10-30-2023, 09:40 PM | #176 |
Re: I am from the Desert
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-13-2023, 09:21 PM | #177 |
double pulley installed no more belt noise
11-14-2023, 10:58 AM | #178 |
Belts are about maxed-out on that adjuster bracket, eh?
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
11-14-2023, 10:55 PM | #179 |
good eye Shifty ...the belts come in one inch increments as far as I can find out this way and that does not give me enough room going the other way with the alternator on a aftermarket bracket cause of the headers and original 327 heads have no provisions for bolting up a bracket to the head! originally the bracket bolted to the exhaust manifold I have clocked the alternator also ...long winded answer but I have run out of options ...there is just a tad left to pull the belts tighter ...no need to at this point ....thanks for looking as always open for advice
11-15-2023, 12:24 PM | #180 |
I had that same issue on my 55 Belair that had a nice set of fuelie heads....I ended up with two of those brackets, one on either side of the alternator ear.
What belt number are you currently running?
11-15-2023, 08:50 PM | #181 |
please send me a picture of your set up ....
I was using the Napa belt shown and when I put the double pulley on I went to auto zone for two Duralast that were supposed to match ....
11-16-2023, 01:39 PM | #182 |
Much to my dismay, I haven't had the Belair since the late 80's...
Seems to me that you could use 15545's for a 1/2 shorter, or 15540 for a full inch. It's kind of old skool, but you can ask for a matched set, and hopefully you are dealing with an older counterman.
11-16-2023, 09:07 PM | #183 | |
11-17-2023, 12:05 PM | #184 |
Well, I am an old counterman (since 1983), so I get it.
I truly miss that ol' 55, wasn't the fastest, wasn't the best stopping or handling, didn't get great mileage, etc...but it was by far the best car I've ever owned.
11-28-2023, 09:28 PM | #185 | |
God Bless
11-29-2023, 11:56 AM | #186 |
Cheers!
12-02-2023, 08:12 PM | #187 |
finally .....so never a short story paint shop didn't make enough paint to complete the entire truck ( gave them a entire disassembled truck) so when they made the new batch didn't match come to find out PPG discontinued a tint that was being used in the formula( body shop offered to paint the entire truck again I said no because of my time invested in reassembly etc. they agreed and turned up the heat on PPG, PPG rep came out got it 97% close only good in horse shoes and POLITICS ):body shop kept the pressure on PPG and then they ask us to send them a correct color part(step from stepside) to their Lab in Pittsburg so they could create a formula and do a spray out .........we have a match ....its tuff with pictures and this color looks more blue gray than blue in some light and a lot blue in the sun light .....so after weeks of the back and forth ....we have a match so back to assembly ..first get the bed wood prepped ....stay tuned
12-16-2023, 09:26 PM | #188 |
no match back to shop for repaint
12-16-2023, 09:29 PM | #189 |
starting on bed wood fed up with paint fiasco trucks in shop being repainted in is entirety
12-18-2023, 10:11 PM | #190 |
satin................bottom side 24hr dry time another coat tomorrow
12-19-2023, 01:02 AM | #191 |
What finish coat are you using on the wood?
12-19-2023, 10:38 AM | #192 |
Really brings out the heavy graining!
12-19-2023, 10:52 AM | #193 |
X2, looks great, don't forget to do the ends of boards, mine checked
12-19-2023, 07:54 PM | #194 |
McCloskey Man O War Marine Spar Varnish Satin ...I was going to use an automotive clear but talked myself into this after reading a lot on the subject....I think im going to like it
12-19-2023, 08:54 PM | #195 |
[QUOTE=Shifty One;9268042]Really brings out
yes it has second coat made them look a little darker... now on to top side tomorrow
12-19-2023, 08:56 PM | #196 |
got the ends Jim
12-20-2023, 09:24 PM | #197 |
buffin...bedsides
12-28-2023, 10:21 PM | #198 |
shifting gears again.... truck out of paint finally now putting it back together for the finale
12-29-2023, 10:52 AM | #199 |
Coming along nicely!
12-29-2023, 10:49 PM | #200 |
