Old 05-14-2023, 07:25 PM   #1
bcfishon
Oops, was I suppose to grease it?
So I have been slowly doing the ls swap in front of my sm465 and np 205, finally started the beast and it sounds like I have a dry pully in the clutch area,the clutch functions properly and the throw out bearing has proper clearance. The noise does not change when I push the clutch in or out, does seem to go quite the higher the rpms . last note is I may have neglected to grease the pilot bearing for the transmission,its a bearing and not a bushing but nonetheless I'm not sure whether I greased it or not for the snout of the input shaft,problem?.
bcfishon is offline   Reply With Quote
Old 05-14-2023, 08:02 PM   #2
RustyPile
RustyPile's Avatar
Re: Oops, was I suppose to grease it?
Originally Posted by bcfishon View Post
So I have been slowly doing the ls swap in front of my sm465 and np 205, finally started the beast and it sounds like I have a dry pully in the clutch area, the clutch functions properly and the throw out bearing has proper clearance. The noise does not change when I push the clutch in or out, does seem to go quite the higher the rpms . last note is I may have neglected to grease the pilot bearing for the transmission, its a bearing and not a bushing but nonetheless I'm not sure whether I greased it or not for the snout of the input shaft, problem?.
Referencing your highlighted statement.. When the clutch is engaged, the transmission input shaft rpm is the same as the flywheel and engine rpm.. any noise originating with the pilot bearing during this condition will not occur.. Look elsewhere, the noise is not coming from the pilot bearing...
RustyPile is offline   Reply With Quote
Old 05-14-2023, 09:49 PM   #3
bcfishon
That is good to hear,thanks
I will snoop further
Old 05-16-2023, 06:49 PM   #4
bcfishon
Starter was just barely contacting flywheel, 2 starters to choose from a 9 toothe and 11, I used the starter from a automatic flywheel on my clutch flywheel and it is making contact at tip of gear,now you know.
Old 05-17-2023, 11:47 AM   #5
biketopia
Glad you figured it out and thanks for posting the solution for the next guy!
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
