Old 02-09-2024, 03:20 AM   #1
Duncan_s
Steering wheel choices
Had to find a steering wheel to replace my old steering wheel that looked like it had a bad time at a nuclear testing facility. pretty sure its a 1st generation chevy truck steering wheel. bolted up perfectly to my 1972 steering wheel, had to swap out some hardware from my original steering wheel but the horn works perfect! what are you guys running for steering wheels in your trucks?
Duncan_s is offline   Reply With Quote
Old 02-09-2024, 04:05 AM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Steering wheel choices
I've got the 15" repro of the one you removed(from LMC)
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 02-09-2024, 08:19 AM   #3
First generation C10 but certainly not first generation Chevy Truck. Anyway, I've runs a dozen or more different Chevy car and truck steering wheels in my 67-72 Chevy Trucks over the years. They all interchange. Comfort Grip, Camaro, 88-94, and '60s car horn ring type, mostly
Old 02-09-2024, 08:25 AM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Steering wheel choices
I like the look of the OEM '69-'72 wheel, but I may switch to the more sensible 15" repro.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 02-09-2024, 09:20 AM   #5
Mike C
Mike C's Avatar
My personal favorite is the 69 Camaro comfortgrip wheel using a 67-68 Camaro hub which is same diameter as the truck column.
The wheel was used in other vehicles as well, but the Camaro I believe is where it showed up originally and I know the 67-68 hub for when the ignition was on the dash works perfectly in the truck.
https://www.jegs.com/i/JEGS/555/7959...CABEgKJTPD_BwE
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-09-2024, 11:14 AM   #6
I am using the 88-94 GM truck wheel. Little smalller than stock and comfortable to hold. I also used a cover as it get hot here in the southern sun.
Palf70Step is online now   Reply With Quote
Old 02-09-2024, 11:53 AM   #7
Duncan_s
yeah thats what i meant. i love that so many chevy steering wheels as re able to bolt on without the use of adapters.
Old 02-09-2024, 12:00 PM   #8
Duncan_s
those seem super popular and they look pretty good. i wanted a more traditional look to mine i also dont have power steering so i really do need a big steering wheel.
Old 02-09-2024, 08:09 PM   #9
dmjlambert
dmjlambert's Avatar
That's my favorite steering wheel and horn button you have Duncan_s. I have it on my 1969 truck. If I sell my truck I'll be keeping the wheel. It is a 62-65 Chevy II steering wheel and also was the one-year-only 1966 C10 standard wheel. I have it on my list of things to do to paint it and make it look new.
Old 02-09-2024, 08:57 PM   #10
HO455
HO455's Avatar
Actual "First Gen" steering wheel. Just for amusement only.
https://driving.ca/features/feature-...in-to-this-day
RIP Bob Parks.
Old 02-09-2024, 09:38 PM   #11
dmjlambert
dmjlambert's Avatar
That is pretty interesting and is now my second favorite. I wonder what those levers in the steering wheel do and how they work.
Old 02-09-2024, 10:46 PM   #12
RenoKeene
Florida Edition
RenoKeene's Avatar
This one seemed to work with the theme of my build.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 02-10-2024, 12:51 AM   #13
'68OrangeSunshine
'68OrangeSunshine's Avatar
When I first bought my '71 GMC Jimmy, the PO had mounted a tiny Grant wheel.
Steering geometry was all wrong.
After it came off in my hand -- in traffic -- it had to go. Lucky he also included the 17'' stock '71 wheel. After I put it on, the truck handled perfectly, and I intuitively knew where the nose was pointed by feel.
But I am long-accustomed to the '67-'68 3 Spoke wheel, like on my '68 Stepside. I like the way it fits between my fingers. At 16'' it's less unweildy than the '69+ style.
Someday, I may put a 3-Spoke wheel in the '71 Jimmy, and move the Headlights and Wiper switches to the positions as they are set up on the '68. That way all my controls will be uniform. [I have a '68 GMC chrome horn button.]
'68OrangeSunshine is online now   Reply With Quote
Old 02-10-2024, 09:14 AM   #14
raggedjim
raggedjim's Avatar
Hand throttle and spark advance.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 02-10-2024, 09:19 AM   #15
ZEKE68
ZEKE68's Avatar
I got a new replacement 67 - 68 three spoke for my 68.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 02-10-2024, 05:37 PM   #16
'68OrangeSunshine
Great.
Seen them in the LMC catalog. I heard the early ones were too flexible -- hope they fixed that. At three bills they're kinda spendy. IMO. But finding a nice OEM wheel can be difficult 50 + years after-the-fact.
Old 02-11-2024, 01:05 AM   #17
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
I always run a comfort grip wheel in my old Chevy's and currently have a blue one in my 68. The come in a few colors besides Black. I think they repop red along with the blue. I think there was other colors offered on original wheels. They were also used on Buicks in the same time frame.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 02-11-2024, 05:25 AM   #18
Richard
Steering wheel I am using on my truck. Similar to comfort grip but 15", fatter and leather covered. Feels good in hand at this point. Steering will be effortless with the ram assist on my truck. A bit worried it will feel to easy..
Richard
Old 02-11-2024, 09:16 AM   #19
raggedjim
raggedjim's Avatar
One in green.
Roger
'70 GMC Jimmy 2wd
Old 02-11-2024, 10:09 AM   #20
70 shorty
Where's my beer?
70 shorty's Avatar
I have the same Grant aftermarket wheel that RenoKeene has. I like it because it looks similar to the comfort grip wheel at a fraction of the cost. Real wood on the wheel, and thick grip are a plus in my opinion as well.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 02-11-2024, 12:34 PM   #21
I was going to build the '72 Short bed I had into a white Cheyenne Super with red inside the bed and interior. I have this era correct steering Caprice steering wheel I was going to use to add an extra touch of woodgrain. It's really rare. It even has woodgrain in the rim. Sold the truck as is years ago
Old 02-12-2024, 11:09 PM   #22
K10-Kansas
K10-Kansas's Avatar
I bought a 15 inch reproduction
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350 and 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 02-13-2024, 01:18 AM   #23
Duncan_s
A lot of great steering wheels, thanks all. these trucks look so good with so many different steering wheels.
Old 02-13-2024, 01:29 AM   #24
'68OrangeSunshine
Nice color.
Old 02-13-2024, 11:27 AM   #25
68 C10 Driver
This was what I decided to go with, a 1965 El Camino steering wheel. Being it is a car steering wheel, I did have to build out the base of the wheel so it aligns with the steering column which is larger in diameter. I like the look of the classic steering wheels, they were definitely works of art.
68 C10 Driver is offline   Reply With Quote
