Old 08-11-2011, 03:57 PM   #226
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Project "Vertically Challenged"
I used RP, BUT, not break in oil. I talked to Jegs tech and they said I need break in oil for new cam...I was given wrong info when I did this last cam. I was told break in oil is not needed if just doing a cam replacement...WRONG.
This time, I'm putting in a mild "Hotrod" lope cam.
70k52wd is offline   Reply With Quote
Old 08-11-2011, 11:42 PM   #227
creepdogg
I too once wasted my cam in my 327, solid lifters that constantly required adjustment, let a buddy borrow it, he tightened them down to hard I think, kept to much pressure on lobes, smoked the cam. Took out at least 5 lobes if I recall. Good luck man
creepdogg is offline   Reply With Quote
Old 08-12-2011, 10:54 AM   #228
70k52wd
Blaze-Air
70k52wd's Avatar
Just checked the studs on the new heads. One stud is pulled up about 1/4in, and one got boogered up from the rocker sliding off.
So, maybe the cam is ok, BUT, if I got to start from scratch again, another new cam will go in, screw in studs and guide plates.
First off I will have my old heads flow tested, see where I'm at with those heads. If they are ok and cheaper to freshen up than doing screw in studs on the new heads I may go back to them.
So I'm back at the starting line with this truck.
Old 08-18-2011, 09:48 PM   #229
jeffg1010
jeffg1010's Avatar
I just ran across your thread. That's one awesome Blazer. I love seeing Blazers nearby...one of these days I will be in the market!
I am in the Charlotte area, so if you guys come down for Good Guys, let me know. I went last year and it was a great time. I'd love to see this thing in person.
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 08-31-2011, 09:55 AM   #230
70k52wd
Blaze-Air
70k52wd's Avatar
It runs again The cam is fine.
And I learned the difference between old heads and new replacement heads
Now I need to find some new a/c lines. Mine ruptured when the compressor had been moved to many times. Two steps forward, one step back.
Old 08-31-2011, 10:30 AM   #231
lolife99
67-72 parts collector,…
lolife99's Avatar
Glad you got it fixed!
What was the actual problem?
What did you do to fix it?
Keith
Convert to disc brakes.
Old 08-31-2011, 11:07 AM   #232
70k52wd
Blaze-Air
70k52wd's Avatar
The new heads require self aligning rockers. Look at your crate, it has round push rod guides. The old heads have slot guides.
I had to re-stud 2 studs, new rockers, that's it.
Old 08-31-2011, 02:13 PM   #233
VA72C10
VA72C10
VA72C10's Avatar
cool!!!
sorry to hear about the a/c lines
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-06-2011, 06:37 PM   #234
70k52wd
Blaze-Air
70k52wd's Avatar
Well, after 6months of no internet we finally have it again...It took 10yrs of negotiations before a provider would commit to bringing service to our community...BUT i won't go into the politics involved...SOOO, now i'm back online and itching to play catch up with all my forum buds. I'll start with some pics from the last rat rod show I went to, a lot of really nice cars were present, but here are just a few...
And while I'm at it, here are a few pics I took just this afternoon of the Blazer with a little fall colors...
ENJOY!!!
Old 11-06-2011, 07:12 PM   #235
VA72C10
VA72C10
VA72C10's Avatar
Glad you're back on!
Old 11-06-2011, 07:19 PM   #236
VA72C10
VA72C10
VA72C10's Avatar
Don't worry....I've been posting enough for both of us
Cool pics of the show. Thanks for sharing!
I've seen several of those but there were many others I hadn't seen. Did you check out the writing on the back of the truck with the Jetson's license plate? I have it saved in a pic somewhere if I remember that truck correctly.
Blazer is looking amazing as usual!
Old 11-06-2011, 09:14 PM   #237
lolife99
lolife99's Avatar
Great pics.
Glad to see you back.
Keith
Old 11-06-2011, 09:28 PM   #238
jeffg1010
jeffg1010's Avatar
man... love that Blazer.
Jeff
Old 11-06-2011, 10:01 PM   #239
70k52wd
Blaze-Air
70k52wd's Avatar
Thanks...
I thought I took more than one pic of the Jetsons truck, it had some cool body mods all over it. I loved the tow truck...
Great pics.
I FEEL SO ALIVE!!!
Much thanks...
Old 11-06-2011, 10:07 PM   #240
litew8
litew8's Avatar
70k5, it isn't a roller cam you're using is it? About ready to fire mine, curious.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 11-06-2011, 10:21 PM   #241
70k52wd
Blaze-Air
70k52wd's Avatar
Flat tappet...The cam was fine as it turned out, it was pulled heads studs that gave my trouble, on new GM heads no doubt...my bad because i needed self aligning rockers with the new heads...I did not know that
Old 11-06-2011, 10:45 PM   #242
litew8
litew8's Avatar
Ok cool. I'm learning new things too. And I've read break-in oil for tappet cam.
There is a sticky thread devoted to it. Here's the link - http://67-72chevytrucks.com/vboard/s...d.php?t=381780
