#251 |
Re: The 6.0 Silverado Build
i dunno? i had just thought of it the other day when i seen the esky's reservoir on the side of the house. i have seen swaps where guys used it and even kept the little steam line that runs to it. just wondering is all...
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#253 |
Slots go on anything!
On the new trucks, the reservoir is where the radiator cap is, and it is pressurized. Using the original '86 radiator, it might not be an issue. WWBD (what would Bob do)?
1974 Jimmy- 5.3/4L80e/NP241 |
#254 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
The reservoir on the donor was not where the cap is and was not pressurized. Had the cap on the radiator. I will be using the stock radiator and overflow bottle from the 86.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#255 | |
#256 |
thanks for the info on the coolant tank guys. i had been wanting to ask but kept forgeting
#257 | ||
Next project: 1970 K10
![]() Mcbassin made a barbed adapter for me to run the steam hose to the heater hose nipple on the radiator. Works perfect! The Jags That Run website sells a slick ventable machined piece that splices in to the upper radiator hose that the steam hose attaches to. This isn't the one Mcbassin made, this was my first attempt, but it gives you the idea.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 03-31-2010 at 03:08 PM. |
#258 |
nice swap, this should make a sweet driver, with good manners and power.
what spark plug wires are those? |
#259 |
They are stock I believe. I will look tomorrow.
#260 |
Still Learning
Man you have been rocking on this project! It is coming along great! I like the painted parts it looks really good! You'll be running in no time!
#261 |
I sure hope so, thanks for the compliments guys.
#262 |
![]() Join Date: Apr 2005
Nice job! Looking forward to hearing it run.
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#263 |
Me too Rob, thanks alot.
#264 |
6.0L power.........
Looking good Josh. Keep the pics comming
What ever the mind of man can conceive......... he can achieve! ![]() My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914 1979 GMC Sierra 6.0 L 4L60E ![]() 1995 Mustang GT 347 ![]() |
#265 |
Josh will these work...
#266 |
Thanks Dennis, I'll send you a PM.
#267 |
Got the cable yesterday Dennis. Thanks alot buddy! 1 million imaginary rep points to you my friend. I was able to use the plastic clip like I thought I would and everything worked out great. I now have the Lokar throttle cable hooked up and had enough time to get the Lokar shifter linkage installed as well. Just harness, fuel tanks, and driveshaft and it'll finally be on the road again.
#268 |
VA72C10
![]() Join Date: Mar 2008
Cool!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#269 |
Turns out the driveshaft will fit perfect. 55 1/2 inches on the dot. Just as I measured. Talk about lucky. So, new u-joint for the rear and a conversion
u-joint in the front to hook up the huge yoke for the 4l80e and it'll be close to running again. ![]()
#270 |
#271 |
Never Satisfied
so remind me, what adapter plates did you use. i bought mine from the guy on ebay that someone on here recommended.
1973 4x4 Blazer- Parting Out 1986 LWB Silverado Undergoing LQ4/4L80E Swap '86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566 |
#272 |
I bought the adapter plates from a guy on ebay too. Dennis, the driveshaft will be different lengths based on wether you originally had a turbo 350 short tailshaft, turbo 350 long tailshaft, turbo 400, 700r4, etc... Mine originally had a th350c with a long tailshaft if I remember corectly. I just got lucky I guess.
#273 |
Got the driveshaft in last night and it fit great. I used a conversion u-joint to fit the 4l80e yoke to the c10 driveshaft. Precision u-joint number 447. Could also be listed as R882328 if anyone else needs the joint. Also got the bed off so I can do the tanks and clean and paint the frame. Stepped inside to call a buddy to come help lift the bed and when I came back out I found my little man helping tear the truck apart.
#274 |
Great pics buddy! Awesome to see the little guy out there helping. Also good to see you making some progress. It'll be running in no time!
#275 |
Not only is that a great pic of your little helper, but it's a great photograph. That's one to frame!
Did you get my PM about your phone message?
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
