Trying to clear up 15x8 truck rally confusion
Hi guys,
I’m planning on picking up a set of OEM 15x8 6-lug (4.0” BS) truck rally wheels tomorrow. I don’t know which Chevrolet model they originated from but I understand that they made these wheels from 67-87 C10/Blazer. Somewhere in that time the stud size changed from 7/16-20 to 1/2-20. Additionally some of these rallys came from 4wd and some 2wd c10/blazer. I assume these are all interchangeable and will fit a ‘69 c10 2WD regardless of what c10/blazer they originated from? Would you please help confirm. I’m trying to avoid buying wheels that won’t fit my truck (wrongly assuming I can run a 1987 4WD Blazer rally wheel on my ‘69 c10, for example). Thank you Last edited by Luke87gt; 03-16-2024 at 07:01 PM. |
![]() Join Date: Apr 2008
Re: Trying to clear up 15x8 truck rally confusion
I think whatever year they were made will fit your 69
71 C10 72 K20 72 K10 Super Kirk |
Pretty sure the 15” 6 bolt rallies will fit on ur 69 ,even if the 69 has drums
Rally wheels were not available I don't think until 1975. 6 bolt anyway. I think all 6 bolt were 4X4. They will fit on trucks all the way back to at least 1960. Off set is different but lots of pre 71 2WD trucks run them.
![]() Join Date: Oct 2009
Squarebody 6-lug 4x4 rallies thru 87, like the ones you have pictured in post #1, will fit 67-70 C10 and 67-72 K10.
New Member
![]() Join Date: Feb 2024
15x8 5x5 muscle car style steel wheels at great price at Summit
sale $50.39 (Save $5.60) |
![]() Join Date: Jul 2003
A 1969 C10 has 6 lugs, not the 5x5.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
The 6-lug 4wd Squarebody 8" truck rallyes were used through '91 on V-model Blazer/Jimmy/Suburban and they will fit an earlier 6-lug GM Truck going as far back as that boult pattern goes. I have run them on 60-70 trucks myself. Just bolt them on and roll down the road.
Nice to know. They are known simply as car rallyes. But yes, they are now made by the aftermarket in both 5 and 6 lug truck patterns
#9 | |
I almost pulled the trigger but these oem truck rallys came on the market locally. Since they were clean I picked them up. I think they’ll look great.
1969 C10 Shortbed Wanted (pm me): - Pair of 275/60/15 tires |
#10 | |
Still a good deal with free shipping.
![]() Join Date: Dec 1999
You can see these later model rally wheels on my 72 K10 in the first post of my build thread. Missing some parts, but many are. Not going back on the truck as evidence in the thread shows. Sit pretty far in on the back of my K10 due to the back spacing.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#12 | |
Those GM Ralleys were a Squarebody 4x4 item through '87. They will work on earlier 6-lug 2wd trucks too. Pre-71, C10's had 7/16 studs. Once disc brakes came along, it was 1/2" studs. They will work on either size of studs w/the correct lug nut.
Also what is the c10 wheel hub diameter ?
C10's were 60-87.... Things changed so be more specific.
#15 |
'86 technically.
![]() '87-'91 were "R". K [just bustin ya chops]
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#16 |
Yep. But that nugget usually confuses those that aren't in the know.
#17 |
How about a ‘69 6lug?
#18 | |
K
#19 |
Especially problematic for guys like me since I have an '89 CC dually as well as a '99 CC SWB 2500. 'Ya gotta' know or you'll be wasting time & energy.
