Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Forums > Past Contest Winners > 2004 ToTM Archive
Old 09-02-2004, 09:57 AM   #1
Liz
Catchy title goes here..
Liz's Avatar
August 67-72 ToTM Winner
Congrats Junkie
General
Manufacturer:GMC
Year:1971
How long have you owned this truck?:4 years
History behind the truck:As far as I know my Burb was "born and raised" in Calif. The guy I bought her from owned her for about 13 years. I know she was "used and abused". The PO owns a paint and body shop, so when I purchased her, she had a fairly new paint job, but the metal wasnt treated properly in places, so rust control is an ongoing problem. My Burb has recently gotten a new SB 350 with a HPCam, I had changed to headders, but soon got tired of them heating my starters and blocking my plugs, went back to rams horns manifolds. She has 2 ch. Flowmasters, with 3 in. tips that end just before the rear axle. Bout 2 years ago, she got a new T350 tranny with a shift kit installed. Shes had all new brakes, and the front end all rebuilt. Shes borderline stock. She was "Born" with over head A/C, but I removed that and had after market AMA under dash A/C installed. My Burb is my daily driver. Shes taken me Coast to Coast 2 times, only problem was a broken fan belt. The paint job thats on my truck was there when I bought her, its a Pearl white with a lavender over spray. The graphics were the POs too. I plan on having a "frame on" resto done in the comming years, she will be a simple Pearl white, the strips will be removed and her body will be smooth. She has the "Clam shell" type rear doors now, and Im working on a set of Barn style doors to replace them
Chassis
Suspension type:stock 1/2 ton, leaf springs/shocks
Front Brakes:disc
Rear Brakes:drum
Steering:605 pwr. steering w/ steering dampner on tie rod.
Front and rear tire/wheel type:Rims 15 in, Inkys ? (PO) Tires BF Goodrich A/T 32.11.50
Front differential type / Gears:Stock
Rear differential type / Gears:Stock
Body
Color Scheme:Pearl white with a lavender "overspray" Graphics were PO idea.
Bodyman:George Judd, Escalon Body and Frame,California
Modifications:After market 42 gal. fuel tank, other wise stock.
Interior
Color:Gray
Material:Tweed
Wiring:Stock
Modifications:Aftermarket under dash A/C.
Steering wheel/Column:Stock
Stereo/Speakers/Amps:Kenwood AM FM Cassette (yes cassette ) 4 6X9 speakers in rear, have 2 more 6X9s and 2 5in goin in eventually.
Air Conditioning:After market "Arizona Mobile Air" under dash
Instrument Gauges:Stock
Engine
Cubic Inch:350 Small Block
Manufacturer:GM
Camshaft:Forged Steel
Cylinder heads:Stock
Valve Covers:Edelbrock Elites
Intake Manifold:Edelbrock
Ignition System:HEI
Exhaust type:Stock Ramhorn Manifolds, 2 ch Flowmasters w/ 3 in tips ending just before rear axle.
Transmission
Automatic / Standard:T350 auto
Torque Converter:Stock
Shifter type:Stock
Drive Shaft:Stock
Liz is offline   Reply With Quote
Old 09-02-2004, 12:20 PM   #2
Mudder
Mudder's Avatar
Congrats Jodie!!! Well deserved.....
Mudder is offline   Reply With Quote
Old 09-02-2004, 01:10 PM   #3
70c10
67-72 Addict!
70c10's Avatar
congrats Jodie!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-02-2004, 10:11 PM   #4
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Congrates to you Jodie. You have put alot of hard work into your Burb. Well deserved.
Dennis
oldiron is offline   Reply With Quote
Old 09-02-2004, 11:11 PM   #5
gr8scott51
gr8scott51's Avatar
Good job Jodie!
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 09-07-2004, 07:48 PM   #6
Pont
I need another Barley Pop
Pont's Avatar
Congrats girl, you deserve it!
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
