Old 02-24-2016, 01:14 PM   #226
tinydb84
tinydb84's Avatar
Re: Used Parts Build
The tabs are pre-fab'd. They didn't include the back piece. I cut those myself. I am thinking a double U shape (top and bottom). I don't think it is actually needed but I think it would look off if the bottom is boxed but the top isn't.
David
Instagram: myfabguy
Old 02-24-2016, 04:33 PM   #227
aggie91
I'm just glad to be here!
aggie91's Avatar
just clip the corners where the boxing plate meets the tabs and axles...basically opens up the corners...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-25-2016, 02:01 PM   #228
slotard
I wouldn't expect TIG to go through much more gas than MIG. 15-20cfh is a pretty common flow rate for each. About the only way for a similar size MIG bottle to last a lot longer is if it's CO2 (a 20lb CO2 bottle is around 170cf while a similar size C25 or Argon bottle is around 80cf). Of course, it does take more time with TIG so you get less welding done. If you're doing much welding at all, buy the biggest bottle you can reasonably store.
Too bad you had to cut it off.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-26-2016, 04:03 AM   #229
tinydb84
tinydb84's Avatar
The welding does take significantly longer but also the post flow from the tacks and each bead does use up a bit of gas. I only have an 80cf tank because I cant fit anything larger in my car. I might buy a second tank so I can run a backpurge set up. Well see when I actually need it.
David
Instagram: myfabguy
Old 02-26-2016, 04:06 AM   #230
tinydb84
tinydb84's Avatar
Got the rear end where it should be. Didnt get a ton done tonight but snapped some good pics!
I took some measurements and it should lay rocker on 31 inch tall tires. With the 28 inch tires on there now it should have a 5(ish) inch ride height. Waiting on parts right now but hopefully I'll get the shocks and lower bag brackets done and maybe some painting this weekend.
David
Instagram: myfabguy
Old 02-26-2016, 09:28 AM   #231
Joe Pass
Joe Pass's Avatar
Taking shape....a lot of work, you should be proud
Joe Pass is offline   Reply With Quote
Old 02-26-2016, 01:38 PM   #232
slotard
Will you have to do any cutting on the cab for driveshaft clearance?
1973 C20, 350/350
Old 02-27-2016, 04:05 AM   #233
tinydb84
tinydb84's Avatar
Thanks Joe. Definitely felt good seeing how low it would be.
Yeah. I'm going to have to a bit. I am going to wait until I get more done before I deal with that though.
David
Instagram: myfabguy
Old 02-27-2016, 04:12 AM   #234
tinydb84
tinydb84's Avatar
Got my bag mounts welded on the links today
David
Instagram: myfabguy
Old 02-29-2016, 01:21 AM   #235
tinydb84
tinydb84's Avatar
Got more work done today.
Shock tabs welded on
Then decided to strip the bed of the 66. It was mostly rattle can primer and was starting to rust.
Stipped a good 80% of it and called my brother to help me.
My uncle came out and masked it for me. He has been painting residential for 30 years. Masked it in less time than it too for me to load the masker...My brother never painted before so I figured I'd let him give it a try.
Got dark before I could get a good pic.
I'll start a thread for it when I actually start wrenching on it.
David
Instagram: myfabguy
Old 03-01-2016, 09:35 PM   #236
tinydb84
tinydb84's Avatar
Took off early from work to get another coat of paint on my 66.
Painted some other parts while I was there
Got my sway bar in.
Got the shipment notification for my bag cups and watts link.
Need to figure out how to package it all back there. I am thinking of installing the watts and bag cups then fit the sway bar in somewhere. I am open to suggestions. Any thoughts?
David
Instagram: myfabguy
Old 03-02-2016, 01:08 AM   #237
mattcrp1
mattcrp1's Avatar
Looking good.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-06-2016, 12:58 AM   #238
tinydb84
tinydb84's Avatar
Got a couple things done:
Started making out a boxing plate for the read half:
Cut it out but got sick of it so I will finish it later
Started working on my shock mounts:
Welded one side on:
Lined up the other side:
Boxed. They look better in person though. I will weld them to the outside of the frame rails behind the axle.
David
Instagram: myfabguy
Old 03-06-2016, 04:19 PM   #239
tinydb84
tinydb84's Avatar
Bit more work done yesterday. Didnt get a chance to put the pics up.
Cut my cups for the upper mounts in the rear
Double beveled the joint
Tig'd them together
Mig'd the inside because I couldnt tig it
Got the watts link welded to the axle
Not the best looking weld :/
Going to finish boxing the tabs on the axle today. Not sure what else I am going to get done since it is raining like hell and I dont have much left I can do in the garage.
David
Instagram: myfabguy
Old 03-06-2016, 09:45 PM   #240
Joe Pass
Joe Pass's Avatar
The needed rain makes it a tough go when in the driveway....
Old 03-11-2016, 04:27 AM   #241
tinydb84
tinydb84's Avatar
I know. I have a canopy but kinda sucks when you need to weld and have bare metal. Pretty lazy/busy this week. Snuck into the garage for a bit today though.
Need a better way to cut this stuff. Its really hard to get the small radius curves to look good.
Need to stop welding on the floor too...
Trying to make everything look like it fits together. Added a boxing plate to my upper mounts to match the bottom mounts.
I filled the gap you can see in the previous pic with some rod and freehand weave.
David
Instagram: myfabguy
Old 03-11-2016, 04:32 AM   #242
tinydb84
tinydb84's Avatar
I have been looking at the bed and ways to mount it. Not really sure I want to use the stock bed floor. I had to move it by myself with some dollys and it is heavy!
I was thinking for now just to run some aluminum crossmembers bolted to the inside of the bed sides and deal with putting the actual floor in later. I was thinking of 2x3x.188 aluminum rectangular tube. Probably run 4 of them, one on each end and one before and after the tires. Any thoughts? Any of you engineers out there want to comment on the material choice for the crossmembers?
David
Instagram: myfabguy
Old 03-12-2016, 04:53 AM   #243
tinydb84
tinydb84's Avatar
Got all my tabs boxed in.
Really need the rain to stop...I dont know how much I'll get done in the next two weeks with the rain and a trip out of town.
David
Instagram: myfabguy
Old 03-13-2016, 02:28 PM   #244
slotard
Do you have a hole saw? With one and a drill press (or even hand drill) those cutouts for tube are a lot easier.
How much weight do you expect to put in the bed? If none, I wouldn't expect any real problems with 2x3 3/16 but I'm not doing any math.
1973 C20, 350/350
Old 04-01-2016, 02:18 AM   #245
tinydb84
tinydb84's Avatar
Good idea with the hole saw. Ill have to do that next. No weight really. Maybe move a couch here and there.
Anyway. Been out of town and sick as a dog. Got a bit done tonight:
Got some of my tubes fit for my bag mounts. Here is the idea:
Got the tubes mostly fit up:
And done!
I am thinking of gusseting them together using 1/8'' plate that matches the style of the 4 link tabs. Its going to be a bit time consuming to match the other side. I am thinking I am going to copy each join using paper wrapped around each tube then turning it inside out and placing it on the tube for the other side. Any thoughts?
David
Instagram: myfabguy
Old 04-03-2016, 12:48 AM   #246
tinydb84
tinydb84's Avatar
Spent some more time fitting each tube. Then leveling everything out.
Then burned it all in.
I didnt like the fitment on the last bar so I am going to redo that one. I ended up mig welding it all because I was worried it would move too much of I tacked it and pulled it off to weld it in the garage. I wish I could get the whole truck in but it will have to do.
David
Instagram: myfabguy
Old 04-03-2016, 12:10 PM   #247
Hankster
Hankster's Avatar
Looks really cool. I like it.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 04-03-2016, 01:19 PM   #248
DblTrbl
DblTrbl's Avatar
It's really coming together man! I like how it's totally different than what I've seen before. What do you intend to do for shocks? Cantilevered? :-)
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 04-04-2016, 12:21 AM   #249
tinydb84
tinydb84's Avatar
Thanks man.
Just going to run them at a ****ty angle for now. I will probably redo them somewhere down the road.
Finished the bars:
Shock mounts. Not the best angle but will work for now.
Going to run these from the notch to the rear bar and the rear bar to the middle bar.
Started cutting but it got late so this is where I left off.
David
Instagram: myfabguy
Old 04-08-2016, 12:13 AM   #250
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Well have you put the filler panels on the tubes yet?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
