#151 |
Re: I am from the Desert
I like the painted wheel wells and core support. Makes it pop under the hood.
My 1970 C10 ChassisFab LWB to SWB Build Thread |
#152 |
![]() Join Date: Mar 2011
I struggled with should I or shouldn't I and im glad I did ....thank you for saying so
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#153 |
today we put the grill on,, hood hinges and hood had the cowl on but removed it ....GAPS and adjusting the hood
![]() ![]() PS I will tuck the harness behind the fender ....some day ![]()
#154 |
closer but no cigar.... sent the buddy buckets back to upholster to much foam .... mocked up the C H E V R O L E T hood needs to go back to paint for a re doo bumper showed up with a scratch and a dimple from UPS box damaged in the same spot as the ding.........patients .....patients
#155 |
snuck in a little interior work
#156 |
two shows here Labor Day weekend one 5 minutes from the house Lead East 50s show last night and another a half hour Dead Mans Curve spent the day there I guess over 2000 cars truck etc.
#157 |
You're so close to being done man! That 56 Chevy is gorgeous.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#158 | |
![]() I have to travel be back this Friday and hit the body shop get them moving on the bed
#159 |
bumper and headlight bezels installed hood going back to body shop
#160 |
finally got my buddies back ...put them in temp good fit now, he took about 3 inches of foam out tapered the backs my head not touching the roof and belly room too
#161 |
Looking great! That's one funky shift lever. Looks like it's made to fit perfectly around a bench seat.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
#162 |
Late to this thread, but man, your work is awesome!
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
#163 | |
#164 |
thanks Shifty for the kind words ....sometimes i think its OCD other times its just plain rewarding when you get it the way you visioned
#165 |
Nice work, great color combination coming together nicely
Keep the pictures coming it entertained me
#166 |
thanks Jim
#167 |
Cpp rear sway sat on the shelf for a few years waiting for this build ..simple install drilling on trailing arms laying on my back looking up
#168 |
got lights......
#169 |
small steps cab light visors rearview
#170 |
carpet day
#171 |
Did you make your own powder coating system?
#172 |
Nice work as usual, jess
#173 |
use Eastwood powder coating gun and their powders ... a residential used electric oven ....I have a blast cabinet from harbor freight .....prep like everything else is most important I set them up with wire hangers on the oven grill shelves apply the powder bake @ 400 for 20 mins and usually I have a nice finish
#174 |
#175 |
Active Member
![]() Join Date: Oct 2012
Looking good!
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
