Old 06-14-2002, 11:56 PM   #1
nosto
Flamin' Bass
nosto's Avatar
Shaving and smoothing?
I shaved (aka filled in) my antenna hole, cab fuel filler and door handles using a welded patch piece and finished with body filler.
I'd like to smooth (aka make disappear) the rear roof seam. Is that usually done with:
weld,
body filler or,
seam sealer?
Yeah, I know the usual next step is to shave the drip rails, but I just spent so much time filling those suckers with sealer I'm not going to touch them again!
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 06-15-2002, 12:47 AM   #2
PushinPebbles
My dad's 68
PushinPebbles's Avatar
Just fill it w/ drip check.......like you did w/ the drip rails...........
welding?!?! I guess it would work................i might just try it!
..................................Jack
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
grand dads truck 68 C-10 stepside
fuel inj. 350/700R-4*soon in audi silver*
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
Old 06-15-2002, 01:06 AM   #3
Blue_71
Bloo
Blue_71's Avatar
ive got a cab that that has been filled with body filler
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 06-15-2002, 01:18 AM   #4
chevyman 68 C/10
chevyman 68 C/10's Avatar
The only way to know you will not have future problems with cracking is to use your mig and weld it ,grind it and finish with a light coat of body filler.
Chevyman 68 C/10
chevyman 68 C/10 is offline   Reply With Quote
Old 06-15-2002, 10:08 AM   #5
ryes 69
I did my roof seam and dash(no dash pad)with fiberglass bondo 7-8 yrs ago NO cracking yet
ryes 69 is offline   Reply With Quote
Old 06-15-2002, 10:20 AM   #6
XXL
Seņor Member
XXL's Avatar
Lots of varied suggestions so far, that appear to be working. The "pros" will likely tell you to weld it, and welding that line is pretty straightforward. So if you want to practically guarantee it won't crack (just before you do that $8000 paint job on it ), you should weld... otherwise, Drip Check sealer, fiberglass, or plastic filler all appear to be working for others.
Kenneth
XXL is offline   Reply With Quote
Old 06-15-2002, 08:35 PM   #7
chevyman 68 C/10
Wink
I want to know ,with the price of primer, sealer paint and all those hours blocking , that I wont get a crack- no matter how small.
