Old 01-05-2015, 12:02 PM   #226
mcbassin
Still Learning
mcbassin's Avatar
Re: jimbosprint 1972 C20 - the good, the bad, and the ugly
Cool pictures. Thanks for sharing. That looks almost like the prairie land around here
mcbassin is offline   Reply With Quote
Old 01-05-2015, 01:13 PM   #227
flashed
Those are great pics and the truck sure does look good .
flashed is offline   Reply With Quote
Old 01-10-2015, 05:38 PM   #228
jimbosprint
jimbosprint's Avatar
Changed the oil today. 500 miles on the new engine.
jimbosprint is offline   Reply With Quote
Old 01-14-2015, 05:17 PM   #229
jimbosprint
New seat cover and foam arrived today. Thanks PICKMUP!
Old 01-17-2015, 06:44 PM   #230
jimbosprint
So after a couple tanks of gas I found my mileage was really bad (~9mpg), and so I did some research into that and the slight stumbling/missing problem I was having too. Turns out Edelbrock carburetors don't like more than 5.5psi fuel pressure and they are also sensitive to heat.
The other day I installed a 1/2" 4-hole wood carburetor spacer to help with heat insulation and supposedly help with low end torque as well. I also got a pressure gauge to find out the actual pressure coming from the stock mechanical fuel pump, and it was putting out 8psi.
Today I installed a pressure regulator. As I turned down the pressure I noticed a change in the idle. Just took it for a test drive and it seemed to have decent response and I didn't notice any stumbling. I won't say it's fixed until I can drive it for a while under various conditions and calculate mileage, but I am optimistic.
Old 01-20-2015, 08:51 PM   #231
jimbosprint
I got the bench seat mostly ready for the new upholstery today. All the hog rings are removed and the back cover and foam are off. I couldn't get the screws for the back frame out, so I'll leave that to the upholstery shop.
PICKMUP recommended filing/grinding down the sharp parts on the top of the frame that could eventually wear through the cover - pics below.
Old 01-21-2015, 11:47 PM   #232
jimbosprint
Seat is at the upholstery shop and he says it will be done tomorrow. I can't wait!
I also took out the old trailer brake setup today. I really did not like that Willy Wonka brake line in the engine compartment or the dumb box under the dash. Some modern trailer wiring is needed still.
Old 01-22-2015, 12:11 AM   #233
Saclandman
Saclandman's Avatar
Lookin' good Jimbo. What regulator did you end up using for your carb?
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 01-22-2015, 04:41 PM   #234
jimbosprint
The seat is done! I am very happy with it (even though it doesn't match the original black cloth trim seat cover). Now I can truly enjoy driving my truck!
Old 01-22-2015, 05:49 PM   #235
mcbassin
Still Learning
mcbassin's Avatar
Wow! the seat looks great!!
Old 01-22-2015, 06:36 PM   #236
flashed
That seat looks great as well as the rest of the truck .
Old 01-22-2015, 06:58 PM   #237
jimbosprint
Thanks guys! It's so much nicer to drive now. Before it was like sitting in a hole looking through the steering wheel.
Old 02-03-2015, 08:56 PM   #238
jimbosprint
Photo gallery updated - 389 photos
Old 02-03-2015, 09:18 PM   #239
Saclandman
Saclandman's Avatar
Looking good, Jim.
Rich J.
Old 02-14-2015, 05:12 PM   #240
jimbosprint
I think I found a bed and rear bumper for $200. A few dents, but no bondo.
Kicking myself for not taking pictures.
Old 02-14-2015, 07:55 PM   #241
flashed
Sounds like a killer deal .
Old 02-15-2015, 09:11 AM   #242
jimbosprint
Owner sent me a pic, and I told him I'd take it. Now I have to find a trailer and a couple friends to help me go pick it up.
(I'm just buying the bed, not the trailer).
Old 02-15-2015, 10:10 AM   #243
flashed
Why not take it home as a trailer ,remove the bed and take the trailer part back ?
Old 02-15-2015, 10:52 AM   #244
jimbosprint
It's too far away. I only want to make one trip.
Old 02-15-2015, 01:27 PM   #245
flashed
Now I understand .
Old 02-16-2015, 04:22 PM   #246
Oly72C20
That is a very clean truck and great job with the details and pictures! I sure wish mine was progressing as well as yours!
Joe
Oly72C20 is offline   Reply With Quote
Old 02-16-2015, 08:00 PM   #247
jimbosprint
Joe
Thanks Joe. All cell phone pictures - I enjoyed taking them because I didn't take enough when I built my last project car 15 years ago.
Starting a build thread motivated me. Let's see your project!
Old 02-19-2015, 02:48 PM   #248
jimbosprint
So the guy selling the bed has decided to save me $100 and bunch of hassle moving it. He's going to take it apart and sell me just the inner and outer passenger side and wheel well. Score!
Old 02-25-2015, 10:47 AM   #249
jimbosprint
I think the driver side exhaust manifold is leaking. Noise developed and got worse the last couple days. I got a replacement when I did the passenger side so I should have it fixed quick.
Also the window fogs up all the time, not just after rain. I think the heater core is leaking.
I wanted a truck to work on - and I got it.
Old 02-25-2015, 02:09 PM   #250
flashed
Those heater cores can be a pain especially if you have an A/C truck .My 72 El Camino needs a new heater core and its even worse than these trucks to change .
1972, c20, deluxe, stock
