02-01-2024, 12:13 AM | #4576 |
Re: What did you do to your truck today.The 3rd chapter
Did you secure the 3-Spoke wheel too?
02-01-2024, 12:28 AM | #4577 |
02-01-2024, 02:11 AM | #4578 |
02-01-2024, 09:21 AM | #4579 |
That bezel cleaned up really good!
Looks amazing! I would have grabbed the other goodies there too. -ignition switch and bezel -cigar lighter and bezel -factory radio (even if it didn’t work) There’s probably more...you found a good one there!
"If it ain't broken, fix it 'till it is!" |
02-01-2024, 09:35 AM | #4580 |
That truck is at this place:
https://www.frenchlakeautoparts.com/#CONTACTUS I had to have the gauge cluster shipped to me. If I had been able to see it in person, then you bet I would have grabbed a bunch of stuff. |
02-01-2024, 11:48 AM | #4581 | |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
02-01-2024, 04:32 PM | #4582 |
Back when I last replaced my shocks I noticed my mounting studs were pretty stripped. Just got around to replacing them and installing CPP shock supports as well. These were a bear to replace.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
02-01-2024, 05:10 PM | #4583 | |
A larger diameter is more attractive if you don't have P/S. You get more leverage for Armstrong Steering.
02-01-2024, 05:41 PM | #4584 |
Bought this 1969 Firts Aid Kit
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
02-02-2024, 06:51 AM | #4585 |
Oh this new $20 tachometer is awesome! Fired up the truck for the first time after installing this thing and the needle immediately jumped to 5400 rpm. Stayed that way for about a half an hour while I drove to town and then the second time I started the truck the needle didn't move at all. I couldn't care less, it's pretty blue and now that I fixed the striped out printed circuit ground screw and added blue LED bulbs I can read the oil pressure gauge at night. Hey at least it's still accurate with the engine off right? |
02-02-2024, 02:02 PM | #4586 |
Piling up the pieces needed to do a power steering install on my truck. Waiting on new power steering pump and alternator belts along with the new rag joint.
Also working on a custom bumper that will be only as wide as the bed box.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
02-02-2024, 08:11 PM | #4587 |
Took truck in for alignment. I had set the new tie rods to match the old ones and put the old shims back after replacing the cross shafts. It probably would’ve been close, but since I had dropped the front close to 2”, everything thing was off. The camber was tilted in and the tires were toed in 1 1/2”.
02-03-2024, 12:43 AM | #4588 |
ingested 14.56 gallons
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
02-03-2024, 01:31 PM | #4589 |
02-03-2024, 04:22 PM | #4590 |
...It is a beauty.
02-03-2024, 05:07 PM | #4591 |
Covered the old door panels with a vinyl that closely matches the seat...
Not sure if I'm just going to recover the bottom door panel black, or change it to the same as the door panel.
02-03-2024, 06:34 PM | #4592 | |
It goes more better faster, too, Yes?
02-03-2024, 06:36 PM | #4593 |
I have that same blue and white first aid box too. Contents are gone, used up.
But I kept it in my glovebox for years.
02-03-2024, 06:55 PM | #4594 |
I had to cannibalize the Battery out of my '68 C/10 Stepside to mount in the '71 GMC.
Yesterday, it was raining cats'n'dogs in Tucson [rare event] and I had to run into town -- wipers and lights on -- for a repair on my Android phone. [While working under the truck last Summer, the lens of the camera got smashed in my hip pocket.] They finally got the lens part in. So I went down. It would be a 90 minute wait, so I was gonna hit a bookstore to hang. No Start Gripe. Just the primordial ''click''. Had to go back inside the store to borrow my phone to call Roadside Rescue. The phone was fixed before the jumpstart guy got there. It started right up with the booster. Before going over today, I read 12.82 VDC on the battery terminals. I ran the Jimmy into O'RAP and got the System Check. Guy said the Batt was bad.[Bad cell, I guess.] Alt and starter OK. It's about 4 years old, so I will replace it maybe Wednesday. Until then, it'll run fine with the Pickup's battery.
02-04-2024, 07:27 PM | #4595 |
Finished the other door panel today.
Compared to the old chrome panels...I like the covered better with the billet handles.
02-04-2024, 10:41 PM | #4596 | |
Started it again later and the needle shook like crazy for a second and then pegged itself past 8 grand! I don't think this tach likes being plugged into an electronic ignition...I don't think this tach likes being plugged into anything, so I'll disconnect that lead and just admire its pretty blue lightning anyway. Thanks for the complement. |
02-05-2024, 01:34 AM | #4597 |
Would have just added these pictures to an edit but I don't know how to do that so you lucky folks get another post.
Added LED backup lights and in this picture the one on the right is LED and then both are LED in the dark. I think that will be a big help backing down my driveway at night. |
02-06-2024, 01:55 PM | #4598 |
Started to restore the wheel for the stepside . It’s in worse condition than I expected but I have time to play with it .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
02-06-2024, 05:43 PM | #4599 |
First coat on JB Weld
02-06-2024, 05:48 PM | #4600 |
Junior Member
Today I received my order from LMC. Two 8 foot fleetside 68-72 bedsides. Two lower front bed repair panels. And two door skins.
I am creating a fleetside longbed for my 157" wheelbase C30. So what I have to do is lengthen the bed 30 inches. I already have the front, top rail section, from a rusty bed. I bought the door skins mainly for the straight beltline at the door handle. I'm sure that I will need to raise the bed floor a few inches to get it low enough to line up with the cab. Cab has a 3 inch body lift on it already. I'll start a thread on this when I get into it some. |
