Old 12-30-2022, 12:25 PM   #101
Hart_Rod
Hart_Rod's Avatar
Re: 1968 C10 Suburban
Clean burb
Hart_Rod is online now   Reply With Quote
Old 12-30-2022, 08:25 PM   #102
3757chevy
3757chevy's Avatar
Originally Posted by Hart_Rod View Post
Clean burb
Thanks Rob. I hope to see your old one here in Colorado someday.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 01-16-2023, 02:46 AM   #103
3757chevy
3757chevy's Avatar
I got a new set of shock relocation brackets as well as new shocks, u bolts and an adjustable trac bar. I've had lowering springs and mounting plates since last year. The only thing I'm missing now is a good dose of ambition. And better weather.
MIKE
Old 01-16-2023, 07:58 AM   #104
kev2809
low n' slo
kev2809's Avatar
progress looking good!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is online now   Reply With Quote
Old 01-16-2023, 11:21 PM   #105
3757chevy
3757chevy's Avatar
Thanks Kev, I been following your thread. Looking good too.
MIKE
Old 02-25-2023, 11:13 PM   #106
3757chevy
3757chevy's Avatar
Changed the neutral safety switch today because it is the backup switch as well and the lights quit working or I may not have noticed .
MIKE
Old 02-26-2023, 12:11 AM   #107
LockDoc
The Older Generation
LockDoc's Avatar
I have never heard of one doing that. Maybe something broke inside and bound it up. Never fun with the column installed.....
LockDoc
Leon
Old 02-28-2023, 01:18 AM   #108
3757chevy
3757chevy's Avatar
LockDoc
Yep usually the switch goes bad like this one . It's hard to get everything lined up and then get my old fumblin' fingers to start those little bitty screws and the stoplight switch connector is right there in the way.
MIKE
Old 04-13-2023, 07:54 PM   #109
3757chevy
3757chevy's Avatar
I pulled my tailgate latch lock to send to Leon[LockDoc] so he can set me up with 1 key to fit all my locks. Thanks again Leon. I sent you a PM.
MIKE
Old 04-13-2023, 09:26 PM   #110
LockDoc
LockDoc's Avatar
Looks pretty clean. It will be nice to only have to carry one key....
LockDoc
Leon
Old 04-13-2023, 10:07 PM   #111
3757chevy
3757chevy's Avatar
LockDoc
Thanks all my other trucks ('67, '69, '71s and '72s) that I've had only had 1 key. Now my '68
MIKE
Old 04-14-2023, 08:27 PM   #112
3757chevy
3757chevy's Avatar
I took my old steering wheel off Today to try to get restored and fix my turn signal switch 'cause it wouldn't cancel . I only needed springs replaced . I fished out the broken ones from under the switch and replaced them . I put a wheel I had in my stash on for now.
MIKE
Old 04-14-2023, 09:25 PM   #113
LockDoc
LockDoc's Avatar
Looks good. Do you know what the wheel is from? I'm looking for a flat one like that for my Blue Dually.
LockDoc
Leon
Old 04-14-2023, 11:32 PM   #114
3757chevy
3757chevy's Avatar
LockDoc
I think it is 88-94 Chevy pickup.
MIKE
Old 04-15-2023, 08:30 PM   #115
LockDoc
LockDoc's Avatar
OK, Thanks.
LockDoc
Leon
Old 04-21-2023, 10:22 PM   #116
3757chevy
3757chevy's Avatar
I got my tailgate lock cylinder back Today . Thanks Leon, I installed it and the ignition cylinder Tonight . Now I can lock my tailgate and start the Burb with one key . I need to take both inner door panels off to get the door locks in and install my new window regulator in the the drivers door. Then I will be able use 1 key for all locks.
MIKE
Old 04-22-2023, 08:10 AM   #117
kev2809
low n' slo
kev2809's Avatar
so nice I bet!
-_--_--_ _________
Old 04-22-2023, 09:21 AM   #118
LockDoc
LockDoc's Avatar
No problem. Your tailgate lock was in pretty nice shape compared to some I've done. It had been worked on before because there were some small parts in it that didn't belong.
LockDoc
Leon
Old 04-22-2023, 03:06 PM   #119
3757chevy
3757chevy's Avatar
LockDoc
I could tell someone had messed with it. It had some marks on it. Thanks for cleaning them up.
MIKE
Old 04-22-2023, 11:56 PM   #120
LockDoc
LockDoc's Avatar
I couldn't get them all out but it looked a little better. No big deal since I had it apart anyway.
Leon
Leon
Old 05-23-2023, 10:57 AM   #121
3757chevy
3757chevy's Avatar
I made a bracket for a second dome light . I saw pictures of one and tried to make it from what I remembered seeing. Maybe a bit different but it is fitting fine. I painted it after taking this pictured.
MIKE
Old 05-23-2023, 01:18 PM   #122
kev2809
low n' slo
kev2809's Avatar
oh that's nice!
-_--_--_ _________
Old 05-23-2023, 03:06 PM   #123
3757chevy
3757chevy's Avatar
This morning I used a tape to fish the wires to the front dome light , got it connected to the front wires and finished by lunch. Still need to try to get headliner tucked under bows ,but that might take two people.
MIKE
Old 05-23-2023, 03:10 PM   #124
3757chevy
3757chevy's Avatar
Stock headliner is a little dingy , hoping to clean it up somehow without any more breakage.
MIKE
Old 05-24-2023, 08:08 PM   #125
HO455
HO455's Avatar
Good work! The nice part of making your own parts is not only do you get free shipping but they also come with the good feelings of a job well done!
RIP Bob Parks.
