#901 |
Re: My 1970 GMC “Project Splice”
It's great when you find a truck that is so well done and resembles what we want for our trucks. Definitely inspiring for sure.
I hope everything goes well with your new baby entering this world, as well as your wife Kyle. You're a blessed man! Brian
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#902 |
![]() Join Date: Sep 2015
Thanks Brian.
#903 |
My awesome wife told me to go work on my truck this afternoon even though we are less than a week from the due date.
#904 |
![]() Join Date: Dec 2009
Looks Great.
#905 |
Two days in a row! Now I'm just feeling spoiled
![]() I got the passenger side all stripped down as well. Next step will be filler and seam seal on dash and firewall. ![]() |
#906 |
I have just noticed that my stereo box for behind my seat may need to be re-planned out a little bit. My pressboard has expanded and since the metal frame obviously isn't, it has got some pretty warped spots in it. Now I have to come up with a new substrate that will work. Might have to use sheet metal as I can't be much thicker than 1/8".
#907 |
Well today was baby day. Lochlan Werner was born at 9:43 AM. Weighing in at 7 lbs 5 oz with a length of 21". Both baby and mom are doing well.
#908 | |
![]() ![]() Just seeing this. Hope You and Mom of Lochlan are doing well ![]()
#909 |
Yes we are. Thanks. He's been sleeping very good so that is nice.
#910 |
I managed to sneak out for an hour today and started the filler process on the top of the dash. I got the marglass done and am now ready for lightweight filler.
#911 |
Good work but Congratulations on your new baby!!!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#912 |
#913 |
Congrats Kyle. I haven't kept up here or Instagram to see your progress.
Congrats on the baby. Glad to hear both baby and mom are doing well. |
#914 |
Thank you! I haven't really been keeping on on Instagram lately. I should post some of my progress there soon.
#915 |
I have found the time to get a bit more filler done on the dashboard over the last couple days. It is coming along nicely.
#916 |
More progress made on the dash today. I also took the GMC lettering I had cut out of the fender emblem and ground it down so it was thin and sleek. I'm still toying with the idea of using these on the dash where I removed the speaker grill. I would paint the letters the same colour as the dash so that it would be subtle. Any thoughts on this?
#917 |
So a couple weekends ago, I made a trip out to the wrecker to get the steering column bracket that my brother stole from me. Haha guess he lost his. Anyway, I found this very nice straight upper grille moulding that I needed very badly as mine is trashed. I didn't want to play around with aftermarket parts and this piece has been very elusive up till now. I was glad to score it for $40 even though I had to take the whole mangled grille as I had no way to seperate them out there.
I also ordered a new set of defrost vents so I can make sure they fit properly in the dash. They seem to be the wrong radius in the corners but there is a pretty good chance that is just how they are. I have done some fine sanding on the passenger one to get it fitting better and am happy with the result. Might do a bit more touch ups on it and then I can repeat for the drivers side. |
#918 | |
#919 |
Thanks! I agree small detail are fun.
#920 |
I got the defrost vents fitting better than factory now. I had to do some sanding on the corners of them and adjusting of the flanges but they fit very nice and tight now. I also finished sanding the last of the filler on the dash and am ready for primer on that area now. I also wanted to fix a defect in the weatherstrip flange on my driver door. For some reason it got substantially wider at the front corner and I didn't want any issues went fitting the weatherstrip so I took care of that issue.
#921 |
I picked up these "Custom/10" fender badges after realising the "custom" font matches the flimsy little plastic badge that goes on the glove box door exactly. If I modify these badges the same way I modified the "GMC" fender badge, I can re-create the glove box emblem in metal instead of the lame plastic one. Yes it will be a bit larger but I believe it will look awesome!
#922 | |
#923 | |
#924 |
that's looking great sanded down. I never considered that as an option. well done! I have a couple of those badges laying around. new option ideas have opened up
#925 |
Haha thanks. Good luck on yours. I'm finding it difficult to hold on to the small pieces while grinding them.
