapped center sections.
3.82 to a 2.91 Forgot how nice the ring & pinion set was in the 3.82
09-01-2022, 10:13 PM | #211 |
At the body shop.
Re: 2wd swap
Well then.
J decided the rake was drastic
09-19-2022, 11:14 AM | #212 |
At the body shop.
Re: 2wd swap
The cast iron hub we made had some serious run out issues. Don't know if it was the studs we pressed in or the chineseum rotors.
My kid found these wilwood hubs for a c10 spindle. Wilwood 270-13217 Hub They'll work with our rotor and caliper with about 1/8 machined off the caliper bracket and machined another 1/8 off the od to fit the Id of our rotors. Now onto motor mount and transmission mount. Fusion360 and sendcutsend are cutting those for us
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 09-19-2022 at 11:27 AM. Reason: P/N |
09-20-2022, 10:34 PM | #213 |
Re: 2wd swap
Still following. Cool stuff.
09-22-2022, 07:59 PM | #214 |
At the body shop.
Re: 2wd swap
In the sun.
Some fall cleaning since it's cool enough to do something other than sweat. His 1st design motor mount, I wanted to use oem style clamshell stuff and he said it uses up to much room for headers. Then the ratchet strap didn't get a full wrap and dropped our mockup block on our F body pan. He handled it like a pro- owned the mistake and thankful he didn't catch it.
10-05-2022, 06:08 PM | #215 |
At the body shop.
Re: 2wd swap
3 pass lower link. Sure why not
10-12-2022, 12:58 PM | #216 |
At the body shop.
Re: 2wd swap
Wilwood hubs with a new caliper bracket. New shorter bolts coming.
Funny how a .250 to long of a bolt turns into a $65 order
10-12-2022, 05:28 PM | #217 |
Re: 2wd swap
Have your own design bracket cut?
10-12-2022, 06:13 PM | #218 |
At the body shop.
Re: 2wd swap
Yes.
Send cut send, they have been absolutely rocking it. But we asked for powder coat and then it took them longer than usual. My son's cad work is on point lately. His latest project, 8-1 strictly for the sound...
10-12-2022, 06:34 PM | #219 |
Re: 2wd swap
Nice.
10-15-2022, 02:12 PM | #220 |
At the body shop.
Re: 2wd swap
Afco shocks on sale ? Sure Jay
10-22-2022, 12:58 PM | #221 |
At the body shop.
Re: 2wd swap
Take off clip to replace the aftermarket junk we had.
Is every 81-87 hood cracked in the front center? Third hood we've ran across like that.
10-22-2022, 03:12 PM | #222 |
At the body shop.
Re: 2wd swap
So.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 10-22-2022 at 10:08 PM. Reason: Added a pic |
11-13-2022, 09:46 PM | #223 |
At the body shop.
Re: 2wd swap
Motors in its home.
Not sure the set back will work. Steering box brace seems stout enough
11-13-2022, 10:29 PM | #224 |
Re: 2wd swap
Those pics aren't telling as far as set-back isdues.
What are you seeing?
11-13-2022, 10:45 PM | #225 |
At the body shop.
Re: 2wd swap
The balancer is going to end up behind the center link.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 11-13-2022 at 10:53 PM. Reason: Added a pic |
