07-06-2022, 03:53 PM | #226 | |
Re: Lets see those BUDDY BUCKETS!!!!!!!
07-07-2022, 09:21 PM | #227 |
Who Changed This?
Hot ziggity, those are some nice seats!
02-17-2023, 08:10 AM | #228 |
Finally got around to re-upholster my buddy buckets last night, just need to clean and paint the slider to consider them done. Added a couple of stainless steel cupholders to the seat back as well.
One question, might be lame, but here goes. The strap with the velcro, on top of the buddy seat foldable back, what's it's purpose?
Driver carries no cash. He's married. '67 Chevrolet C10 SWB - 350 Vortec/TH700R4 Backyard Engineering |
02-17-2023, 08:50 AM | #229 |
To hold center seat to the cab so it won’t fall forward
Az |
02-17-2023, 06:28 PM | #230 |
Thanx for the reply Rods, much appreciated.
02-20-2023, 06:07 PM | #231 |
Basic set, covered in factory parchment. Frame and jump seat powder coated black. Upholstery shop added the cup holders.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
04-14-2023, 11:20 PM | #232 |
I tore apart my buddy bucket seats in preparation for restoring them. Here are a bunch of photos of the internals.
The upper upholstery is stapled closed. Last edited by pjmoreland; 04-14-2023 at 11:53 PM. |
04-14-2023, 11:22 PM | #233 |
Mildew!
There is thin foam and plastic sheet on the back side of the upholstery. Last edited by pjmoreland; 04-14-2023 at 11:54 PM. |
04-14-2023, 11:25 PM | #234 |
The springs are embedded inside the foam.
04-14-2023, 11:27 PM | #235 |
I sure hope I'm able to reuse this rubber U-channel. I'm going to flip it over so the new staples go into a fresh side. The original staple side has some cracks starting to form in it.
04-14-2023, 11:29 PM | #236 |
U-channel and staple dimensions
04-14-2023, 11:31 PM | #237 |
The bottom flaps of the seat back upholstery overlap and are stapled to the dense rubber U-channel.
Hog ring dimensions. Last edited by pjmoreland; 04-14-2023 at 11:56 PM. |
04-14-2023, 11:33 PM | #238 |
There are cardboard stiffeners stapled to sections of the lower upholstery that tuck up under the upper upholstery.
04-14-2023, 11:35 PM | #239 |
The seat bottom upholstery is secured with one steel listing wire in the back and hog rings along the sides and front.
04-14-2023, 11:38 PM | #240 |
The passenger side foam was in decent condition other than reeking of mildew.
04-14-2023, 11:40 PM | #241 |
There is a gridwork of thin steel wires molded into the bottom cushion. It is attached to the lower springs with four pieces of fine rope.
I believe these seats are 1967 model year. The driver seat tilts, and the passenger side is fixed. |
04-14-2023, 11:42 PM | #242 |
That brown stripe is a rip in the foam that appears to have been repaired in the factory.
04-15-2023, 05:39 PM | #243 |
I just had these recovered when I get to the storage unit ill get a pic of the new covers
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-16-2023, 08:26 PM | #244 |
as discussed here they are recovered
04-23-2023, 01:58 AM | #245 |
Here are some photos of the reassembly of my seats. I used spray adhesive to glue the cloth sections of the upholstery to the foam so that it wouldn't be loose.
04-23-2023, 02:00 AM | #246 |
I used spray adhesive to secure the foam to the frame.
04-23-2023, 02:02 AM | #247 |
I had to add a layer of 1/2" foam to the front surface of the bottom foam because the upholstery was slightly larger than the ACI foam.
The upholstery set was made by Rick's Upholstery. http://67-72chevytrucks.com/vboard/s...d.php?t=772584 Last edited by pjmoreland; 05-21-2023 at 11:08 AM. |
04-23-2023, 07:27 AM | #248 |
Lots of work on those really paid off look grear
04-23-2023, 10:54 AM | #249 |
04-23-2023, 11:44 AM | #250 |
Very well documented and a testament to patience. Knowing how much documenting a project takes, your effort is appreciated.
