11-21-2020, 08:53 AM | #226 |
Moderator
Re: My caster mod (with pictures)
Check out this page - https://www.suspension.com/universal-bump-stops.asp
11-21-2020, 11:54 AM | #227 |
Post Whore
Thank you.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-05-2021, 11:27 AM | #228 |
Thanks everyone for all these reply's and the great write up. I am starting my 67 drop and want to keep my stock spindles due to a disc conversion and this will be great. Does anyone know what the aliening specs are to be after this mod?
05-05-2021, 04:52 PM | #229 | |
OE called for Zero to POS .5 Camber. I target NEG .5 Camber. For caster, I request as much as possible w/o impacting my Camber target. These C10's didn't have much Caster to begin with. If you can get 5° that's pretty decent (I was able to yield 6.9/7.4 for reference). Toe was pretty close to OE. The larger/wider the foot-print, there might be need to adjust to account for the increased contact patch.
05-05-2021, 08:58 PM | #230 | |
05-18-2021, 11:10 AM | #231 |
Post Whore
I posted my alignment specifications on post 214.
04-15-2022, 01:26 PM | #232 |
I know this is an old thread but I did this mod to my 67 and I have severe tire scrub when I turn, is it normal ?
Posted via Mobile Device |
04-15-2022, 02:21 PM | #233 | |
What are the final alignment specs?
04-15-2022, 04:06 PM | #234 |
Not sure on caster need to find a shop I trust. Set at home Toe is 1/8" camber is close to 0. Drives good just when I back out of a parking spot and turn the wheels hard one of them will scrub bad (as in tear up grass or leave a black mark) they have a different turning radius from each other ?
04-15-2022, 04:59 PM | #235 | |
I have 6.9/7.4 on my dually. Going from reverse to forward there is a shift but once you're moving it's not an issue. Toe needs to be dialed in as well.
04-15-2022, 06:18 PM | #236 | |
Post Whore
As previously recommended get thy truck to the alignment shop. Now it is possible to install the upper control arms on the wrong sides and to put the centerlink on backwards. I have no idea how much of the front suspension you worked on but these are easy things to check before going to the alignment shop and trust me they are much cheaper to rectify at home, rather than when your truck is up on the rack. Good luck and please share your findings.
04-15-2022, 07:27 PM | #237 |
It was frame up build, all new components. 2" or 2-1/2 spindles (don't remember) 1" springs etc.
04-15-2022, 09:31 PM | #238 |
Ahhh.... Definitely verify the a-arms are on the correct sides & the Center-Link isn't backwards. I bet you're ok on the Center-Link because there's typically tie-rod to x-member interference when that occurs.
04-16-2022, 01:12 AM | #239 |
how does one know if the upper control arms are backwards?
04-16-2022, 10:32 AM | #240 |
Yeah, don't be like me and try to get it aligned with the UCAs on backwards. It won't work well.
Fist picture shows them on backwards. See how there's more angle between the UCA and the top of the spindle? Second picture shows them on the correct side. Look at how the UCA and top of the spindle are sitting more parallel. You want to have the bump stop towards the rear of the truck.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-16-2022, 10:45 AM | #241 |
Yes I see, the spindle is more in line with the front UCA mounting bolt too.
04-16-2022, 12:39 PM | #242 |
Yes A-arms on correct side, as my helper double checked all my work on the truck.
http://www.67-72chevytrucks.com/vboa...1&d=1650127136 |
12-29-2022, 08:43 AM | #243 |
So if I use tubular control arms for my 67 build I will not have this caster issue, is that correct?
12-29-2022, 09:27 AM | #244 | |
Some tubular arms are nothing more than a copy of the OE stamped steel arm while others might refine some of the geometry by making changes.
