Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-16-2016, 01:39 PM   #226
hemi43
hemi43's Avatar
Re: Hemi's 70 Blazer build
Went for a nice fall colors tour this weekend. Probably the last big drive of the year before the Blazer gets put away for the long winter hibernation. Put almost 300 miles on this drive and used just under a half a tank of fuel. I sure love that 5.3 !!
hemi43 is offline   Reply With Quote
Old 01-15-2017, 03:03 PM   #227
Chad22873
Chad22873's Avatar
Hey Dan, I think I read somewhere in another thread that you had said on this build that you didn't close up any of the original holes in the firewall. I believe you said even though you weren't using them that you wanted it to remain original. I am doing the same. My question is what did you do with the square hole that the original bulkhead of the wiring harness ran through? Did you use it or did you find a grommet of some kind? I wish to use the square hole but for a solid round cable of wires.
BR549
Chad22873 is offline   Reply With Quote
Old 01-15-2017, 09:28 PM   #228
harrisoncole4
harrisoncole4's Avatar
Amazing build! I hope my blazer looks close to this one day.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858
harrisoncole4 is offline   Reply With Quote
Old 04-10-2017, 02:40 PM   #229
hemi43
hemi43's Avatar
Just brought the Blazer out for the first time this year. I decided to tackle a rattle that has been bugging me since I finished the build, and finally got it solved. I put a small rubber block on the door window frame that contacts the A pillar. Man, this made a huge difference, because it now prevents the two from touching on rough roads. At least now there's some pressure on the door when closed. Best part is that it's almost impossible to see when the door is closed.
Old 04-10-2017, 04:35 PM   #230
IronCanine
I'm trying....
IronCanine's Avatar
Another solid Blazer hack. Very smart Dan.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 04-10-2017, 04:40 PM   #231
grillzy
What a great idea!
grillzy is offline   Reply With Quote
Old 04-13-2017, 03:57 PM   #232
xr395b
awesome idea i need to do that on mine
xr395b is offline   Reply With Quote
Old 04-14-2017, 01:06 PM   #233
mtully79
mtully79's Avatar
How did you attach it to the window frame? Sheet metal screw?
Thanks, great thread!
mtully79 is offline   Reply With Quote
Old 04-16-2017, 04:17 PM   #234
hemi43
hemi43's Avatar
Yeah, I didn't want to put holes it it but figured it wouldn't move if it was screwed down.
Old 04-16-2017, 04:18 PM   #235
hemi43
hemi43's Avatar
I was bored today so I made a YouTube video of the build.
https://youtu.be/hy7e_k0PEHg
Old 04-17-2017, 03:05 PM   #236
69lowrydr
New Member
69lowrydr's Avatar
I just went thru your entire build, very nice job and cool video.
I noticed on page 1 that you made your own rocker reinforcement plates from the old rusty ones. I'm currently at that stage with my 70 Blazer and was wondering if you have a .dxf file for the profiles you would be willing to share?
Mike
69lowrydr is offline   Reply With Quote
Old 04-17-2017, 03:32 PM   #237
hemi43
hemi43's Avatar
Mike
Took me a while, but I found the .DXF file.
PM me an e-mail address that I could send it to.
Dan
Old 04-17-2017, 03:55 PM   #238
69lowrydr
New Member
69lowrydr's Avatar
PM Sent
Old 04-17-2017, 04:24 PM   #239
hemi43
hemi43's Avatar
OK, file sent !!
Let me know how it works.
Dan
Old 06-28-2017, 03:50 PM   #240
hemi43
hemi43's Avatar
Finally got a day with no rain !! Went to the lake to see how high the water levels were because we are at record conditions. Looking forward to another trip to the Syracuse Nationals in a couple weeks. Hoping for better weather.
