01-08-2017, 03:14 PM | #226 |
Re: 66 Pro Street Build (Domeringer)
WOW! You have some MAD fabrication skills! That looks BAD A$$$$ and looking forward to seeing it lighting up the rear tires.
01-08-2017, 08:25 PM | #227 | |
Active Member
Well as mentioned... still busy as hell but here's some progress. Early on I was talked into running a set of 315 Mickey Thompson tires. Original plan was big tire! Reminder Gary... don't change your plans! Had to shorten the rear end again to go big tire. Ran the two forward down bars and started mocking up the radiator mount. Also working on fabbing up two side tanks... one for methanol or race fuel and the other for pump gas. Here's some pics |
01-09-2017, 10:23 AM | #228 |
I'm just glad to be here!
WooHoo!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-09-2017, 02:01 PM | #229 |
Just amazing work, looks so cool just sitting there, well done.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
01-09-2017, 05:30 PM | #230 |
Man that is cool.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
01-09-2017, 07:05 PM | #231 |
Who Me?
Its nice to see your using a 2nd tape measure for back up!
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
01-11-2017, 09:59 AM | #232 |
How far back on on the from the front of the frame did you cut it? How did you decide to cut there? I'm currently working on a relatively similar build not nearly as stout but I'm replacing the frame rails and back halfing the truck but I'm leaving the front stub but changing the cross member and suspension.
01-12-2017, 12:50 AM | #233 |
Great Build ! I am trying to build 52 chevy truck with a C4 running gear This helps a lot to see another build thanks
Keep up the Great Work!!! |
01-29-2017, 06:13 PM | #234 | |||
Active Member
Thank you karl!
Hi David... Thank you much! Hi Steve, LOL it's odd to see 2 together in the pic.... can never seem to find one. Quote:
Ok workin on it! As I mentioned the truck will have two tanks one for high octane and the other for C16 race fuel. Started welding everything together... here's some pics of the layout. Will post details of innards next week. |
01-30-2017, 09:16 PM | #235 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Hmmm, some pretty nice welds on the aluminum tank!
Still watchin' closely! LOL!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
02-03-2017, 02:42 PM | #236 |
Beauty...every time I look back in so much better.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
02-12-2017, 05:23 PM | #237 | |
Active Member
Thanks guys! Figure'd some of you might like to see how the tanks are fabbed, so I'm going to get a little detailed on how the tanks and fuel system are designed and put together. The left tank is going to be mainly used for street use. Premium gas and maybe some E85 if we push the tune. Here's the in tank pump I'll use for this system. The right side tank will be ready for high HP. Race fuels only! It will contain another in tank pump that will only transfer the fuel to a surge tank up front that will contain 2 or three additional pumps to supply fuel bigly here's an excellent example for reference... RADIUM I'm going to machine and fab all of components and make my own version... more on that later. Made a lot of progress this week! Bent up some tube and attached them to the frame for mounting the tanks and started finish welding the tanks. Here's some pics |
02-13-2017, 07:04 PM | #238 |
Pretty cool stuff going on every time I check your updates...Thanks for sharing!
02-15-2017, 07:26 PM | #239 | |
Active Member
Working on the layout for the fuel pump hangers. Machined some brackets for the pumps. |
02-16-2017, 10:55 AM | #240 |
Those are nice! Sure beats a hose clamp...lol
02-18-2017, 05:07 PM | #241 |
Active Member
Thanks Karl!
Ok.... Machined and welded some pump hanger flanges |
02-18-2017, 08:37 PM | #242 |
Who Me?
Mad fab skills as always Gary!!
02-22-2017, 06:59 PM | #243 |
Active Member
Thank you Steve!
Got the tank pump hat designed... off to the machine TOP
BOTTOM |
02-22-2017, 07:37 PM | #244 |
This build is so off the charts, very cool, keep at it.
Mudman.
02-24-2017, 03:17 AM | #245 |
Gary, I have nothing to add except massive admiration.
Your build is in such a different world. Tanks look lovely.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
02-25-2017, 06:09 AM | #246 | ||
Active Member
Well... up with the birds! Here's some update pics of the fuel hat design. Laid out the o'ring sealed electric insulators and inserted one of them into the hat, also added the tank seal o'ring groove and lightened the hat a bit more... good to go! |
03-14-2017, 12:04 AM | #247 |
Glad to see this truck still going. Sorry for all the annoying questions in the past, I have since done my research and figured things out. I can't wait to see this done. I don't know if a 71 El Camino counts as a truck but I'm gonna start my build thread here thank you for the "truck" inspiration it kept me from going the typical Cameron drag car kind of build.
03-14-2017, 07:29 PM | #248 | |
03-14-2017, 08:29 PM | #249 | |
Active Member
Have been very busy in my spare time, programming and machining parts for this fuel pump setup. Another weekend of machining and I'll post up some pics... |
03-14-2017, 08:56 PM | #250 | |
Tags |
66 c10, drag truck, pro street, twin turbo ls1 |
