Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 04-09-2016, 08:44 AM   #226
ochre 72
Re: Project 6 Point Oh
Very nice build. I picked up a few things reading through it. Looking forward to more progress.
ochre 72 is offline   Reply With Quote
Old 04-12-2016, 03:13 PM   #227
IGOR
IGOR's Avatar
What color is that on your transmission? Is that also POR-15?
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 04-12-2016, 09:57 PM   #228
East Tex
It's actually one of a very few things that I've painted with a rattle can. But it looks great. Here is a pic of the label. The color is Cast Iron.
My 1972 K5 6.0 LTR 4L60 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=622068
East Tex is offline   Reply With Quote
Old 04-12-2016, 10:00 PM   #229
East Tex
Originally Posted by shenk10 View Post
Great build. I saw you got extended emergency brake cables. I plan on going the same route, except I have a 6" all spring lift. Do you think the 3" extended cables would work with that or do you think I should go a little longer? I've tried searching and all I found was people just moving the bracket to the bottom rail which I dont want to do. Thanks.
I don't think the 3" cables would be long enough for your 6" lift. But, I'd be scared to guess how much longer you'd need them.
Old 04-13-2016, 10:25 AM   #230
IGOR
IGOR's Avatar
Thanks!
-Ben
Old 04-13-2016, 07:15 PM   #231
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
More...
I like the bolts on the front diff!
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 04-14-2016, 12:53 AM   #232
East Tex
http://www.amazon.com/Flange-Serrated-Screws-Stain... http://www.amazon.com/Flange-Serrated-Screws-Stain...
They're stainless bolts. Here is the link to Amazon where I bought them. I put them on front and rear diff covers.
Old 05-04-2016, 02:49 PM   #233
shenk10
shenk10's Avatar
I'm running into the same problem with the rear brake hose. The brake line attaches to the hose with 7/16" fittings correct and the 3/8" fittings go to the brake drum? What did you tell inline in order to get the larger diameter tee fitting for the hose. I tried to explain when I order from inline but got a tee that fits the 3/8" fittings. Thanks for the help.
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 05-05-2016, 03:37 PM   #234
East Tex
The only thing that I told them was that I wanted a brake hose for a 1972 K5, that was 4" longer than stock (because of my lift kit). And it was the correct one when it came in.
Old 06-05-2016, 11:29 PM   #235
Chad22873
Chad22873's Avatar
Anymore fresh painted parts laying in the grass? Lol
BR549
Chad22873 is offline   Reply With Quote
Old 06-29-2016, 07:28 PM   #236
East Tex
Haha no. As a matter of fact, I've been so busy at work, that I haven't touched the Blazer in months. I hope to slow down some this summer and get back at it.
Old 01-06-2019, 10:34 PM   #237
East Tex
Been a while since I posted. I got the fuel lines buttoned up. I test fit the high mount A/C brackets, and afterwards painted with POR15 and reinstalled.
Old 01-06-2019, 10:42 PM   #238
East Tex
Of course I had help from one of my Grands!
Old 01-06-2019, 11:00 PM   #239
East Tex
I thought that I'd take the front shaft to the local drive shaft shop and have them rebuild the cardan joint, and while they were at it, I thought that I'd have them replace all the u joints in both shafts to save me the trouble. Well, I explained to them if they'd clean them up real good and put a nice paint job on them, I'd let them do it all and not just the cardan joint. I made it clear that these were going on a very nice restoration. Well, I couldn't believe my eyes, they didn't even take off all the grease/dirt before balancing or painting. I should have done it myself, because I had to re do their crap work.
Old 01-06-2019, 11:03 PM   #240
East Tex
Got my tow hooks installed.
Old 01-06-2019, 11:10 PM   #241
East Tex
So I finally bought me a tig welder and a Stainless Works 2.5" "builders" exhaust kit. It's 304 stainless and has straights, 90's, 45's etc. I'm still learning to tig, so don't be too harsh on my welds lol. Also bought some Borla Pro XS mufflers.
Old 01-06-2019, 11:23 PM   #242
East Tex
More
Old 01-06-2019, 11:26 PM   #243
East Tex
Vibrant V band clamps were way better than Stainless Works. The hangers were Stainless Works and worked great.
Old 01-06-2019, 11:39 PM   #244
East Tex
More
Old 01-06-2019, 11:42 PM   #245
East Tex
I've got both sides plumbed over the rear axle, and that's where I'll stop until I can get the body back on and see where the rear quarter panel sits. Then I'll finish it out behind the rear tires.
Old 01-06-2019, 11:45 PM   #246
East Tex
Now I'm going to get it to where I can start it and check everything out before I put the body back on. I got core support and radiator on, now to figure out what hoses to get.
Old 01-06-2019, 11:46 PM   #247
East Tex
Old 01-07-2019, 06:17 PM   #248
aggie91
I'm just glad to be here!
aggie91's Avatar
Very Nice work on the exhaust! I might should come check it out in person some day...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-11-2019, 11:48 AM   #249
East Tex
Come on by. I guess that I need to clean my shop up, before anyone sees my mess
