HELP keep blowing fuse!
Hey yall so i put a Painless kit on my 1969 c10 and for some reason i hit the brake i keep blowing the fuse for it. Any ideas?
![]() Join Date: Dec 2009
Re: HELP keep blowing fuse!
Which kit did you install?
That may help if someone used the same kit you have. Sounds like you have a (Hot) wire going Directly to ground. I would start with unplugging the rear harness (If it is in sections) and tracing where it is making a direct ground. Also check for pinched wire/wires where they are run thru the cab and bed.
Shouldn't be that hard to track down. The white wire #918 is probably grounding somewhere.
If it only blows when hitting the brake (and does not blow when emergency flash and blinkers) that only leaves a faulty/shorting brake switch as the culprit. If it blows with flashers and or blinkers I would suspect a problem in the steering column or the blinker switch. |
#4 | |
So have done two turn signal switches and still keeps blowing the fuse
So, the fuse blows when you use the brake and the turn signal and does not blow when you use the flashers? Need to confirm that the flashers don't blow a fuse as it is a separate circuit. If the flashers blow it, it is more likely in the taillight wiring.
Assuming the above is true, the only things it could be are: -mis wired or shorted at the steering column multi connector (likely) This is easy to mix up. Check page 84-87 of instructions. -defective/mis wired brake switch. -short in the column (not likely since you've tried 2 switches) -defective blinker switch (not likely since you've already tried 2) -defective/mis wired dome light switch (that is the only other thing on the circuit). PS> Do the blinkers work until you hit the brake? Last edited by cj847; 11-09-2023 at 07:54 PM. |
Electrons are invisible, making them hard to locate when they go awry. It's easy to locate a coolant leak or brake fluid leak.. They leave a trail of evidence.. Not so those pesky electrons.. Follow this kink to a tool that will guide you directly to the short.
https://www.toolaid.com/product/25100 |
#8 | |
Nice Kink! Never knew such a tool existed...Ya Science! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#9 | |
Reminds me that I have not seen or thought of the one got one of these I used years ago to fix a melted wire issue. Now I need to Look in my Electrical cabinet and see if I can find it ![]()
#10 | |
So looked at it so I can plug one of my LED United Pacfica taillights on one side and then a Standard Incidence bulb on the other to get the LED to work but when the switch is engaged for the opiste side with the stanadard bulb it dull flashes.
so got some updates for you guys so I ended up figuring out that I need to ground the tail lights in order for them to work but the problem I'm having right now is my tail lights aren't going on when it pulled the actual headlight on so I need to figure out what's going on there but otherwise I have everything else working at the current time.
#12 | |
Here is a copied Quote from Paul in post#7 and then the link it came from. {1967-72 Headlight switch, GM used 2 different styles. 1967-68 8-Terminal headlight switch or a 1969-72 7-terminal headlight switch. Note- 1967-68 the front park lights go off when headlights turn on using original style switch, if you want the front park lights to stay on with headlights choose the 7 terminal headlight switch as they are interchangeable. If your using a 69-72 version you should still have functioning lights so there is a good chance you have other issues. Per above you can identify the 67-68 switch by its 8 terminals and the 69-72 by it's 7 terminals.} Link: https://67-72chevytrucks.com/vboard/...witch+diffence
Hey so got it so one of the wires on the rear harness got pinched when I ran it through the frame rail!
My LED tailights require a grounded flasher for the turnsignals and the flashers.
A pinched wire can and will ruin your day
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
#15 |
Glad you Found it.
