Old and crusty
![]() Join Date: Jan 2009
LS coil packs
I run a 5.3 Vortec in my 64 C10 and want to know if I can run LS3 coil packs instead of the stock ones.
I wanted to buy a set of the Holley valve covers that hide the coil packs but my coil packs will not work with them. Anyone got a clue?
65 Chevy long wide daily driver - SOLD! 64 Chevy Short Step LS |
Re: LS coil packs
As long as the harness side plugs are the same (I believe they should be, but not 100% certain) they should just be plug and play. Depending how far back your engine is sitting you may have clearance issues on the passenger rear corner though.
14 Silverado- 4/6 drop daily 66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop ![]() 66 GMC 1 ton stepside looooong bed- the tow pig/work truck. |
Re: LS coil packs
https://www.ebay.com/itm/32544613889...mis&media=COPY
This set of harnesses have the correct coil terminals for the coils. https://www.amazon.com/dp/B0BBGQ8QSW...roduct_details These are the coils that fit the holley valve covers. |
Old and crusty
Re: LS coil packs
Thanks for the info.
![]() Join Date: Sep 2020
Re: LS coil packs
I had to modify the mounts on my edelbrock coil cover to accept ls2 coils, the ones I have were designed for ls1 coils….
Unfortunately I don’t have a picture of the actual coils, this is the cover however…. |
