Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 12-28-2011, 11:09 AM   #226
altownsend
Disc Brake Upgrade Thread 1960 3/4 Ton C-10
1960 C-10 3/4 ton Step side
4 wheel drum brakes
I did not see options for the 1960. I want to get the least expensive conversion done for front and rear disc brakes, power steering, and power brakes. I plan to install disc brakes in the rear at a later time, so I want to convert with that in mine.
For now, I want to convert to front disc brakes. I need to know what year donor vehicles' parts will bolt on for the conversion. Please advise.
I want to go with power steering and power brakes on this 1960. Please advise what year donor vehicles will bolt on. The master cylinder on the 1960 has 3 bolts mounting it to the firewall. I notice that all of the other master cylinders have 4 bolts mounting the master cylinder to the firewall. Please advise a solution.
altownsend is offline
Old 12-28-2011, 11:16 AM   #227
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Disc Brake Upgrade Thread 1960 3/4 Ton C-10
4 wheel drum brakes
The only bolt on disc brake spindle for your 60-62 balljoints and outer tie rods,... are aftermarket conversion spindles for the 60-62 trucks.
Performance online sells them for $229.00 every day.
They also have 10% off until the end of the year.
Look here:
http://www.performanceonline.com/196...dle-Set-16683/
Keith
Convert to disc brakes.
lolife99 is offline
Old 12-28-2011, 11:54 AM   #228
altownsend
Re: Disc Brake Upgrade Reference Thread
Thanks, Keith,
Now, about the hub, caliper, and rotors. Please advise if I can use the existing hubs. Also, what year caliper can I get from the salvage yard? I can buy a new rotor from the parts house. What year do I ask for. I will go with the 6-lug since I have the 6-lug on the rear. Please advise - thanks
Old 12-28-2011, 01:18 PM   #229
lolife99
lolife99's Avatar
Thanks, Keith,
6-lug rotors have to be purchased from the aftermarket also.
Performance Online sells them also.
http://www.performanceonline.com/FRO...10-TRUCK-8600/
(If you want 5-lug then you can get them at your local parts house).
Just ask for 1973 1/2-ton truck parts.
These will be the required 1-1/4" rotor version to match your spindles and these aftermarket 6-lug rotors.
I would buy new calipers, bearings and brake hoses.
These parts are cheap.
Plus it's your brakes we are talking about.
Keith
lolife99 is offline
Old 12-29-2011, 01:44 AM   #230
Captainfab
60-66 Nut
You can change your entire front suspension to the '73-'87 suspension and do away with the torsion bars. It is a little more work (hole drilling) than on the '63-'66's, but it has been done by many.
I know there is a thread or two on here that describes the '60-'62 suspension swap in more detail, but I can't find it at the moment. I believe markeb01 started one of them.
I can help with the power brake conversion bracket, but I don't have a power steering adapter plate for the '60-'62's at this time.
4 wheel drum brakes
Captainfab is offline
Old 01-02-2012, 05:28 PM   #231
krazy_texan
krazy_texan's Avatar
so in a nutshell i can just pull the entire crossmember out of a 73-87 and bolt it in my 65 with maybe a few holes drilled, then if i want to keep the 6 lugs just order new rotors and call it good? cause that sounds like the easiest, fastest and cheapest route for me.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline
Old 01-03-2012, 01:50 AM   #232
Captainfab
60-66 Nut
You can do the conversion that way if you like, but it is definitely easier without an engine in place. You will have to drill one hole on each side, and elongate one hole on each side. This is a quick and easy way to do the conversion, if rebuilding toe entire front suspension in not necessary or not in the budget currently.
The disc brake upgrade can also be done by removing everything from the donor crossmember and bolting up to your existing crossmember. The later model lower control arm shaft U-bolts are larger diameter than the early ones. I recommend drilling out your crossmember and using the larger diameter U-bolts. You can also keep your existing control arms, and just change the ball joints and add the spindles, rotors, calipers, etc.
You can use the aftermarket 6 lug rotors, as long as you have the HD spindles with the 1.250" thick rotors.
Old 01-16-2012, 12:04 AM   #233
camaney
suscribe
camaney is offline
Old 01-16-2012, 12:53 PM   #234
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Well .... I started the process of sloooowly collecting parts for my conversion.
I picked up some A-arms and a center steering arm from a late 70's because I wanted rubber bushings.
I just lowered a customers '96 1500 using dropped spindles, so I now have the stock spindles as an option.
I'm thinking about reworking the lower a-arm to except the correct ball-joint.
NOTE: When looking for a-arms at a wrecking yard...find a greasy truck !!
(LOL, we found a grease free truck, surface rust, man it took all day to wrench those fasteners off...)
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline
Old 01-20-2012, 06:24 AM   #235
slick copper
slick copper's Avatar
This may have been covered already. I'm running vintage American Racing Turbine wheels (6 lug) and don't wanna give them up. If upgrading to 6 lug disc brakes will it affect my wheel backspacing? Pretty much will I be able to keep my wheels without it looking stupid? Here's a pic of my truck. Keep in mind I haven't lowered the front yet in the pic (in progress). 4 wheel drums right now.
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline
Old 01-21-2012, 01:02 AM   #236
Captainfab
60-66 Nut
When switching to front disc brakes, it does increase your track width some. I just don't remember exactly how much.......I wanna say 1-1/2". There is a brand of dropped spindle that is supposed to compensate for some of that, but there again I don't remember what brand. Hopefully someone that knows will chime in. Sorry I couldn't be more help.
Old 01-21-2012, 04:32 AM   #237
slick copper
Thanks CaptainFab! Hopefully someone can help shed some more light on this for me. Anyone???
Raymond
Old 01-21-2012, 02:46 PM   #238
Slow Build
Slow Build's Avatar
CPP Modular spindles. They are more expensive plus you need to buy their caliper mounting kit. You can't run rear dust covers with them.
According to Justin at Scotts Hot Rods in the following thread (post #74) the CPP Old School New School spindles do the same. I haven't done any research to verify this yet. CPP doesn't show these on their website and the only place I've heard about them is through this thread.
http://67-72chevytrucks.com/vboard/s...=485760&page=3
Another thread I just found.
http://67-72chevytrucks.com/vboard/s...d.php?t=485760
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 01-22-2012, 01:00 AM   #239
Captainfab
60-66 Nut
THanks for posting. I was thinking it was the CPP modulars, but wasn't positive. I did not know that there were possibly other spindles that move the wheels in.
Old 01-22-2012, 05:09 AM   #240
slick copper
Thanks Slow Build! Very helpful to know. So for what I'm talking about wanting to do the CPP modular spindles will be my best option. They will still push out my track width 3/4" on each side. But it's only that little bit and wayy less than other spindles. I think I can live with that, and looks like I can keep my wheels!
Couple more questions for you guys.
1. To run my 15" wheels will I need to run the 12" rotors or can I go with the 13"?
2. If I wanted to go 4 wheel discs (add discs in the rear) Would that affect wheel spacing and how much?
Thanks guys, sorry to be a bother. I'm sure all this has been covered before at some point. Just wanna get my facts straight for when I do all this.
Raymond
Old 01-23-2012, 02:38 AM   #241
Captainfab
60-66 Nut
With 15" wheels, you will have to stay with 12" rotors. If you convert the rear to discs, that will add 3/16"-1/4" to each side to the overall axle width.
Old 01-23-2012, 06:02 AM   #242
slick copper
Thumbs up Re: Disc Brake Upgrade Reference Thread
I can live with 12's. I'll just go with the drilled/slotted ones. And BIG thanks for all the info guys. That'll work on the rears. Guess I will upgrade to rear too that'll give me that little extra to compensate for the front.
Raymond
Old 01-24-2012, 01:11 AM   #243
Captainfab
60-66 Nut
Let me know if you are interested in one of my rear disc brake conversions.
Old 01-24-2012, 05:47 AM   #244
slick copper
I will! It'll be a little bit though. Gotta get this drop finished, and then get the tranny rebuilt. Brakes will be after that!
Raymond
Old 02-06-2012, 01:01 AM   #245
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
My 66 is a 3/4 ton, but the booster/master cylinder is from a 79 1/2 4x4.
Should I try and find a booster & master cylinder off a 3/4 ton, or will I be fine?
66 C20 Service Truck:
LostMy65 is offline
Old 02-06-2012, 01:09 AM   #246
Captainfab
60-66 Nut
Some of the master cylinders on the 3/4 tons will be different than a 1/2 ton master, depending on the factory brake package. If your front calipers have the 2-15/16" bore, you can likely get away with that '79 K10 booster and master. If you have the 3-5/32" bore calipers, I would suggest a appropriate master. The masters will interchange with boosters regardless of 1/2 ton or 3/4 ton, at least with pre '99 trucks.
Old 02-06-2012, 12:57 PM   #247
LostMy65
LostMy65's Avatar
Does this look like a 3-5/32 bore or a 2-15/16?
The front end was off a 79 1-ton.
LostMy65 is offline
Old 02-07-2012, 01:11 AM   #248
Captainfab
60-66 Nut
Ok, that does make a difference since you have a C30 front suspension and brakes. The 30 series trucks used an entirely different style caliper, with a bore that I believe may be bigger than 3-5/32". Is your 14 bolt from the same truck? I would definitely go with a master cylinder for a '79 SRW C30.
Old 02-07-2012, 03:38 AM   #249
LostMy65
LostMy65's Avatar
I think the 14 bolt was just a 3/4 ton.
Can I atleast run the booster and master cylinder from the 1/2 ton suburban until I find a setup from a C30?
LostMy65 is offline
Old 02-07-2012, 03:17 PM   #250
padresag
like the Capt states one should use the appropriate master. once you install the smaller master and perhaps find out that you can get away with it; it will never get changed. then one day you will need all that brake and find that you don't have it. someone then gets hurt( I am just making a general statement, not you personally, but if the shoe fits!!)
but I would just check if there was any difference in the master cyls. the one(m/c) on my
1 ton doesn't look any different from the others but may have a bigger bore. I know that the w/cyl are a good size larger. one would think that a vehicle wit a much greater GVW would have a larger total braking capacity.
ron
padresag is offline
