Old 02-26-2021, 10:10 AM   #226
skymangs
skymangs's Avatar
Re: Orson the 49 GMC ~ Chris C.
I’m going to go carb on my 53 Packard Clipper Deluxe Sportster. You can’t reproduce that classic look with EFI.
skymangs is offline   Reply With Quote
Old 02-27-2021, 12:27 AM   #227
skymangs
skymangs's Avatar
1. Today’s progress
2. What’s left
Old 03-01-2021, 10:54 PM   #228
skymangs
skymangs's Avatar
1. we finally finished the engine harness today, all that’s left tomorrow is the fuse box
2. we also finished the firewall today.
Old 03-02-2021, 11:42 PM   #229
skymangs
skymangs's Avatar
we started putting loom on the wiring today
Old 03-03-2021, 08:39 AM   #230
6DoF
6DoF's Avatar
it's always suuuuper satisfying to watch loom turn a rats nest into simple perfection.
6DoF is offline   Reply With Quote
Old 03-03-2021, 10:25 AM   #231
skymangs
skymangs's Avatar
Yes it is!
Old 03-03-2021, 11:39 AM   #232
57FleetsideC4
Great progress! It's nice to get things under control.
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 03-03-2021, 01:12 PM   #233
skymangs
skymangs's Avatar
Thank you
Old 03-03-2021, 09:26 PM   #234
skymangs
skymangs's Avatar
1. we begin building the fuse box
2. JP installing the fuel line Quick connects
3. fuel system done
Old 03-03-2021, 09:29 PM   #235
skymangs
skymangs's Avatar
JP building the fuel system
http://www.facebook.com/104461545014...21892017954786
Old 03-04-2021, 02:44 AM   #236
joedoh
joedoh's Avatar
great stuff chris!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 03-04-2021, 09:55 AM   #237
skymangs
skymangs's Avatar
Thanks brother!
Old 03-04-2021, 10:22 PM   #238
skymangs
skymangs's Avatar
The fuel system is finished! We modified the universal 0-30 ohm sender and included it in the tank.
Old 03-05-2021, 11:31 AM   #239
skymangs
skymangs's Avatar
This is the look we’re going for!
Old 03-05-2021, 10:26 PM   #240
skymangs
skymangs's Avatar
This was the 04 and up PRND switch
This is the correct 99-03 PRND switch installed
This is showing us putting the wire loom on the main harness
Same
Main harness finished
Old 03-05-2021, 10:29 PM   #241
skymangs
skymangs's Avatar
Sender, lines and ground finished
Overall with finished fuel tank
we pulled the clutch, so we could remove the compressor from the old bracket and mount it on Orson
Old 03-06-2021, 08:46 AM   #242
Father&son56project
Excellent progress! I can't wait to see a shot of the finished wiring, all tucked into place. How many hours do you figure you guys have invested in just the wiring?
Father&son56project is offline   Reply With Quote
Old 03-06-2021, 09:32 AM   #243
skymangs
skymangs's Avatar
I’d say 20-25,but I’m not charging for this since I bought a harness that didn’t fit.
Old 03-08-2021, 11:33 PM   #244
skymangs
skymangs's Avatar
1-2. We got the fuze block wiring all loomed up
3. all the pulleys are back on and the belt is routed. Tomorrow the cooling system goes back on for the last time!
Old 03-10-2021, 12:07 AM   #245
skymangs
skymangs's Avatar
1. The problem, the tensioner pulley was to big and left no room for the hose
2. I solved it by going from a 3.5” pulley to a 3”.
3. The belt fitted correctly
4. we also did some more wire covering
Old 03-10-2021, 12:10 AM   #246
skymangs
skymangs's Avatar
The relay sockets came in today, so we started building the fuse Block
Old 03-10-2021, 11:17 PM   #247
skymangs
skymangs's Avatar
1. We got the fusebox finished
2. Here’s the backside
3. all 4 of the injector plugs on the driver’s bank were broken and wouldn’t stay on, wound up replacing them all. Also did some more Wire covering
Old 03-10-2021, 11:19 PM   #248
skymangs
skymangs's Avatar
We chose a 2nd gen Durango 2nd row for this build
Old 03-11-2021, 08:44 AM   #249
6DoF
6DoF's Avatar
oh shoot, that'll be a good seat. i like how the middle actually totally folds down vs an insert. more of buckets with a console vs a bench with an armrest.
Old 03-11-2021, 09:48 AM   #250
skymangs
skymangs's Avatar
That’s exactly the reason it was chosen, that and the width. These trucks will fit a 55” seat, this one’s 53”
