Closed Thread
Old 01-01-2011, 12:50 AM   #251
spudz
spudz's Avatar
Re: my 87 chevy project
Be sure to use a good quality 6 point socket on the head bolts and u should have no problem
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline
Old 01-02-2011, 06:30 PM   #252
87 chevy silverado
Much worst than just head gaskets. the complete motor is the Farly new 350. I got it from a buddy,i also have to swap a few things and get gaskets
Attachment 675496
Attachment 675497
Attachment 675498
Attachment 675499
Attachment 675500
87 chevy silverado is offline
Old 01-02-2011, 06:35 PM   #253
nbpro
Just so I got you right, your motor went out and you have another one coming from a buddy, right? Your post was a little confusing.
nbpro is offline
Old 01-02-2011, 06:38 PM   #254
87 chevy silverado
yes thats correct. sorry for the confusion i tor down the 305 mostly by my self with help of another buddy and pulled the block and bottom end with my dad.
Old 01-02-2011, 06:48 PM   #255
nbpro
good
nbpro is offline
Old 01-02-2011, 06:56 PM   #256
87 chevy silverado
yea the 350 is carb so i have to change intakes and all new gaskets, get a flywheel, oil pump scence were going to be right there and change the oil filter adapter cuz my radiator don have a oil cooler spot for it. and i may swap my cam and lifters
Old 01-02-2011, 07:08 PM   #257
spudz
spudz's Avatar
cool, just be sure to use a mild cam . because your tbi will NOT like it haha. How bad was the 305? you can use your intake from your old motor on the new one.. I think you will want to get injectors for a 350 and a ecm or atleast the prom from a 350 ecm so it will run at its best.
spudz is offline
Old 01-02-2011, 07:08 PM   #258
87 chevy silverado
and i going to try to repaint the hole engine bay and put in the passenger inner finder(new one)
Old 01-02-2011, 07:14 PM   #259
87 chevy silverado
no i have a 2 year old rv cam in the 305 now that we put it in when we rebuilt it. all the bearings and rings are shot. lifters seem to be great so i still deciding if i want to swap what yall think?
Old 01-02-2011, 07:14 PM   #260
Stitch
Location: Where I come from, it's cornbread and chicken...
RJ, you can use the factory TBI from the 305 on the 350 without a chip change...you should be able to install the whole TBI top end including the heads on the 350...just fyi
Stitch is offline
Old 01-02-2011, 07:17 PM   #261
87 chevy silverado
i know chuck. thats wat i was trying to say.thanxs tho
Old 01-02-2011, 07:21 PM   #262
87 chevy silverado
just wish i had a serpentine belt system at this point
Old 01-02-2011, 07:33 PM   #263
spudz
spudz's Avatar
i know for a fact...that the injectors, knock sensor, and chip is different for 350s and 305 trucks.. whether you can run the 305 stuff on a 350 without it running lean or rich I dunno..... tbi is the same an all tho.
spudz is offline
Old 01-02-2011, 07:36 PM   #264
87 chevy silverado
im not sure what ur say in the last part.
Old 01-02-2011, 07:44 PM   #265
nbpro
Was years ago a used to be friend of mine replaced the rod knocking 305 to 350 and no other changes. It ran fine in the low end but if you kicked it when it got to 4000 RPM it fell flat on it`s face and went into a bog. We did a plug chop and found it was going dead lean. He later swapped the injectors over and this helped a great deal but it didn`t entirely cure it. Next came a 350 ECM and a knock sensor and that cured it. I`m not saying knock sensors can`t be interchanged but it was my understanding they work off frequencey and if that`s the case there is different frequencey`s created by different bore sizes. With the 350`s bore being considerably larger and since knock sensors are cheap, I`d swap it.
nbpro is offline
Old 01-02-2011, 07:47 PM   #266
nbpro
http://www.thirdgen.org/techboard/tb...-350-swap.html
nbpro is offline
Old 01-02-2011, 07:49 PM   #267
spudz
spudz's Avatar
the throttle body itself is the same but the injectors are different.
spudz is offline
Old 01-02-2011, 08:04 PM   #268
87 chevy silverado
ok makes scence now thanks for the info yall
Old 01-02-2011, 08:24 PM   #269
87 chevy silverado
Originally Posted by nbpro View Post
thanx much
Old 01-02-2011, 09:23 PM   #270
87 chevy silverado
Old 01-03-2011, 11:00 PM   #271
87 chevy silverado
well my dad took the tbi to work to clean it up and came home and told me we got to go to Pull A Part this weekend
Old 01-03-2011, 11:10 PM   #272
spudz
spudz's Avatar
why is that??? TBI messed up?
spudz is offline
Old 01-03-2011, 11:19 PM   #273
87 chevy silverado
yea i was clogged up bad supposedly. the iac was stuck all the way open and cousin my weird ideals at times. and wile we are the were going to pick up what we need to make the 350 run its best
Old 01-03-2011, 11:44 PM   #274
spudz
spudz's Avatar
yeah the pcv port is usually always clogged up too. easy fix tho. get you a tbi rebuild kit and go through it. Not too hard.
spudz is offline
Old 01-04-2011, 11:37 AM   #275
87 chevy silverado
well i need to git somethings any way so im not going to argue with a trip to p-a-p
Closed Thread
