04-29-2011, 11:04 PM | #1 |
Re: '72 Chevy SWB, Project Driver
Sounds great! What software package did you use and where did you get it?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-29-2011, 11:49 PM | #2 |
Has more rust than truck...
Thanks! She smooths out the more it runs. The software is ElmScan, its a scan tool that allows you to view data and read and clear codes. It doesn't have "tuning" capability like HPtuners or EFI live.
More info on it http://www.scantool.net/elmscan5-compact.html I bought it on amazon for $40 Amazon.com: ElmScan 5 Compact USB OBD-II Scan... |
04-30-2011, 01:52 AM | #3 |
just read the whole build. Awesome!!!!!!
04-30-2011, 11:45 AM | #4 | |
04-30-2011, 10:07 AM | #5 |
sounds great
04-30-2011, 12:29 PM | #6 |
Grandpa in the rustmobile...
Very very nice..
When do you think she'll be on the road?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-30-2011, 02:19 PM | #7 |
Thanks everyone. The tune was a mail tune by Black Bear Performance, great customer service. I hope to have it on the road by the end of May at the latest. Then I can start working on it like I originally intended(small weekend projects)
List for drivable. Fill with coolant Make push rod spacer for master cly Install/rebuild steering column and shift linkage Clean/paint driveshaft and press in U joints Figure out a air intake Install hood Mount TAC and gas pedal Clean up wiring in cab, behind motor and by computer. And I better get some exhaust on it |
04-30-2011, 05:32 PM | #8 |
Green club
Awesome!
Very cool, I love it and so will you Your fuel pump is mounted in the exact same place as mine it, so quiet you can barely even hear it prime. Depending on what direction you wanted to go with, the factory tube/MAF setup works excellent for my setup and looks factory.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
05-01-2011, 10:13 PM | #9 |
Thanks. I just want to drive the damn thing! Driveshaft painted, U joints in and installed....small steps.
Driveshaft being the prefect length was dumb luck. Never posted a pic of the hydroboost. I need a spacer between the hydroboost and the master cyl push rod. |
06-18-2011, 12:05 AM | #10 |
watched the movie for the first time it sounded awsome, shes quiet for open manifold! mine was alot louder!
05-01-2011, 10:33 PM | #11 |
Lookin' good..
We all envy your potential gas mileage...
05-05-2011, 06:21 PM | #12 |
Nice build! Will be interesting to see what kind of gas mileage you are able to pull off with the 4.8 and 4L80e.
05-15-2011, 10:08 PM | #13 |
Been too busy lately! Thanks guys, I hope to get 17+mpg
Made the spacer for the hydroboost. You can kinda see it in there TAC mounted Gas pedal mounted, still need to pick up some more bolts for it and clean up the wiring. Last edited by usmcchevy; 05-15-2011 at 10:08 PM. |
07-01-2011, 07:50 PM | #14 |
Kvn1011
[QUOTE=usmcchevy;4682317]Been too busy lately! Thanks guys, I hope to get 17+mpg
Made the spacer for the hydroboost. You can kinda see it in there cool build!! i picked up a hydroboost from a 94 astrovan last week and was curious on where you picked up your hardlines, or where you may have found your fittings?? and also what did you use for the extension to reach the brake pedal?? thanks kev here the one that i just got |
07-02-2011, 03:59 PM | #15 | |
[quote=kvn1011;4766622]
Thanks! The pressure line from pump to HB unit is from a 85 C/20 diesel. The pressure line from HB to steering gear is made from Jegs teflon AN-6 hose with adapters(forgot what size). The mounting plate and extension came from this guy: http://www.ifsja.org/forums/vb/showt...ght=hydroboost Then the little spacer I made that goes in the master cylinder hole is made from a cheap 3/8" extention 1 1/16" long. |
05-15-2011, 11:17 PM | #16 |
lookin good!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
05-16-2011, 01:49 AM | #17 |
^^^ x2!
05-23-2011, 10:48 PM | #18 |
Thanks guys!
Slight hold up, this is how I got my restored van tilt from ebay. |
05-23-2011, 10:57 PM | #19 |
sorry to hear about the tilt nobody wins on that kind of packaging very well detailed build your almost home !
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
05-23-2011, 11:43 PM | #20 |
Dang it!
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
05-23-2011, 11:49 PM | #21 |
dang plastic shift indicators.... why cant they have made them metal
05-24-2011, 07:42 PM | #22 |
made in america
truck is awesome man! ive been toyin with the same idea with my 66 but so far its all just pipe dreams. you do some good work and your super close. im tuning in for the grand finale
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree 2004 corvette- lowered, borla, tuned. slow my old girl 1966 c10- 305v8, t-5 sold |
05-24-2011, 08:27 PM | #23 |
6>8 Plugless........
Nice work! Sorry to see the column destroyed in shipment!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-24-2011, 11:16 PM | #24 |
Still Learning
Man that sucks on the new column. I have opened a bunch of broken parts packages. I know how this works. Hopefully they will make right with you.
05-25-2011, 10:06 PM | #25 |
Thanks. Still working with the guy on the column.
Got the gas pedal completly mounted. And got to use my birthday present from my wife! Last edited by usmcchevy; 05-25-2011 at 10:35 PM. |
