Old 02-26-2023, 11:47 AM   #876
Re: What did you do to your truck today??
Just curious how many miles on the balancer. I know they have varied lifespans.
I did cap and rotor on my Suburban a month or so ago. It wouldn't fire over when it was wet out, until it dried. That's when I realized how many miles and how long it's been since I put that motor in. I noticed a split plug wire and yes the plugs need replacement. But I developed a bad head gasket and will do the wires and plugs on reassembly. I also have new P/S hoses to install once heads go back on. It's been a good vehicle. Just time to finally give it some love.
Old 02-26-2023, 01:35 PM   #877
Just call me Sean
Just call me Sean's Avatar
Her odometer shows 222xxx miles. It was running rough and no codes so I gave it a tune up. It ran great but when I went to change the oil after that I noticed the dripping water. I noticed the balancer while I was checking for leaks with it running after I changed the freeze plug.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 02-26-2023, 06:10 PM   #878
Just call me Sean
Mom's brakes never felt right to anyone that drove it, despite me having changed most every part of the braking system. Similar to my 93 but hers was much worse. So I deleted the ABS. They work much better now. I'll have to do mine next. Hers has the first design ABS, different than mine but should be relatively the same to delete it.
Old 02-26-2023, 10:23 PM   #879
I disabled mine by getting anti-seize on a sensor when changing a rotor I've had to stop but quick a few times since. It stops great, and I control the locking
My Suburban has about the same miles on it.
Old 02-27-2023, 01:57 AM   #880
Just call me Sean
The older ones are just RWAL, the only sensor is the VSS.
Old 02-27-2023, 09:58 PM   #881
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Not today, but over the weekend I got all hitch parts removed...
This coming weekend cut off exhaust, remove bumper/hitch...
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-05-2023, 03:42 AM   #882
pjmoreland
pjmoreland's Avatar
Replaced the battery cables and the transfer case front output seal. Found some questionable wiring and cleaned it up while I was there. The starter motor solenoid wire fell out of the ring terminal. I'm glad I found that now instead of getting stranded somewhere.
pjmoreland is online now   Reply With Quote
Old 03-11-2023, 11:47 PM   #883
Just call me Sean
Another new thermostat in the 93.
Old 03-16-2023, 05:26 AM   #884
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Racking it tonight, hope to get Rear Bumper, Receiver Hitch, and Tail Pipes removed...
If all goes well, my buddy passing through Friday night, Rear Flip and Notch Sat am...
Old 03-17-2023, 02:23 AM   #885
pjmoreland
pjmoreland's Avatar
It has been raining here a lot lately, and I have been noticing that water has been dripping from the heater box onto the passenger floor mat. I removed the blower motor to investigate (not easy, by the way, and requires the dash to be flexed out of the way). Anyway. I did this while it was raining, and could see with a mirror that water was dripping steadily through the fresh air inlet from the seam of the block-off panel that is glued to the top of the firewall under the cowl. I then removed the cowl and found that the seam sealer was deteriorated to the point where the plate was loose. I removed the plate, cleaned off the old seam sealer with a wire wheel, resealed it, and painted it.
Old 03-17-2023, 07:07 AM   #886
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Truck racked, hitch removed. (Damn that thing was heavy)
Not sure anything gets done today, but a lot happens Sat...
Old 03-18-2023, 06:22 AM   #887
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Time to get this day started...
Old 03-21-2023, 09:08 PM   #888
Wutda heck, I see Belltech. Cool dual wheeler regular cab
Old 03-23-2023, 06:30 PM   #889
Just call me Sean
The exhaust donut blew out again.
Old 03-24-2023, 04:57 AM   #890
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
6/8 Static Drop + Have a Set of Period Correct Directional Wheels...
Link to rim pics -> https://link.shutterfly.com/kKmGZVm0ztb
Old 03-25-2023, 11:19 PM   #891
wrangler94
new plugs, wires, distributor cap, rotor, radiator cap, and checked the timing, which was wayyy off from the mechanic that put the new distributor in, and OMG it runs so good now. the change is unreal. 1992 chevy 3500 with 350
wrangler94 is offline   Reply With Quote
Old 03-26-2023, 08:04 AM   #892
I would never ever consider those wheels.............................................................................................. .............................................. In the '90s . But now all I can say is perfectomente! It's all about the era correct. Plus, once you stop seeing something, it's nice to see it back again. Well, except my ex-wife
Old 03-27-2023, 11:20 AM   #893
KQQL IT
At the body shop.
KQQL IT's Avatar
Recently got my son a 90 Cheyenne regular cab shorty.
Been doing the usual ignition brakes oil grease tuneup.
Tried to get the axle out for passenger side axle seal and as usual it seems the spider gear pin was broken.
Easy Sunday got long.
Old 03-29-2023, 06:58 AM   #894
Nice project. I'd like to find one something like that.
Old 04-01-2023, 11:22 PM   #895
KQQL IT
At the body shop.
KQQL IT's Avatar
1990s eagles off
1980 something rally wheels on and some 275 60 coopers
Old 04-02-2023, 07:02 AM   #896
Ralleys always look great on these trucks.
Old 04-02-2023, 09:42 PM   #897
KQQL IT
At the body shop.
KQQL IT's Avatar
We finally got a brake pedal!
Adjuster nuts where on backwards from the prior owner. :/
And 3 new brake hoses
New shoes pads re packed wheel bearings idler and pitman arms.
Maybe now I'll feel good about my son driving this one.
Old 04-04-2023, 09:56 PM   #898
Just call me Sean
I took the good spare from my van and put it on the truck, so I would still have the not so great spare on the front. It was pretty bald, but I didn't notice until today that the belts were starting to poke through the center because leaves were sticking to the sharp points. It will be the van spare until I get another tire. Also, the 99 is down until I figure out what's wrong with it.
Old 04-08-2023, 10:24 PM   #899
KQQL IT
At the body shop.
KQQL IT's Avatar
Oil and filter
pcv valve
grommet and vacuum tube.
Seems to have fixed our low idle issue.
Hope so.
Old 04-14-2023, 08:20 PM   #900
Just call me Sean
On the 93, the idler pulley locked up. The belt unscrewed it from the bracket and threw it off the engine and got chopped up in the process. After searching the ground where it happened I found the pulley laying on the frame rail under the hood. Purchased a new belt and pulley and then realized I had to go to the junkyard to get another bolt and spacer because they were damaged too.
