02-02-2023, 10:15 PM | #1 |
after market signal lights
Hi was wondering if someone can help me with wiring for a signal stat 900. I looked on the web and found the wiring diagram for a 7 wire, but for some reason mine has 10 wires and cant find any thing for those. dont no what the other 3 wires do Thanks Denis
02-05-2023, 11:02 PM | #2 |
Msgt USAF Ret
Re: after market signal lights
I was thinking that your extra wires might be for the left and right turn signal light wires in the dash. Or maybe even for the front marker/turn signal lights.
Do a continuity check between them and the left and right turn lights in the signal stat switch.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-12-2023, 04:06 AM | #3 |
Found this on the truck lite site. Think they own signal stat now. https://www.truck-lite.com/915y124.html A 10 wire for Peterbuilt trucks. Extra wires appear to be for high/low beam on the unit linked. Sorry no signs of a wiring diagram I have found. Maybe email truck lite and ask for one?
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
02-12-2023, 07:06 AM | #4 |
This is the only thing I found in the link below.
It breaks down the wiring into 3 categories. 1-Turn signals 2- Flashers (If it has the pull-out flasher bar) 3- Bright and dim lights (If it has the button on the end of the lever) Hope this helps. http://www.forum.aths.org/Attachment11161.aspx
02-14-2023, 11:08 PM | #5 |
Richard and Getter Done thanks for the info but the lever only moves up and down and no button on the end of lever. Don t need them i quess won't worry about it
