Old 07-19-2009, 03:31 PM   #251
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: '69 Longbed Daily Driver - Project
tires - 225/75/15's
bags - slam specialties RE7's all the way around
up front, the easiest way to go about it is to get the plates and cups from *****************. that saves you the time of fabbing up your own plates.
I also am running 2.5" drop spindles up front.
I didn't need to tub, however, the pumpkin will hit the floor of you bed when aired out. if you have larger tires, you may have to.
IvelDesigns is offline   Reply With Quote
Old 07-19-2009, 10:09 PM   #252
grayharville
^^who I am^^ what I say>
grayharville's Avatar
thanks! and how about the rear bag setup? did you use a kit? whered you get the notch? im really counting on you! lol you're truck is the whole reason im baggin mine, no lie! so i want all the specific details so i can duplicate your whole setup! thanks alot!
grayharville is offline   Reply With Quote
Old 07-21-2009, 12:39 PM   #253
IvelDesigns
I'm happy to hear you like my truck. It's always cool to hear someone say they're inspired to tackle their own project based on something you did.
most of the details are throughout this thread, but the rear bags are RE7's as well, and were simply mounted in place of the factory coil springs. The notch is the standard ECE notch that you'll see a lot of the guys on this forum using. I'm also running some home made 2.25" blocks, but they really aren't needed. You will also need to get an adjustable panhard bar from ECE as well so that your rear end stays in the correct spot.
make sure to take lots of pics and post them up in a build thread when you do start tearing into it.
You could always save some time and just buy my truck. $11k takes it home. I'd have no issues driving it to TX either
Old 07-23-2009, 09:50 PM   #254
grayharville
i really wish i had 11k. you would be driving to tx! lol anyways, i want to build my truck, mainly because my great grandfather bought it new, drove it till the day he died, it had been sittin since 1989, until i then resurrected it, and i am on a mission to make somethin he'd be proud of!
Your truck is beautiful, i want to match your truck pretty close, except mine will be red and white two tone. thanks alot for answering my questions, i may have a few more down the road, so please hang around to answer them! lol heres another batch of questions, on the rear, how are the bags mounted to the trailing arms? did you simply drill holes? and what about on the frame? what about air line provisions? do you have any pics of the front bag setup? thanks sooo much!
Old 07-24-2009, 12:51 PM   #255
IvelDesigns
sorry, i don't have hardly anything for pics of the front setup.
in the rear, the bottom bag mount will go through the existing hole in the trailing arm. just make sure you get the right length bolt (not to long, and use a couple washers to make sure it doesn't pull through the hole in the arm). For the top you'll have to drill your frame. the crappy thing is, to get the fittings through the frame you'll need to drill about a 1.125" hole. I was going through for layers of steel, upside down, pushing up... it sucked.
Old 07-24-2009, 01:36 PM   #256
grayharville
lol sounds like it sucked, ill probably just bust out the torch.
what would you suggest for bags? my main issue is cost.
i found some chassis tech de-nominator bags, that are "supposedly" the same thing as airlift dominator bags, im not sure how legit these are, but for the price saving i thought i would try! thanks alot
Old 07-24-2009, 04:32 PM   #257
grayharville
oh and also, i couldnt find the ECE notch on their website? any ideas?
Old 07-24-2009, 08:49 PM   #258
smbrouss70
smbrouss70's Avatar
I'm sure he meant CPP, they make the bolt-in notch that most people use, including myself.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-25-2009, 09:42 PM   #259
grayharville
oh ok. wait, i couldnt find one there either? in their online category anyways. any ideas? im really just interested in seeing the price.
Old 07-25-2009, 11:49 PM   #260
smbrouss70
smbrouss70's Avatar
http://www.classicperform.com/Store/...ck/6372CNK.htm
They list it for $99. Check with our board vendors, you should be able to save a few bucks.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 07-26-2009, 03:29 PM   #261
grayharville
thanks! hey, i have the steel, and can fab good, would it be a good idea to build my own frame notch?
Old 07-26-2009, 03:48 PM   #262
VA72C10
VA72C10
VA72C10's Avatar
I have a CPP notch but after seeing others I think I'm gonna get some thick steel round tube and make the notch round to match the rear end and then box the frame in that area. you can fab a notch like the others also....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-28-2009, 12:23 AM   #263
IvelDesigns
go with slam specialties RE7's. They are $75 each, and have worked well for me. I used them on my '50 too.
Old 07-28-2009, 07:23 PM   #264
grayharville
thanks! i have some heavy wall drill pipe. ill prolly use it for my notch!
where did you order your bags from ivel?
Old 07-28-2009, 09:45 PM   #265
IvelDesigns
***************** usually has them in stock. And yeah, fabbing your own notch should not be any big deal. Just use some .25 wall tube, and i would suggest boxing that part of your frame too.
there's a really good write up on fabbing your own notch in the FAQ section.
Old 07-28-2009, 11:12 PM   #266
grayharville
thanks so much guys! i really wish i could start on this now! but first, i need tires.
i might get the bags, build the notch, install the rear bags, then run some lines to a ball valve, so i can use it without a compressor and tank, once i can afford that stuff ill upgrade.
Old 07-31-2009, 11:50 AM   #267
IvelDesigns
i'm not sure how well a ball valve will work. especially since you need to be able to force air in, and let it out.
Another option for doing bags on the cheap is to use shrader valves. You can get them at NAPA for a couple bucks. Then you don't even need to run a tank.
I suppose you could run a tank with a single shrader, then have ball valves between each bag and the tank, but then you'll still need something, maybe a shrader to let air out.
just some thoughts.
Old 07-31-2009, 04:01 PM   #268
watahyahknow
watahyahknow's Avatar
uhmmm run 4 tire inflator thingies you know the ones you hook up to youre compressorhose to inflate the tires http://www.sz-wholesale.com/uploadFi...mber_46254.jpg
they have a handle to put air in and a small valve to let air out and a big clock to measure the amound of pressure . you need to put a different hose on the end so there permanently hooked to the bags though or maibe one of those thats hooked up to a manifold with 4 schrader valves so you can tune the bags one at a time by opening the valve to that bag
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-31-2009, 06:20 PM   #269
grayharville
im busy with moving houses right now, but once i catch a break ill do a thorough research on this. and i feel stupid, but what is a shrader valve? THanks alot guys!
Old 07-31-2009, 06:31 PM   #270
watahyahknow
its on every wheel on youre car look it up on google for a pic
Old 07-31-2009, 08:12 PM   #271
brak
brak's Avatar
WOW!
Lookin great.
Too bad i'm finally starting on mine
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 07-31-2009, 10:45 PM   #272
grayharville
oh okay i know what your talkin about. i just call that the "valve stem thingy" lol
Old 08-30-2009, 10:49 PM   #273
IvelDesigns
ok guys, after having the '69 sit in the garage for damn near the whole summer, it's time to get this into the hands of someone who will drive it, use it, and take care of it.
http://desmoines.craigslist.org/cto/1350766086.html
http://cgi.ebay.com/ebaymotors/ws/eB...=tab%3DSelling
http://www.goodguysclassifieds.com/c...olet_C_10.html
If you're a board member, I'll throw in all of the spare parts i have. new black dash pad, inner wheel wells, lights, etc... hell, if you want it, i'll throw in the '69 clip that was on it, and another '68 hood (purple but dent/rust free)
Old 09-03-2009, 12:20 AM   #274
grayharville
i hate to see it go... i wish i could get my hands on that spare hood, but shipping from iowa to texas would SUCK!
Old 09-03-2009, 11:30 AM   #275
texanidiot25
Eat My Rust
texanidiot25's Avatar
I'd be all over that if you were closer. Certainly one of my favorite trucks here.
texanidiot25 is offline   Reply With Quote
