#226 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Killer
Bags are bottoming out and im running stock spindles with a 1 1/2 sectioned crossmember. Looks like imma order some drop spindles thanks matt thread hijack over..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#227 |
Texas Big Wig
Re: Killer
No problem
I dont know what wheels you are running, but I have read that 3" drop spindles wont work (or at least not W/O mods) with 15x8" wheels I bought the 2-1/2" DSs & mine are pretty close |
#228 |
Texas Big Wig
Re: Killer
Well I checked the mail today & I got my new rear view from Mekdad
What it looks like out of the box Not bad, but has VERY sharp edges & slight machining marks ![]() ![]() So I smoothed the edges with a orbital sand & uses 220 grit Then I hand sanded it with 600 grit ![]() ![]() Then I polished it on the buffer ![]() ![]() |
#230 |
Texas Big Wig
Re: Killer
I also worked on the heater box some more, but didnt get it finished
And I took some more pics of it at dump... Mainly cuz Im pic whore ![]() In some of teh pics below the front tires are sitting on some 2" thick boards because the LCAs dont slide on the cement very well & wont let it lay 100% out, so with the boards under the tires it actually lays out a half inch lower than without (5" to the bottom of the bumper at the lowest point W/O the boards & 4-1/2" with the 2" boards under the tires) ![]() ![]() ![]() ![]() ![]() ![]() ![]() Nighty Night Killer ![]() ![]() Last edited by Spray-Bomb; 12-02-2008 at 09:49 PM. |
#231 |
On the fast track to nowhere..
Re: Killer
Cool! How you think that mirror bracket would look painted black? I want mine to look as stock as possible and the polished aluminum just doesn't look stock to me.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#232 |
Rusty but Trusty
Re: Killer
Mirror bracket looks great.
At dump now, what is the distance to pinch weld? What will crossmember to pavement clearance be at ride height? What length shocks will you need or are you going to mod the brackets to run stock? Is this where you plan to leave the front suspension for a while, at least til you get a drop member? Or do you have other mods planned for it? Looks really good.
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built |
#233 | |
Texas Big Wig
Re: Killer
![]() IIRC its about 3" (the middle of the front bumper is 5") Im not sure of that, but thats not what I have to worry about, my LCAs are the lowest part of my scrub line I still need to measure & see how long they need to be Yeah this is as low as Killer 1.0 is going ![]() Although I may pie cut my UCAs to help with camber ![]() |
#234 |
Re: Killer
I've been considering the very same thing
#235 |
Re: Killer
Hey bomb just wondering why wont the 3" drop spindels work? i have a disc setup out of a 81 and i was going to order the 3" spindels any info? On my member i plan on using a couple drag blocks and jsut bolt it to the bottom of the member not sure if that will work but it seems good in my head.
2009 dodge hemi custom paint 86 lwb bagged layin frame 73 2 door nova 54 bel air |
#236 |
Texas Big Wig
Re: Killer
They make the LCAs REALLY close to the wheels & the more inset the wheels have the worse it is (only with 15" wheels, anything bigger is just fine)
Now I have heard of some people clearancing the LCAs so they dont rub or knock off the wheel weights, but I have never done it In the end it only matters how low you want to ride & its only a 1/2" My truck would lay out just as much in the front without them, but it had STUPID camber & to get rid of the camber I had to air it up a lot Last edited by Spray-Bomb; 12-03-2008 at 03:23 PM. |
#237 |
Re: Killer
ok then ill be ok ill be runnign 20's up front and 22's in da back thanx for the info and that truck is looking nice
#238 |
Texas Big Wig
Re: Killer
I really didnt get anything done to Killer today... but I did stare at em, does that count ???
I mocked up the heater box & I think Ima have to cut the corner of it a lil more for more clearance It clears the tire, but it wouldnt allow for a inner fender I will be filling in the stock hole & making a tube that runs into the inside of the cab... A sort of bulkhead I suppose ![]() ![]() ![]() Also found out that at true full dump, my tires come off the ground ![]() ![]() |
#239 |
Re: Killer
That's sweet!
#241 |
Re: Killer
what is the truck resting on when the wheel is off the ground?
pretty cool!
#242 |
Re: Killer
cant get no lower than that
#244 |
THE TOY STORE
Re: Killer
hope you dont plan on drag'n it. scarry to drag and not be able to atleast stear a little bit
#246 |
Re: Killer
Great work on this build! How about the pie cut on the UCAs you mentioned earlier to help with camber issues. What's involved or whats the general procedure?
#247 |
Texas Big Wig
Re: Killer
I havent done that yet, & I was mistaken on what it does... It helps with BJ bind, not camber
#248 | |
Re: Killer
Adam M STX Designs Motorcycles | Choppers | Hotrods |
#249 |
Eat My Rust
Re: Killer
Hope you don't ever need to turn when dropped... lol
killer ride. ![]() |
#250 |
and a few others
Re: Killer
back on page 7 where your dad's holding the fender in place, is that at ride height, or are the bags dumped, or are the bags in yet? will it go lower than what is shows in that pic?
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
