Old 08-29-2016, 02:37 AM   #226
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: Introduction and 2wd Blazer in progress
What is the drop on this blazer. I'm about to convert my blazer to 2wd and I'm trying to decide how low to go. I want to run 22's
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 08-29-2016, 12:36 PM   #227
gclark1
gclark1's Avatar
I started with 2.5" Western Chassis spindles and 2" lowered coils. After that, I cut an ever so slight amount from each until I dialed it in exactly how I wanted it (took me a few tries to get it right). The rear was just a remove the overload and take 3" out. Take the leaf packs to a spring shop and they can de-arch them for you. Converting from a 4wd, your specs will be different though. You just have to play with it and start somewhere and then adjust to your liking. Time and patience...
gclark1 is offline   Reply With Quote
Old 08-30-2016, 12:05 AM   #228
jbristo67
jbristo67's Avatar
From all of the research I've done once I put the 2 wheel drive suspension under it it should be stock 2 wheel drive height. The more research I do the more I come to the conclusion that the frames are identical outside of the front not having the holes for the 2 wheel drive crossmember
2011 Nissan Armada
Old 09-19-2016, 02:28 PM   #229
68Timber
I know the pieces fit
68Timber's Avatar
Just got my Brothers end of summer sale catalog - congrats on the cover!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-19-2018, 11:57 AM   #230
made2drag
made2drag's Avatar
Great build...it looks amazing!
I see you went with a 17/18 combo, are those 18x8's in the rear? What size tires in the rear? Thanks
made2drag is offline   Reply With Quote
