Old 02-07-2023, 11:46 PM   #1
wazzabie
seeking kill switch suggestions
I would like to install a kill switch but I don't want to cut into any of the factory wiring. Any suggestions?
wazzabie is offline   Reply With Quote
Old 02-07-2023, 11:49 PM   #2
Bandit130
Bandit130's Avatar
Re: seeking kill switch suggestions
My suggestion is to install or have an alarm installed. I did and have no regrets.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 02-08-2023, 01:13 AM   #3
Dead Parrot
Pretty much by definition, a kill switch involves modifying some aspect of the factory wiring. A kill switch is installed in series with a wire carrying current needed to start and/or run the motor. You have to cut something somewhere to install the switch.
If you go with an alarm and have bent the knee to the smartphone tracking universe, get an alarm that sends you an alert and possibly photos/video from the cab mounted camera. So much better when your 911 call includes a detailed description of the person currently in the act of stealing your vehicle. Perhaps hide one of those Apple tags/gps sender somewhere on the truck. If they succeed in the theft, you have a chance it will phone home with its location.
Dead Parrot is offline   Reply With Quote
Old 02-08-2023, 05:37 PM   #4
truckin 79
I use on of these on positive battery cable, mainly to save battery from discharging. The Die Hard battery in truck is about 15 years old, starts the truck every time. CO has become the #1 state for car thefts as of late, I really wish people would stop moving here. Anyway I have also added the club to my truck as an extra safety measure. The truck also has a hood release that is inside the cab 79 so that also helps. Simple install of battery kill switch as well
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 02-09-2023, 07:27 AM   #5
Corts60
Just here to tinker
Corts60's Avatar
X2 on battery cutoff switch with removable key. But you’ll want to mount it so that it is difficult for the thief to get to the terminals on the back or they’ll just jump them and steal it anyway. The only bummer is this will reset your radio settings every time you use it.
OR
What I’ve done in the past is mount a normally closed momentary push button in the radiator support so it contacts the hood when closed. I then wire the horn through this switch so if I’m someone pops the hood, the horn immediately blasts and won’t stop until the hood is closed. This is usually enough to bring attention and scare people away. You can add another on/off switch in series and hide that somewhere convenient for yourself so you can get under the hood without making the horn go off. Easy and cheap.
Then all you have to do is pull the ignition wire out of the coil and you’re all set. Once they pop the hood to see why it won’t start, boom.
Old 02-09-2023, 05:29 PM   #6
1976gmc20
We left CO over 25 years ago. It was getting worse back then.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 02-09-2023, 09:53 PM   #7
Factory Guy
Factory Guy's Avatar
I did that as well on one of my cars, the red handle (removable part) was hidden inside the car where one wouldn't look. After I did this I read where you should do it on the NEGATIVE cable and not the POSTIVE cable.
Factory Guy is offline   Reply With Quote
Old 02-10-2023, 12:14 AM   #8
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
100% chance if you pay any retail store to solve this problem, wires will be cut, crimped with a hammer and most likely mutilated at worst.
What I do and will recommend to you. figure out what circuit you want to add kill switch to.
Research connector, find terminal family name and size
Buy Terminals
Buy proper crimp tool, quality, not cheap!
Buy wire that matches OE wire color being modified
Remove wire from Circuit,
Cut OE terminal off at 1st crip, pull off remaining strain relief - this saves the most and you only loose 1/8" of wire or so
Crimp new end to new wire from kill switch and install new wire with factory crimp to the circuit you want.
clint
I also found a programmable module for kill switches. will only share over PM.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 02-10-2023, 07:11 PM   #9
Just call me Sean
Just call me Sean's Avatar
The steering lock and gearshift lock are the main theft deterrent. I could hotwire your truck in under two minutes but would have to break the locks to drive it away. I hotwired my K5 when a fusible link melted but I didn't find it until I got home because it was easier to hotwire it than diagnose it on the side of the road.
I would suggest the kit that allows you to remove the steering wheel if you're that worried about it getting stolen.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 02-10-2023, 09:15 PM   #10
Bandit130
Bandit130's Avatar
https://www.youtube.com/watch?v=1WnPey_5Trc
Mopar by Birth
Chevy by Choice
Old 02-10-2023, 11:41 PM   #11
Bloodhound
I go with a two part approach. A fuel pump kill switch (I'm fuel injected) and a hidden commercial GPS tracker that is battery powered - 5 years on 3 AA batteries. There is a subscription cost for the tracker, but the reality is if someone wants the truck, they'll drag it onto a ramp truck and disappear. I like knowing that if the worst happens, I'll be able to quickly locate it.
Bloodhound is offline   Reply With Quote
Old 02-11-2023, 12:20 PM   #12
v30crewcab
v30crewcab's Avatar
battery kill switch, with a fuse between the two terminals. retains power unless you try to start it with it shut off. retaining your radio settings but will pop the fuse if they try to start it.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
