Closed Thread
Old 07-21-2013, 06:47 PM   #2601
OrrieG
OrrieG's Avatar
Re: What Did You Do With Your Truck Today ?
Minor stuff. scored a pair of 63 Starfire courtesy lights to put in my kick panels.
OrrieG is offline
Old 07-21-2013, 06:59 PM   #2602
mechanixman
mechanixman's Avatar
Cool! Any pictures?
I made the kick panel,
still need to weld it in.
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline
Old 07-21-2013, 10:40 PM   #2603
mknittle
mknittle's Avatar
I didn't do anything to my 52 but I did some serious looking and measuring on my 72. and found some possible solutions on moving the A/C pump on my 6bt Cummins to narrow up the bottom some.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 07-21-2013, 11:13 PM   #2604
spitfire_er
On my 55.5 gmc, I got all my brakes gone through and replaced all the parts that needed it. Also got a few good parts off another 57 GMC including an electric wiper motor!
spitfire_er is offline
Old 07-22-2013, 12:05 AM   #2605
T Hilde
Got all the tail lights wired up. Now I'm working on the inside.
T Hilde is offline
Old 07-22-2013, 12:30 PM   #2606
Dan in Pasadena
Dan in Pasadena's Avatar
I've been out of town since Friday so I got nothing done. I've been busting buns at my step son's new house installing a soft water system and post hole digging (ugh!) for rotted off posts - what a PITA job!
Work to restart on my '55 later this after noon!
Dan in Pasadena is offline
Old 07-22-2013, 10:22 PM   #2607
mknittle
mknittle's Avatar
I cut and drilled bumper mounts and reworked the pad where my core support mounts.
I also replaced another electric window motor in my moms Dakota. that's to in less than a week.
Mark
My GMC build.
mknittle is offline
Old 07-22-2013, 10:25 PM   #2608
mknittle
mknittle's Avatar
Originally Posted by Daze57 View Post
^ try again to upload a pict . -i would like to see what it looks like
Ill see if I can reduce the size tonight.
Mark
My GMC build.
mknittle is offline
Old 07-23-2013, 11:18 AM   #2609
pvienneau
pvienneau's Avatar
Cleaned up a front and rear brake cylinder on the bench grinder iwth a brass wire 8" brush; they look brandy new now.
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline
Old 07-25-2013, 12:13 AM   #2610
tttuba
Found this bumper and grille guard on e-bay mislabeled as a 38 Dodge pick up part. Was the only bidder and got it CHEAP. Had to install it and dress up my bumper.
tttuba is offline
Old 07-25-2013, 12:15 AM   #2611
tttuba
oops should have been this picture too.
tttuba is offline
Old 07-25-2013, 12:17 AM   #2612
fabguy
Elev8r Man
fabguy's Avatar
I got my 53 hubcaps in a very similar way on eBay .
Congrats, gotta love it
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline
Old 07-25-2013, 01:16 AM   #2613
mechanixman
Looks fantastic tttuba!
-Nick
Projects:
Old 07-26-2013, 05:59 PM   #2614
Midgets50
Midgets50's Avatar
took my drive shaft in to get cut. hopefully i can install the drive shaft and run brake lines the next time i get back
Midgets50 is offline
Old 07-26-2013, 06:09 PM   #2615
Denee007
Denee007's Avatar
I'd like to see those too!
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline
Old 07-26-2013, 07:50 PM   #2616
Dan in Pasadena
Denee,
I don't have a photo but I've seen several cars and trucks that used those old chrome license plate lights on the kick panels and even in the engine compartment. These are the ones I'm talking about are about 1" in diameter with half the lense area covered in chrome kinda like an eyelid.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Old 07-26-2013, 08:55 PM   #2617
Russell Ashley
Russell Ashley's Avatar
Dan, you mean like these? These are about the easiest way to add courtesy lights. I have mine wired so that both sides don't come on when one door is open.
Russell Ashley is offline
Old 07-26-2013, 10:53 PM   #2618
Denee007
Denee007's Avatar
Dan, Russell, now that is a clever idea! Thanks!!
Denee007 is offline
Old 07-27-2013, 12:24 AM   #2619
Dan in Pasadena
Yup, EXACTLY what I was talking about. Thanks!
Old 07-27-2013, 07:21 PM   #2620
crossfire84
crossfire84's Avatar
stained my bed wood today.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 07-27-2013, 07:47 PM   #2621
Russell Ashley
I need to make a new picture. I have corrected that gap at the top of the A/C outlet.
Old 07-27-2013, 11:24 PM   #2622
hsdropout
Got front fenders and hood fit up.
Having problem with back of hood not wanting to set down when closed........
Can't get adjusted to stay down...........worn hinges maybe?
Any tips?
hsdropout is offline
Old 07-27-2013, 11:32 PM   #2623
tttuba
Got my rear fenders back from the blaster. Looked good. Found all the prior work. Some of it was even lead work. That's a lost art. Never mind terribly toxic.
tttuba is offline
Old 07-28-2013, 12:46 AM   #2624
OrrieG
OrrieG's Avatar
blocking interior side of doors before paint.
OrrieG is offline
Old 07-28-2013, 01:23 AM   #2625
Dan in Pasadena
Any tips?
I'm having the same problem. Fabguy suggested I put all the shims under the lowest hood bolt (when the hood is in the up position). I plan to do that tomorrow and hope it makes some difference.
Closed Thread
