Old 05-03-2014, 07:30 PM   #226
Dean'smeanmachine
Dean'smeanmachine's Avatar
Re: '72 chevrolet c20 custom camper build "Craig"
that triangle was a very thin spot it even "tin canned" when you pushed down on it
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 05-03-2014, 09:55 PM   #227
swamp rat
swamp rat's Avatar
Nice work Dean!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-07-2014, 10:26 AM   #228
Dean'smeanmachine
finished the drivers side cowl patches. it was quite complicated and challenging, i think im getting better at this though!
Dean
in God we Trust
Old 05-07-2014, 10:29 AM   #229
Dean'smeanmachine
i kept burning thrue. i think it was the undercoating that was making it burn thrue. thats why it looks like that
and the finished patch, not bad.
also the floor patch finished
Dean
in God we Trust
Old 05-07-2014, 10:31 AM   #230
sduckworth13
sduckworth13's Avatar
Nice work Dean
Scott
sduckworth13 is offline   Reply With Quote
Old 05-07-2014, 10:32 AM   #231
Dean'smeanmachine
i think i have 10 hours into that cowl patch
Dean
in God we Trust
Old 05-07-2014, 10:33 AM   #232
Dean'smeanmachine
Originally Posted by sduckworth13 View Post
Nice work Dean
thank you
Dean
in God we Trust
Old 05-07-2014, 09:53 PM   #233
sduckworth13
I understand Dean, it's amazing how much time can go in such a small piece. Usually that area is pretty rusty and you'll quit blowing thru till you hit some solid metal. I had the same issue when I patched mine up too.
Scott
Old 05-07-2014, 11:12 PM   #234
Dean'smeanmachine
cool, thanks. yeah, its crazy the time that goes into even the smallest piece.
Dean
in God we Trust
Old 05-08-2014, 12:38 AM   #235
Mustard72
Mustard72's Avatar
So is that a little steel frame they put inside the cowl there for the two threaded holes? I figured they were just nuts (or equivalent) welded in there. Got a screw broke off in one of mine that I'll need to address at some point...
Patches look good, Dean. I suppose by the time we get proficient at this stuff, we'll be done with our trucks.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 05-08-2014, 08:08 AM   #236
mcbassin
Still Learning
mcbassin's Avatar
Those areas you fixed are one of the hardest to remove all the rust from in my opinion. I thought I got it all on my cab but I had some bubbles come back through the primer 2 years later. Really frustrating! I was almost ready for final sanding when I found it. I only hope I got it all the second time.
Not to discourage you at all just letting you know sometimes there's more rust behind the holes you can actually see.
I know how long it takes to fix these spots. All your hard work is rewarded when it's all done. Keep the pictures.
mcbassin is offline   Reply With Quote
Old 05-08-2014, 10:38 AM   #237
Dean'smeanmachine
yeah, there is a frame. it is pretty thick steel with the holes threaded in. there are no nuts as far as i know. yeah, takes a while to master this stuff lol
Dean
in God we Trust
Old 05-08-2014, 10:40 AM   #238
Dean'smeanmachine
thanks, yeah they are some diffucult spot. thanks for the heads up ill check it out. i appreciate the tips from you other guys that are further along in the restoration. thanks
Dean
in God we Trust
Old 05-11-2014, 11:20 PM   #239
Dean'smeanmachine
alright, i finished up the last patch (that i know of) on the cab i thoroughly looked every where and couldent find anymore rust. . still need to order pass. cab corner and then im done with cab (not including doors) then it will be time to clean up underside and stuff. also still have to paint the engine.
Dean
in God we Trust
Old 05-11-2014, 11:25 PM   #240
Dean'smeanmachine
heres the other side with all the pinholes welded up and ground down.
that last picture didnt turn out good lol
Dean
in God we Trust
Old 05-12-2014, 12:49 AM   #241
swamp rat
swamp rat's Avatar
Well your running circles around me, i didn't get anything done today, might not get much done at all the next week as i have to get ready for and take a little road trip..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 05-12-2014, 01:27 AM   #242
Mustard72
Mustard72's Avatar
Yah. Good to see somebody making progress, because it sure isn't me. Good job, Dean.
Nick
Old 05-12-2014, 09:22 PM   #243
Dean'smeanmachine
swamp rat: have fun on your road trip
Nick: thanks. i can understand. busy as a bee probably
Dean
in God we Trust
Old 05-12-2014, 09:28 PM   #244
Dean'smeanmachine
a little progress today (yesterday now)
primed the floor and the repairs. the primer is from tractor supply. nothing fancy, sticks well. this is no big buck build.
i think it turned out good. and my spray gun works awesome
Dean
in God we Trust
Old 05-12-2014, 09:30 PM   #245
Dean'smeanmachine
nice to have it all the same color after all that hard work
Dean
in God we Trust
Old 05-12-2014, 09:32 PM   #246
Dean'smeanmachine
also took the passenger door back off to do some repairs. drilled a hole in each hinge to help line it up. hopefully in a good spot
Dean
in God we Trust
Old 05-12-2014, 11:23 PM   #247
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress Dean. I know how much time all those repairs take. I do the same trick with my hinges too. Get's you close.
Old 05-14-2014, 10:52 PM   #248
gdavis
gdavis's Avatar
off and running there man. I wish I lived up there in the summer for I would live in that bone yard with all the cool trucks. I said summer.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 05-15-2014, 10:46 AM   #249
Dean'smeanmachine
Mike: thanks. yeah Scott told me about that trick.
George: love that yard. its my favorite
Dean
in God we Trust
Old 05-20-2014, 11:05 AM   #250
Dean'smeanmachine
got some passenger side door repairs in progress
Dean
in God we Trust
