#51 |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Window felt install question
My window now rolls down against the bumper perfectly.
Winding it to the top is another thing. I didn't bend out the horizontal window felt mounting tabs on the passenger side before I installed them. You know the results...
#52 |
I ended up trimming mine instead of bending them. I also did away with the clips and screwed them in higher up in the window frame. It help a lot in allowing the window to travel all the way up.
#53 |
Moderator
I saw where you discussed that forestb.
I just removed all the components and bent the tabs out, then reinstalled it all. Works much better. Seemed easier or faster the second time around. ![]() I think I will bend the drivers side out more than it is now. Don't want to do this again if I don't have to. Besides that my wife knows now and I wont want to hear it...
#54 |
Just found this thread and have the rubber the right way belt line strips in the online cart….. wanted to see how everyone likes them? Did anybody do the window channel felt from here too? How did those work vs the other ones at like brothers etc….? Thanks
#55 |
resurrecting this thread. I ordered mine from rubber the right way in late November 2022. I have yet to receive them, so I called. They are backordered, but the representative advised me that their product is a precision product rebranded. So is Steele rubber belt line according to rep. So what other options are there besides precision?
#56 |
![]() Join Date: Mar 2011
It's been very informative reading this post. I am ready to install the side glass and vent window assembly. I've rebuilt both of the crank assemblies, the vent window assembly with all new glass, and whatever else goes into the installation. And I ended up buying new side glass when I couldn't get the scratches out. I have been researching and I've found that right now it seems that everything is backordered except for Steele Rubber so I ordered the complete kit. I'll chime in when I receive them and see what I've got. I've always used either Precision or Steele as my choice.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
#57 |
![]() Join Date: Sep 2020
Been working on assembling the doors and find everything goes well till the fuzzies come into the picture, slot in door to receive clips is .162 in height, the clip for said hole is .260 and it doesn’t want to compress.
Hopefully this new rubber right company has something better than the LMC crap, May go the small screw route……. |
#58 |
These are my original fuzzies.
Squish the ends down where they fit behind the door channel, and scrape the fuzz off. ![]()
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#59 |
Have removed the fuzzy already, was concerned that squeezing dow the clips, that they wouldn’t stay in place…guess gotta try…last resort, remove clips and use small screws…frustrating is what this is…..
#60 |
I had to go the small screw route. With my glass in there was no way to get the fuzzy between the glass and the door. The bumper in the bottom of the door was out and still no way to get the glass to drop below flush with the bottom of the window opening. Pull the window, put in the strips, crank up the window and they'd pop loose. Of all the things I've done on my truck, working with the door weatherstripping and glass was the biggest PITA.
#61 | |
#62 |
My passenger door went together well, but the driver's door I took my door/fender-aligner slide-hammer and "tweaked the window opening a bit and it works wonderful now. Video on this next week.
#63 |
I recently installed the window whiskers/wipers on my 1963 C10. Here’s the video on how I made the window roll up properly. https://youtu.be/Jo4Cq57ZCX0
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#64 | |
#65 |
That looks super smart!
I didn't even think of doing it that way. That's a smoother, gentler, method than what I did with one of these: ![]()
#66 |
Very Clever, top.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
#67 | |
Moderator
#68 |
I did this video in doing my door glass. Might be a good taste of what you're getting yourself into.
#69 |
![]() Join Date: Aug 2020
Well Done to the both of you!!! I used tiny screws on a previous replacement but will use your method on my currect project. It can be DONE!!!!!
#70 | |
To me the glass was the only added expense, the junk fuzzies from LMC were not going to be used anyway..and I have two sets ..they can both be yours for the price of freight… |
#71 |
I'm working oin the same issue with my fuzzies. When I finally decided that I wasn't going to get them in all the way, the clips that I did get in, were almost impossible to get back out. This set of fuzzies is a mess. I spent a couple of days getting the inside ridge where the clips go reworked and readjusted the crank and wheels a little. I now have the windows going up and down with no restrictions and staying centered in the channel. Now I need to get another set of fuzzies and try to get them in. I agree that this is one of the most difficult jobs I've done on Sanity.
#72 |
The ones I got from RePops went in much easier than the ones from LMC, the clips were shaped correctly….I’ve got two sets of the latter that are yours for freight cost…
#73 | |
Thanks for a good video. |
