Old 10-30-2013, 11:37 PM   #226
mechanixman
mechanixman's Avatar
Re: 1952 1 Ton Rebuild
thanks
I forgot to post some pictures of it primed.
I thought I'd put the door and fender in the right place to see if what I did actually made a difference.
mechanixman is offline   Reply With Quote
Old 10-31-2013, 06:26 AM   #227
coralhead
coralhead's Avatar
Originally Posted by mechanixman View Post
Thanks guys,
John,
I'll have to look for one of those. I was using 100 before it fully cured, and it seemed to clean it up enough.
have you used those foam sanding pads?
I picked some up at menards, they come in a 300 grit range, and soak up water like a sponge so it's pretty easy to wet sand.
I've been using them just before I shoot the primer. They seem to work pretty well.
I have used the foam blocks with luck I also have used a piece of hard flat rubber as a backing block for sandpaper as well. The use of icing to finish up the final filling/sanding of the area will really help in getting it smoothed out. It is a bit pricy but you only use a small amount to fill in the final sanding scratches. It sands out really nice and sands easily as well.
Good Luck and pay attention to the details. I remember you saying that you wanted to get this done over spring break
Keep up the good work.
coralhead is offline   Reply With Quote
Old 11-03-2013, 11:12 PM   #228
mechanixman
I got some POR 15 on the floor pan.
Made a side by side picture to see what the floor looked like when i bought it, to now. Just for fun.
-Nick
Projects:
1952 Chevy 1 ton = The Build page
Old 11-03-2013, 11:26 PM   #229
greasy58
yeeeeeaaahhhh that's gonna be one sweeeet truck man!!!
greasy58 is offline   Reply With Quote
Old 11-04-2013, 12:17 AM   #230
mechanixman
Ha ha thanks brother
Yeah that's the hope, plan, and goal.
Old 11-05-2013, 02:53 AM   #231
greasy58
looks like you are well on your way with this one, keep up the good work. I looked through your whole thread its cool to see how things are coming along with your build
Old 11-12-2013, 12:07 AM   #232
mechanixman
Thanks Greasy
I started working the back half of the cab over the past several days.
There were a couple small dents in the passenger side. Instead of pounding them out, the PO just filled them in with bondo. I sanded took off the top 2 layers of paint, and pounded out almost all the dents, and sanded a little more. I just wanted to take a picture of how ugly it looked before I made it one color.
Next step was the cab corner that was more rusted than I originally thought. When we first got the truck you couldn't see that rusted out line in the corner. When I rolled the cab on it's end to put a dolly under it, I cracked the bondo and found this. I cut out the corner this morning.
Old 11-12-2013, 12:17 AM   #233
mechanixman
My dad and I were looking at the old panel, and discovered it was actually patched with another truck's corner. The arrows are pointing to some of the seams the previous owner made fixing this corner.
I think it's funny that this isn't the truck's second, but third chance on life. (and hopefully not the last)
I got the new corner clamped and almost welded up. I'll finish tomorrow.
These Chinese-made aftermarket parts are kinda crap. the flange that mounts the door jamb was about an inch too long, and the flange on the outside of the cab wasn't long enough. (where small clamp is in the last photo.) But these were just minor inconveniences. I got them sorted in about a half an hour.
Just 207 days till Power Tour 2014.
It'll be here before I know it...
Happy Veterans day.
Old 11-12-2013, 07:34 PM   #234
coralhead
coralhead's Avatar
Nick, Looking at your last photo of your weld, you need a short skip weld along the entire seam and then go back and fill in the spaces. Don't try to weld it all at one time. Youy will get the metal too hot and will have trouble with it pulling. I used a bunch of short welds spread out to keep the deformation down.
You progress is looking good and stay patient.
Old 11-12-2013, 09:22 PM   #235
Katrina/10
Katrina/10's Avatar
What kind of fasteners are those, and where can I get them? Thanks
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 11-12-2013, 09:51 PM   #236
coralhead
coralhead's Avatar
I got mine at harbor freight. Look in the welding/autobody section. They are really cheap (construction as well as price) but will last for a few projects if you are not too rough on them. They are called butt weld clamps I believe. Used correctly they set a small gap between the two pieces being welded.
Old 11-12-2013, 11:12 PM   #237
mechanixman
Thanks, I actually was doing a bunch of short welds, but when I filled in between. Instead of the whle seam, I tacked it in place, but skip welded between each clamp.
Coralhead is correct, you can get a set of butt weld clamps at harbor freight. A set of 8 clamps for $8.
Old 11-13-2013, 07:23 AM   #238
coralhead
coralhead's Avatar
Nick, on a side note. Sometimes you don't need to use the whole patch panel to make the repair. My corners were the same shape as yours but I only used the amount of patch needed. You can see that by cutting the upper piece of patch off you don't have the long verticle weld to smooth out. As a plus you wll have a nice piece of flat metal to fill in other places as needed.
Old 11-13-2013, 09:05 AM   #239
Katrina/10
Katrina/10's Avatar
Thank you, I will go get some!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 11-13-2013, 12:25 PM   #240
FarmerSid
FarmerSid's Avatar
I tried those clamps and don't like them. Leaves too much gap.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 11-20-2013, 01:56 PM   #241
maxdog51
maxdog51's Avatar
I just made 6 of them. They worked great for me when I chopped the top. By the way, you guys are making some excellent strides. keep up the good work and you'll have her on the road sooner rather than later.
maxdog51 is offline   Reply With Quote
Old 11-22-2013, 12:01 AM   #242
mechanixman
One step closer to paint!
-Nick
Projects:
Old 11-22-2013, 09:17 AM   #243
Russell Ashley
Russell Ashley's Avatar
I've used those clamps with some success but getting the bars out of after you loosen them up can be a problem.
Mechanixman, you are doing some nice work. Keep it up.
Russell Ashley is offline   Reply With Quote
Old 12-05-2013, 03:59 PM   #244
Sam03
Sam03's Avatar
Great work dude! Keep it up and keep sharing the progress!
Sam03 is offline   Reply With Quote
Old 12-05-2013, 04:22 PM   #245
Daze57
Daze57's Avatar
nice work
Daze57 is offline   Reply With Quote
Old 12-07-2013, 02:01 PM   #246
mechanixman
Thanks guys
Not too much to report. I've wet sanded the cab, and I'm just waiting on an opportune time to try painting it. We bought a kerosene heater that should be more than warm enough to heat the garage, but it's still freezing in there.
I originally planned on using the infamous purple HF hvlp guns. But I may have found a paint booth I can rent out on a sunday for a $100.
So we'll see how that goes. My only problem is trying to find a way to get it there.
-Nick
Projects:
Old 12-08-2013, 04:47 AM   #247
dmack91
dmack91's Avatar
My skills are minimal (first try at paint and body work), but I found this Devilbiss gun worked fine for what I needed for about the same price as the HF gun.
http://www.ebay.com/itm/Devilbiss-Gr...item1e833a7374
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 12-08-2013, 11:37 AM   #248
Bubba54
Another thought on the clamps. As FarmerSid has stated, they can leave a bit of a gap. You can fit your patch tight and mark where you will place your clamps, then open that spot a little bigger. If you find that the patch is too tight after tacking, you can run a body saw blade to get a gap.
Here is a pic where the clamp area has a bigger gap.
mechanixman, Nice progress on the build. Keep up the good work.
Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647
Bubba54 is offline   Reply With Quote
Old 12-15-2013, 12:01 AM   #249
mechanixman
Thanks Shawn
It's been quite a while since I have posted anything. (A lot longer than I thought it was.) So I figured it'd be a good time to do a long update.
My cousin bought this 1.5 ton a couple months before I bought mine.
It's a 1953 4100
Original 235 sm420 with PTO, and a working dump bed.
I finally got a picture of it last Thanksgiving.
Next three pictures are of the final metal work before I have it completely ready for paint.
I've tried using a couple (different) spot welders to get finish off that section in the three pictures, but none of them actually welded them together, so I eventually decided to get off my lazy butt and drill/weld the inner and outer cowl panels together. Some finish grinding, and you almost can't tell.
Old 12-15-2013, 12:19 AM   #250
mechanixman
So all this took place today:
First picture is how the frame sat for the past couple months. I decided it was time to finally bring it in the garage so I can actually work on it during the winter season. Only problem was that if I wanted to realistically work on it, I'd have to put it in the garage nose first; something this truck has never done before. So I had to do a three point turn in the street by myself. (Something I really wouldn't recommend, it took me 5 hours between shoveling and pushing)
Dad and I got the cab on the frame in a couple minutes, not a big deal at all. We thought it would be a good time to see how the motor fit in the engine compartment. And I must say I'm pleased. It's low enough I have a better center of gravity, it's just far back enough that it doesn't hit the radiator, and far forward enough that I don't need to touch the firewall or floor.
The only problem I'll have once this thing is put together, I won't be able to reach the 3 or 5 cylinder spark plugs do to the manifold and the steering box.
The shifting location of the T-5 is just where I expected it to be, not too inconvenient in my opinion. Any thoughts on it?
How would you guys have done it? Right now I have about an inch from the top of the shifting plate to the bottom of the cab, and I haven't put in the cab mounts yet.
The last picture was the last one I took tonight, I like to think the truck looks rather sinister from that angle.
-Nick
Projects:
