Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 11-18-2012, 05:09 AM   #226
BrutonLS1
BrutonLS1's Avatar
Re: Color Wiring Diagram FINISHED
I wish I could have made this bigger so y'all could see the issue i'm having, you may have to reference to another diagram on this thread. I just can't tell which holes they're going into and why there aren't as many wires on the other side.
-Bruton
1968 GMC long bed 5.7/700R4
--I'd rather push a Chevy, than drive a Ford.--
BrutonLS1 is offline   Reply With Quote
Old 11-18-2012, 12:06 PM   #227
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Hey, BrutonLS1.
Here's a bigger diagram. If the Forum's jpeg format works. You can save in and make it larger without it "fuzzing up".
I'll likely tell/ask you what you already know.
The wires plugging into the fuse block are not matched one for one coming thru. There are elements in circuits that are "jumped"
together to be handled by a common fuse at the fuse block "train station".
I can't tell what specific wires you are asking about. But, since I've poured over every wire waaay too many times,
if you just hint at what your issue might be, I bet a bunch of folks will chime in.
I spent a while focusing on your diagram "circles". Then, I realized that you need to front some more info....I'll try to enlarge the specific areas you "highlight" in a minute and post them.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 11-18-2012, 12:16 PM   #228
magwakeenercew2jh
Oops! Your elect. areas......
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 01-15-2013, 12:53 AM   #229
truckster
truckster's Avatar
I realize this is an old thread, but I've used the information a number of times for myself and to help others.
Thanks!
truckster is online now   Reply With Quote
Old 01-21-2013, 11:51 PM   #230
franciscocl7
franciscocl7's Avatar
Originally Posted by gkesseru View Post
The wiper motor wiring does not match the shop manual:
Hi guys....I have the master diagram, I can modify any change you observe on it
franciscocl7 is offline   Reply With Quote
Old 01-30-2013, 10:26 PM   #231
MarineChevyDriver
MarineChevyDriver's Avatar
Can anyone explain what it means to have a 12, 18, or 21 circuit harness?
MarineChevyDriver is offline   Reply With Quote
Old 01-31-2013, 12:19 PM   #232
harley rider
harley rider's Avatar
this is the amount of accesories you can power. if you have no things like electric fuel pumps or fans or ac, ele. windows or seats, you can get by with a 12 circuit. there are some 9 circuit kits from rebel or E-Z wire I prefer the E-Z kit but there about the same. the more stuff you have the more circuits you need .
harley rider is offline   Reply With Quote
Old 01-31-2013, 08:23 PM   #233
MarineChevyDriver
That's the best explanation I could have asked for. What is the most common? I see a lot of 18's out there on the forums.
Old 02-04-2013, 09:31 AM   #234
crakarjax
crakarjax's Avatar
I went with 21 just to be future-proof. You don't have to use any circuits that you don't need.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 02-04-2013, 06:41 PM   #235
harley rider
most of the ones I've installed were 21 but get what fits your project and think ahead of what you might do in the future.
Old 02-07-2013, 03:53 PM   #236
hippisteve
Hello,
I'm in need of some help...
I have a "67 c10. I am neck deep in a wiring issue.
I have head lights, tail lights. Signal lights, and four way flashers.
However, when I turn on the headlights, signal right or left, the other side flashes between back-up lights and tail lights. I also have no horn?
I have replaced the signal light switch, hoping that was the issue. But....
I know the tail light sockets are rusty, it has a wood bed, and I'm not sure where to find the ground.
I can't download the wiring diagrams on my ipad.
Any help would be greatly appreciated.
S.EllisWoodWorking@Gmail.com
hippisteve is offline   Reply With Quote
Old 02-07-2013, 04:33 PM   #237
magwakeenercew2jh
Originally Posted by hippisteve View Post
Hello,
I'm in need of some help......snip...However, when I turn on the headlights, signal right or left,
Sorry. What does the last part of that first sentence mean?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 07-06-2013, 10:49 AM   #238
SpawnAden
If some one could send me the huge color diagrams I would be grateful!
bcalcote@gmail.com
Just some pics of what I am knee deep in... (72 GMC 2500 402 BBC ).
SpawnAden is offline   Reply With Quote
Old 07-15-2013, 07:10 PM   #239
CSGAS
optomistic ah-so
CSGAS's Avatar
franciscocl7, What format is the original diagram in? I'd like to make up a custom diagram to follow for my truck. I have Visio and access to a computer with Illustrator (all of the apps from the current Adobe CSs actually) and Freehand. I also have friends who can convert most CAD formats to something I can modify (I've done that before, and.....well, it's better than starting from scratch--Sometimes).
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 08-01-2013, 11:37 AM   #240
twisty
twisty's Avatar
thanks a ton to all who put these up! took a while to go through all the pages in here, but i think i got enough to rewire the whole truck!
twisty is offline   Reply With Quote
Old 09-26-2013, 06:01 PM   #241
72_ChevyMan
Can anyone tell me the size of the wire they are? Like when it says 18 by the name on the diagram is that the size of the wire? If so 20g seems way to large. I'm wanting to rewire the entire truck with just wire (have some custom things I want to do) instead of buying a kit. I just cant find what gauge of wire I'm needing to buy and what gauge goes where. Thanks
72_ChevyMan is offline   Reply With Quote
Old 09-26-2013, 08:16 PM   #242
fixit-p
fixit-p's Avatar
The numbers are the wire size. 20 ga wire is actually pretty small.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 09-26-2013, 11:55 PM   #243
BlacklandCamper
Thank you, thank you, thank you!!
This will be a huge help.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline   Reply With Quote
Old 09-29-2013, 08:21 PM   #244
CST10
CST10's Avatar
Hello All,
I have a 1970 cst10 that I seem to be having electrical issues in the dash cluster. Also missing lic plate and reverse lights.
Can some one please send me the full diagram so I can print to help try and solve this issue.
Thanks.
thedagobergs@eatel.net
CST10 is offline   Reply With Quote
Old 12-03-2013, 04:13 PM   #245
themikehyde
Same here: I am looking for the wiring and vacuum hose drawings for a 1970 6Cyl.
mike@themikehyde.com
Thanks!
themikehyde is offline   Reply With Quote
Old 12-06-2013, 07:32 AM   #246
CSGAS
optomistic ah-so
CSGAS's Avatar
CST10, it sounds like your problem is most likely the light switch. I know it seems unlikely but a lot of circuits run through it. If that's not the problem, your printed circuit may not be connecting to the harness connector well anymore--brittle, cracks, corrosion, whatever.
themikehyde, I haven't run across vacuum hose drawings yet, but there are very few vacuum items compared to most passenger cars. The 6 cyl wiring diagrams are on the first page.
Guys, you know what I found out? NONE of the GM diagrams that appear to be useful, show the cig lighter option and what color wire is "factory correct." I only realized a few weeks ago that the INSTALLED cig lighter, is NOT connected in standard/baseline vehicles--only with package upgrades!
Rubbing is Racin'
Old 12-06-2013, 11:36 AM   #247
themikehyde
CSGAS, All I saw on the pages was links for the v8, not the 6.
Mike
Old 12-11-2013, 09:46 PM   #248
Steve-W
Steve-W's Avatar
I suck at reading wiring diagrams..
Ok guys, I really need your help on this one, because I am going around in circles.
in my 69 c10 I'm putting in a 12 circuit mini set from EZ wiring. everything is labelled, so far so good. But I need to connect it up to my excisting horn/direction connector, that would be that half moon shaped connector dangling underneath my steering column right?
If I try to read my wiring diagram, I have no clue whatsoever which wire ends up where. I'm trying to follow the wires through the diagram from the connector down to the horn and/or indicator lights..but I get lost at the fuse panel and at the blockhead connector.
So who can tell me which wire does what in the red squared box in the picture. you are also very welcome to tell me what an idiot I am if it's to easy to miss, but I just don't see it.
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 12-11-2013, 10:25 PM   #249
Special-Ed
Special-Ed's Avatar
Re: I suck at reading wiring diagrams..
document is incomplete at best... i can land all wires except the ones that go off the page directly under the half moon connector
take colored pencils and literally trace each line in a different color...
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 12-12-2013, 01:30 AM   #250
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Try this one.
and here's yours.
Ignore the arrows
bottom to top.
White-brake switch.
Dark green -to right rear turn/brake light- goes to the connector in the firewall behind the distributor
Yellow- to left rear turn/brake light- goes to the connector in the firewall behind the distributor.
Purple - from fuse panel flasher to turn signal switch.
Brown- from fuse panel hazard flasher to turn signal switch
Dark blue- from turn signal switch to front right signal with a connector wire to the dash cluster for the right signal indicator light.
Light blue - from turn signal switch to left front signal light with a connector wire to the dash for the left turn indicator light.
The dark blue and light blue wires go from the connector through the firewall wiring block into the engine bay and through the harness to the left and right signal lights. The connector wires join them at the block on the inside of the cab or at the half moon connector.
Black- this is the horn relay ground wire from the steering column to the horn relay.
What else you got.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
