03-06-2011, 10:41 AM | #226 |
Re: My 84 CC Dually mod thread - there will be plenty of pics
Very cool!
Thanks for the info Posted via Mobile Device
CHEVY ONLY |
03-06-2011, 06:31 PM | #227 |
subscribed...loving this build.
Guess we are waiting on the wheels
Best Regards, Leon 1970 C/10 LWB Cummins Turbo - Build in Progress Many other toys as well... |
03-06-2011, 06:49 PM | #228 |
It followed me home?
I like it!
Can you please hurry up and put the wheels on, I am waiting to order a set for mine and would like to see how they look on a square body first
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
03-06-2011, 06:51 PM | #229 |
x2
03-06-2011, 10:11 PM | #230 |
Sorry to have to keep you guys waiting but it's probably going to be a while before the wheels get bought. I need to get the engine back together and I just yanked the 400 automatic out today to have it rebuilt. I am going to try and order the wheels by the end or april.
Thanks for all the great comments! Posted via Mobile Device
-------------------------------------------------------- 1984 CC Dually - 454 - TH400 - Western Hauler Edition Big plans are coming! My build thread HERE |
03-07-2011, 02:27 PM | #231 | |
C35 Crew Dually
but yes lets see this beast done.
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
03-13-2011, 07:10 PM | #232 |
Tore the dash apart today to get a light bulb count so I can replace with LEDs. I also needed to check and make sure my water temp connection was still good as the gauge never worked when I bought the truck. The gauge has good power/ground and sender connection so it must just be a bad gauge, ordered a new one from LMC. Will post some pics once I put the dash back together with the LEDs.
Also removed both the drivers side door panels to free up some sticky power window motors. You would be surprised what a little bit of WD-40 will do Oh yeah also started to mount my new mirrors. Waiting for my buddy to bring home his nutsert tool so I can finish up that little project. Will also post pics when done! Posted via Mobile Device
03-13-2011, 09:46 PM | #233 |
LED lights through out I love it. You will be able to everything now.
03-21-2011, 08:41 PM | #234 |
The new LED's in the dash. While I have it apart I am going to custom fit a 2 1/16 tach gauge in where the clock is. Plan is for it to look almost factory by the time it's done.
03-21-2011, 08:59 PM | #235 |
Wow is that ever nice and bright
03-22-2011, 09:01 AM | #236 |
damn! what kind of LEDs did you use? look extremely bright!
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
03-22-2011, 10:09 AM | #237 |
C35 Crew Dually
Looks good but we need a NIGHT pic!
03-22-2011, 04:03 PM | #238 |
http://www.superbrightleds.com/cgi-b...FWLED-xHP5.htm
03-22-2011, 04:04 PM | #239 |
Sorry, no night pic until the tach mod is done! Hopefully this weekend!
03-22-2011, 04:08 PM | #240 |
Thanks for the link to the lights. I will be purchasing them for my truck. How many in total are in the dash, and elsewhere you put them?
03-22-2011, 05:19 PM | #241 |
That real bright...
03-24-2011, 05:28 PM | #242 |
This tach mod is going to be easier then I thought! Already got it roughed in and I think it looks right at home! Much more functional then the clock.
03-24-2011, 05:33 PM | #243 |
Nice!
I wanna do exactly the same! how is the view from behind the wheel?
03-24-2011, 05:38 PM | #244 |
That looks good..if you painted tha neddles all to match & blacked over tha autometer, it would look totaly stock
03-27-2011, 08:05 PM | #245 |
Tach mod is done! Dash is back together and a night shot as promised.
03-27-2011, 08:18 PM | #246 |
C35 Crew Dually
Looks awsome! can see everything alot better. i need to do this mod lol.
03-27-2011, 08:35 PM | #247 |
Awsome. That will be an inspiration to everone on here. Thats nice and bright. Good job. I'm going to be ordering some real soon.
03-29-2011, 02:33 AM | #248 |
For the gauge cluster, was that a LED replacement bulb or did you purchase LED's and solder them in with resistors? If it was a replacement bulb from superbright would you mind posting the part number you ordered, they look great vs. the dim and poorly illuminating stocks. Also, on the tail lamp leds were they plug n play or did you have to alter the harness or add resistors? I have heard when put in without resistors they cause the fast blink in the cluster like a bulb is out elsewhere in the truck. Thanks for any info you can share
03-29-2011, 04:31 PM | #249 | |
The tails are not truly plug and play as you do need to remove the stock bulb sockets and wire the LEDs in. I suppose you could leave the sockets and just remove the bulbs and then splice into the existing wires but I wanted the clean setup. You can buy the LED tails below. As far as the flash rate, the documentation that came with the tails said you do not need to replace the flasher or add resistors as they must already be built into the circuit boards but in my case where I converted every light in the truck to LED I had no choice and opted to go with a no load plug & play flasher. http://www.jcwhitney.com/pickup-truc...0d16352y1984j1 Posted via Mobile Device
03-29-2011, 04:47 PM | #250 | |
Posted via Mobile Device |
