Old 11-15-2013, 02:38 PM   #226
nebdrummer
nebdrummer's Avatar
Re: my 50 build... why not?
Almost done with all the kitchen remodeling. Just in time for the new snail!
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 11-15-2013, 03:55 PM   #227
_Ogre
_Ogre's Avatar
i like fabbing up turbo installs, refresh me on what motor your using? efi or carb?
shop air compressor timer
Old 11-15-2013, 08:23 PM   #228
nebdrummer
nebdrummer's Avatar
Pretty much a stock lq4 6.0. Custom cam, worked holley hp by c&s, and e85. Probably won't be over 15-17 lbs non intercooled. I will eventually build a forged 40x block, but this will do the trick for now. Hoping to break 9's on the first track outing. *nail biter*
Old 12-02-2013, 08:58 PM   #229
vht
We need some updates!!
vht is offline   Reply With Quote
Old 12-04-2013, 12:18 AM   #230
nebdrummer
nebdrummer's Avatar
I wish I had some for ya. Just working on the house yet. Still need baseboard and molding. Then, switch a few outlets and switches, then I should be sanding in the garage.
Old 12-04-2013, 08:48 PM   #231
vht
Base board is over rated. Work on the truck. I'm thinking 5.3 in mine, unless a 6.0 comes along. Turbo would be nice too. Great job, going to be a nice ride.
Old 12-06-2013, 12:39 AM   #232
_Ogre
_Ogre's Avatar
it's usually my wife that wants the base board finished or the kitchen remodeled
maybe nebdrummer likes being married too
Old 12-06-2013, 07:44 PM   #233
vht
Talking Re: my 50 build... why not?
Keeping the wife happy is a bigger job than building a truck sometimes!
Old 02-14-2014, 01:04 AM   #234
nebdrummer
nebdrummer's Avatar
Box is about ready for primer. Hopefully this weekend I will be able to get it, the running boards, and splash aprons primed, blocked, and reprimed. Then in the next couple months, everything from the cowls to the tailgate will be DONE!
Set of wisecos.
S718 wrist pin upgrade
Main studs
Lunati h beams with arp 2000s
I sent the Frankenstein carb to Kevin at CSU.
Also, sent the converter back to freakshow to get re stalled. I had it set up for all motor. Now I'm going all out or nothing.
Lil johns big motor purchase was made on Monday. That has head studs, ls9 gaskets, custom cam, springs, pushrods, and ect, ls7 lifters, trays, melling oil pump, rocker arm trunion upgrade, timing chain, and jgs 60mm bov. Still have to get 2 40 mm jgs gates, boost controller, driveshaft, flex plate, balancer, and probably all the nickel and diming **** that comes with this. It's pretty crazy to see all these high quality parts. I've never done anything even close to this, so it should be fun.
Old 02-14-2014, 01:09 AM   #235
99 to Life
99 to Life's Avatar
dang, nice grip of expensive parts. should be killer.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-15-2014, 09:05 AM   #236
Bubba54
Nebdrummer, raised bed looks great. Motor sounds like it will be a monster. Maybe another garage burnout will be in order.
I’ve purchased what looks to be the same wheel tubs for my raised bed. Looks like the two wheel tubs are different in the pics. Just wondering what modifications you did to it and how?
Thanks Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647
Bubba54 is offline   Reply With Quote
Old 02-16-2014, 09:59 PM   #237
nebdrummer
nebdrummer's Avatar
Thanks guys. Yes, I could probably work another garage burnout video in the mix. Lol
Bubba, the two tubs actually started as one fender. I bought it from tractor supply company. It was their biggest one for like $40. I cut it directly down the center and lucked out. It was an absolute perfect fit minus a tiny bit of trimming. So I cut it in half, then I took it to a harbor freight shrinker/stretcher to stretch the fenders out to the length I needed. I think it was right at 23". Then I just cut a piece to fill in the inside and welded everything together..
Box has the first coat of primer on it. I filled the stake pocket holes, filled some holes, fixed a few cracks in the running boards, and did a bunch of seam sealing. Going to block and reprime this week.
Old 03-01-2014, 01:01 AM   #238
nebdrummer
nebdrummer's Avatar
Box, splash aprons, and runningboards are all blocked and reprimed along with a new tailgate. Hopefully a week or so before color is on it. But, with my luck lately, probably not.
Motor is at the machine shop, so a few weeks, I should have that back for assembly. If it goes as planned, I will have the back half of the pickup stuff painted and mounted so I can quickly sand and buff all the parts before the motor gets back. Hen it's all nice and clean when it's in the garage. I got my pair of waste gates and started fabbing up the turbo mount/hot piping with the v-bands. A good friend of mine welds for a stainless pipe company and he can get his hands on a whole bunch of stainless, so my hot side will all be done out of that. He will be coming down and tigging it all together for me. Only a matter of time now! First carshow I wanna try and get to is in Columbus Nebraska on May 23-25th. I think it will be pretty tough to get it done, but maybe. If not, then my eyes are set on north plate Nebraska in September. I don't think I will be comfortable driving it this early to the Minnesota show.
Old 03-20-2014, 06:08 PM   #239
nebdrummer
nebdrummer's Avatar
Carb should be back from csu this week or beginning of next.
Converter will be here tomorrow.
motor might be done this week yet as well. If not, beginning of next week.
Did some wet sanding and buffing on the lower half of the back of the cab.
Started sanding on the rest.
Aaaand and box, running boards, splash aprons, and tailgate are painted.
Old 03-20-2014, 09:39 PM   #240
*Kenny
looking nice and smooth!
*Kenny is offline   Reply With Quote
Old 03-21-2014, 01:52 AM   #241
nebdrummer
nebdrummer's Avatar
Thanks!
Old 03-28-2014, 02:25 PM   #242
nebdrummer
nebdrummer's Avatar
I plan on getting all the wet sanding and buffing done on the box, cab, and doors this weekend. Then I can throw on the rear fenders and running boards. Then I'll give the bed wood a good sanding. Stain it a bit darker, and throw that all in.
Motor is done for the most part. Waiting in some money for a balancer, flex plate, solid moor and trans mounts, and valley gasket. Then I can throw the engine and trans in. I found a tight spot to tuck the alternator up in. I swiped an alternator off a newer Buick with the long mounting ear. It lines up perfect with a timing cover bolt. Then I just have to make a small upper and lower mount off the side of the block.
Old 03-29-2014, 10:51 AM   #243
99 to Life
99 to Life's Avatar
looking killer man, can't wait to see that beast tearing up the streets.
Old 04-24-2014, 01:32 AM   #244
superfly
Well I went and drove from the Canadian Border to Middle of Nebraska And Guess who I meet up with???????
Yes Neb Drummer, Thanks for the Hospitality it was great meeting you and the Boss. Hope Her Shoulder stays in place LOL..
You have a awesome ride there and I am Stoked to have seen it. Next time we will go eat and tear up the town.
Jaime
superfly is offline   Reply With Quote
Old 04-26-2014, 06:06 PM   #245
nebdrummer
nebdrummer's Avatar
No problem Jamie! It was great to meet you. And yes, I will show you a proper burnout. Lol.
Old 04-26-2014, 06:18 PM   #246
FarmerSid
FarmerSid's Avatar
Those rear meats look awesome under there! Nice job!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 04-27-2014, 09:07 PM   #247
superfly
make it page 11
Old 05-02-2014, 08:46 PM   #248
nebdrummer
nebdrummer's Avatar
Not a whole lot to update on this, but I got all the glass in today, power steering is done, bed wood is sanded back down for the new stain and varnish, and inner fenders are trimmed up for the a arms and power steering hoses. I'm still unsure what I'm going to do for the wood color.
Well, we got the motor and trans out in last night. And found that the alternator I have won't work how I had planned. I need to see if I can borrow a small 93mm denso unit for mock up. Then, I found that the passenger truck manifold won't clear the frame. So now, a list of things I need.
Random assortment of lsX passenger side manifolds to find one that fits, or a custom set of headers will be in order.
93mm denso alternator,
F body power steering setup for mockup to see if that will even work.
Edelbrocks victor series 8895 water pump. Clockwise rotation
eBay NASCAR pulley to fit the water pump
Jegs sfi f body balancer
Balancer installer/remover
64.25" driveshaft
Catch can
Pre and post fuel fittings
And a ****load of AN fuel fittings and hose.
I found out that speedway doesn't price match. So I got the tci flexplate elsewhere for right at $100 cheaper from summit.
While I was clocking the housings on the turbo, I figured I would show off some billet love.
Old 05-02-2014, 11:38 PM   #249
99 to Life
99 to Life's Avatar
looking real good, can't wait to see this sucker run the street and strip.
Old 06-02-2014, 01:47 AM   #250
superfly
tag
