Old 10-07-2015, 07:48 PM   #226
jojo
printing is my trade
jojo's Avatar
Re: Jojo's '70 Stepper
My guess is timing , vacuum leak, or carb.
Originally Posted by mcbassin View Post
What you're going to want to do, is install an LS motor
Just kidding.....
As Bill said, check for the easy stuff. Vacuum leaks, and timing. You should have hard start problems if the timing is out.
When the plugs fouled, was it oil fouled or gas?
If it's gas your carb may be dumping too much gas in there.
If it's oil, well you know that's not good.
Seriously, the LS style engine I put in my truck was the best investment I made. I did mine on the super cheap using craigslist for the motor and trans. there's a wealth of knowledge on this site to answer any question you may have.
Originally Posted by my67chevytruck View Post
nice progress. are you running ported Vacuum, or Manifold Vacuum? have you checked the idle speed setting?
Sorry guys, I'm not receiving notifications from the forum thats why I'm not responding quickly. I appreciate ya'lls advice.
I wish I could do the ls motor, but I don't have time or money. LOL
It's not oil since the plugs are dry, so I've tried a couple things since. I readjusted the carb and played with the timing. The timing marker is not where it should be on the balancer so my first adjustment was no good. So I've had to put it back where it was originally and advance it some from there. I added new plugs again. Also, I got too far advanced and got some pinging on the test drive so I backed off some. Also I reduced the idle mixture to run more lean. Hopefully theres some balance now.
Oh and I did switch which port I was getting the vacuum for the advance, I believe its manifold now but not sure. Lol With a vacuum gauge hooked up, it's showing that I'm getting more vacuum than from the old port.
With everything the way it is, my plan was to test drive for a week or so and check the plugs. But, the brakes are really acting up and I have all my parts in to do the front discs. So I've begun that process.
I'm attaching a picture with a question:
Theres still some ball joint left in the lower control arm. How do I get that one out? And how do I get the upper one out?
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 10-08-2015, 11:26 AM   #227
my67chevytruck
Under Construction
my67chevytruck's Avatar
IIRC with the UCA's there are Rivets if they are original, you can grind the rivet head down, and punch the shaft out, the replacements should come with new hardware to bolt them up . The LCA you have to press the ball joint out, and press a new one in.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-08-2015, 02:36 PM   #228
mcbassin
Still Learning
mcbassin's Avatar
Like Heath said you will need to press the lower ball joints out. Go to autozone and pick up the C-clamp style press. If you have an impact wrench it makes easy work of the ball joint swap.
Go ahead and spend the extra money and buy Moog USA ball joints
mcbassin is offline   Reply With Quote
Old 11-16-2015, 06:39 PM   #229
dfwright
dfwright's Avatar
I could have sworn I was subscribed to your thread, Jojo, since I especially like watching the San Antonio builds, lol! I guess I wasn't, since I had lost your thread. I should be subbed now! Good work!
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 11-17-2015, 10:24 AM   #230
jojo
jojo's Avatar
Thanks man! Yeah we San Antonio guys gotta support each other!
Old 11-20-2015, 05:06 PM   #231
jojo
jojo's Avatar
Problems with the install of the disc brake system.
1. I broke the booster by depressing the pedal to screw it in under the dash. See pictures. Not sure if its fixable and hoping y'all can advise.
2. Some time back I had decided to go a different route and not lower the suspension, so I went for stock height spindles. Well performance online sent me drop spindles anyways. All spindles look the same to me, so I installed them. After getting it back on the ground, it seems as though I ended up with drop spindles after all. I guess I'll leave it that way and go back to my original plan (maybe get some springs for the back.
Pictures rotated sorry
Old 11-20-2015, 05:09 PM   #232
jojo
jojo's Avatar
I posted in the main forum for input on the booster problem.
Old 11-20-2015, 06:55 PM   #233
Hope someone can answer you about the booster issue. The drop is mild and looks pretty good. Still a truck with clearance, but no nose bleed.
Old 12-05-2015, 04:37 PM   #234
jojo
jojo's Avatar
Thank you! I decided to go ahead and get the springs for the back when I get some extra money. Probably 4" to even it out some. It was in my original plans anyways.
Old 12-05-2015, 04:43 PM   #235
jojo
jojo's Avatar
So I ended up getting another booster from auto zone. I'm gonna see if it is compatible with the performance online master cylinder. It all hooks up together. I just need to get it on the road to test.
I got the front end stuff installed (no pics of the progress). It was a hassle with the stupid copper washers for the banjo bolts on the calipers. The ones that shipped didn't create a working seal so I kept leaking brake fluid. I ended up getting a kit with a bunch of different sized copper washers from summit. One of the sizes worked for me. After all that, we tried to bleed the system and now I have a leaky cylinder out back (ugh). Next step, getting that fixed and I hope to be testing out the system by next weekend.
