Old 01-25-2024, 10:00 PM   #1
twoskies
twoskies's Avatar
Roof Cutting
Hey
ive got a cab that is rough except the roof, got another cab that the roof is the bad part, tree fell on it
has anybody taken a good roof off and put on another cab
any suggestions to possibly speed up the process
any tool suggestions, ive seen the thin line sanders, probably buy this weekend, but any other that anyone can think of
yes i know , its going to be alot of spotweld cutting, lol
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 01-26-2024, 09:01 AM   #2
raidmagic
raidmagic's Avatar
Re: Roof Cutting
Are you replacing the whole thing or just the skin?
1965 C-10 1/2 ton shortbed part time daily driver
1980 C-10 1/2 ton shortbed project
raidmagic is offline   Reply With Quote
Old 01-26-2024, 10:00 PM   #3
twoskies
twoskies's Avatar
Re: Roof Cutting
hey
im replacing the inner and outer roof and the front outer windshield panel
Old 01-26-2024, 10:02 PM   #4
Lokin4AReason
Lokin4AReason's Avatar
Re: Roof Cutting
any foto s of the project s ?
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 01-27-2024, 11:27 AM   #5
Grounded63
Re: Roof Cutting
If it's a big back window. Cutting it at the pillars. Is probably the only thing. That will make it easier or faster.
Grounded63 is online now   Reply With Quote
Old 01-28-2024, 08:29 AM   #6
twoskies
twoskies's Avatar
Re: Roof Cutting
Here's the roof pictures, i know it;s alot of work, Aint Scared, lol
like most, more time than money and not alot of either
Old 01-28-2024, 08:33 AM   #7
twoskies
twoskies's Avatar
Re: Roof Cutting
inner roof pictures, might be able to hammer and dolly once the outer skin is off, probably use a headliner to hide the imperfections
Old 01-28-2024, 08:29 PM   #8
caseyjones
Re: Roof Cutting
No advice, but please take a lot of pictures of the process and post them here - it's hard to find good pictures of the inner structures of the roof.
caseyjones is offline   Reply With Quote
Old 01-28-2024, 09:19 PM   #9
Lokin4AReason
Re: Roof Cutting
cheque for spot weld s n drill the out w a bit ( or you can buy a spot weld drill bit )
and double cheque before you peel the roof
tha you can work your way down in seeing at what else needs to be replaced
take plenty or foto s of before starting the job . so you ll have a reference or seeing at how it looked before the job was started
i would start w the one your keeping in seeing at how far you need to pull things apart , imo
than work on the one your stripping for part s s
looks like a fun project , imo
just some time involved in doing it tho
Old 01-29-2024, 12:05 AM   #10
Getter-Done
Getter-Done's Avatar
Re: Roof Cutting
This type of drill for Spot weld works best for me.
Link: https://www.ebay.com/sch/i.html?_ssn....m3561.l161211
84 Chevy K-20
Old 01-29-2024, 01:48 PM   #11
62c30
Re: Roof Cutting
I replaced my 61 roof skin with an aftermarket one. I cut the skin off then air chiseled what was left. Cleaned it up and used panel bond and glued the new skin on. Really wasn't bad, and the panel bond should seal it off.
62c30 is offline   Reply With Quote
Old 01-30-2024, 08:56 AM   #12
twoskies
twoskies's Avatar
Re: Roof Cutting
62C30
I Like your Style
might try it that way, spent a couple hours last nite getting the old roof sealant off
also Getter Done
Thank You for the Link to the spot weld bits, ive ordered some
Old 01-30-2024, 10:58 AM   #13
62c30
Re: Roof Cutting
I do have some decent pictures of my 61 with the roof skin off if anyone needs anything. I had the skin off when it was blasted so I primed it and down the a pillars and anywhere else I could get before I glued the new skin on.
Old 01-31-2024, 08:32 AM   #14
twoskies
twoskies's Avatar
Re: Roof Cutting
hey 62C30
Pretty much what i was going to do, my inner roof needs some love when i get the outer off but sure i can get it close, going to make a headliner, should be easy as i can drill and seal some aluminum slats in the inner for support and use them for support for thin wood liner that ill cover with something
ill take whatever pictures you can share , just to use as a reference when i get the outer off
Thank You
Old 01-31-2024, 09:28 AM   #15
62c30
Re: Roof Cutting
Here are some pictures. There was some rust in some of the bracing that I think they reproduce now.
Old 02-01-2024, 09:00 AM   #16
twoskies
twoskies's Avatar
Re: Roof Cutting
ok
got my outer roof off, as expected its a mess underneath, i have cleaned up most of the loose rust and old soundproofing mats,
i still think i can save the inner roof, going to take a little time with dolly and hammer and most likely cut and weld
ill upload pictures after work
Old 02-03-2024, 12:07 PM   #17
twoskies
twoskies's Avatar
Re: Roof Cutting
pictures
after the outer roof was off, i was able to work the inner to a decent point, im going to make a headliner so that should cover almost all of the imperfections
Old 02-03-2024, 08:50 PM   #18
dmb
Active Member
dmb's Avatar
Re: Roof Cutting
If you dont mind me asking, what glue did you use and where did you get it Thanks David
dmb is offline   Reply With Quote
Old 02-03-2024, 08:56 PM   #19
62c30
Re: Roof Cutting
I'm pretty sure it was 3m panel bond but I'll have to look. It's not cheap but it works.
Old 02-03-2024, 09:52 PM   #20
62c30
Re: Roof Cutting
It's not cheap and you lose part of it in the tip but it seems to work well
Old 02-03-2024, 10:42 PM   #21
dmb
Active Member
dmb's Avatar
Re: Roof Cutting
Thanks I have yet to see anything that was good to be cheap in the last few years. I bet it is cheaper in the long run. I am going to try it. I dont weld as good as I did a few years ago. Cant see or hold still lol
Old 02-03-2024, 10:46 PM   #22
dmb
Active Member
dmb's Avatar
Re: Roof Cutting
The gun to use it is much higher than the Panel Bond on ebay
Old 02-03-2024, 11:05 PM   #23
62c30
Re: Roof Cutting
I think for the tips, gun and adhesive is was around $100 but it's been a few years. I've used it on several projects and so far has been great. It would bond different types of metal together and since there is no heat like welding no chance for warping or burning paint.
Old 02-07-2024, 08:54 AM   #24
twoskies
twoskies's Avatar
Re: Roof Cutting
ok
after looking at the inner roof, i probably wont be happy with it
so im looking at cutting it out,
Has anyone done this, i know where the obvious spot welds are
the upper door frame, across the windshield and across the back(only accessible after outer roof is out)
Old 02-07-2024, 09:36 AM   #25
62c30
Re: Roof Cutting
I replaced only the area above the windshield on the inside and out, not the whole thing. I think that panel for 64-66 is a newer part.
