03-30-2023, 09:31 PM | #1 |
Fuse blows when I hit the brake pedal
What do I check for.
03-30-2023, 09:51 PM | #2 |
Re: Fuse blows when I hit the brake pedal
Is the fuse the proper size? Otherwise you are usually looking for a short to ground. Unless it is shorting to another circuit. Is anything else powering on when you activate the brakes?
Check the bulb sockets or the brake switch first, as they are the most accessible. If you see nothing obvious such as melted or chafed insulation start at one brake light and disconnect it from the circuit. Do only one light at a time. with a good fuse or circuit breaker installed activate the brake lights. If the fuse keeps blowing trace your way to the switch looking for a bad spot in the wire. Carefully inspect where the wires pass corners, clips, holddowns, etc. |
03-30-2023, 10:53 PM | #3 |
I had a light bulb filament blow one time, in a way where the remaining piece of filament miraculously shorted out to a metal piece of the bulb base. so whenever that circuit was activated the fuse blew.
Because that rotten bulb would blow the fuse whenever the circuit was active, I couldn't just see which bulb was "out"; I had to remove every bulb and inspect closely one at a time. RANT: Of course I discovered this little issue at 5 a.m. in the winter time at a gas station when leaving town for a special weekend getaway with my lady sitting patiently in the passenger seat insisting she wasn't mad, meanwhile, I was blowing every extra fuse I had to try and resolve the issue, because it was still pitch black outside and we apparently were driving with no running/brake lights in the back. Thanks for listening lol Last edited by jumpsoffrock; 03-30-2023 at 11:03 PM. |
03-30-2023, 11:26 PM | #4 |
During my years as a mechanic, I "majored" in electrical repairs. I bought this tool off the Matco truck in the 80s.
https://www.toolaid.com/product/25100 It's very easy to use and will take you by the hand and lead you to the short. I never failed to locate a short using it. |
03-31-2023, 07:39 AM | #5 | |
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
03-31-2023, 10:25 AM | #6 |
I think I told my cruise control story on here regarding a brake light bulb on a newer vehicle
03-31-2023, 12:11 PM | #7 |
If you have rusty fuse terminals, that can cause fuses to blow.
Fuse heats up due to excessive resistance and breaks the contact where the fuse strip is soldered to the terminal (outside metal ends of glass type of fuses). Just something to look at during the diagnosis. Bob |
04-01-2023, 05:26 PM | #8 |
I would unplug the plug at the back of the frame and see if it still blows. Then you have it narrowed down to in the truck or the back lights.
04-01-2023, 06:17 PM | #9 |
The wiring for the tail lights to the cab is all new. I unplugged it at the rear of the truck and hit the brake pedal and the fuse blew. The left turn signal works but when I turn on the right one it makes a weird noise and burns out the flasher. Ugh this is driving me crazy
04-01-2023, 06:30 PM | #10 |
Now you can unplug at the firewall and try again. Short may be in the column or the turn sig switch. Orange is power to the BL switch and the white wire goes into the column up to the switch and back down both turn sig wires to the tail lamps only to be cancelled on either side depending on which way you activate the signals. So your right turn is probably the culprit
04-02-2023, 02:05 PM | #11 | |
Does it matter how the brake light switch is plugged in, Orange and white wire on either side of the switch? I’m going to pick up a new turn signal switch and maybe a brake light switch tomorrow and try that. Just don’t know what else to try. |
04-02-2023, 03:57 PM | #12 | |
04-02-2023, 06:50 PM | #13 | |
04-02-2023, 06:57 PM | #14 |
04-02-2023, 07:13 PM | #15 | |
04-02-2023, 07:34 PM | #16 | |
Go to the link I posted and download the instructions. Also included in the instructions is a detailed description of how the device works. |
04-05-2023, 10:53 PM | #17 |
Thanks Rusty Pile for the help! Finally good to go
04-06-2023, 02:37 AM | #18 |
