Old 04-21-2011, 01:27 PM   #251
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Daverods 52
Iron Duke is the name of the motor 2.5L.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-23-2011, 10:15 PM   #252
ruffrida2005
Re: Daverods 52
nothing happen this weekend? I got a thread for the dime.
Paul
Old 04-24-2011, 10:19 AM   #253
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Weekend not over yet.
daverod is offline   Reply With Quote
Old 04-24-2011, 11:20 PM   #254
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Filled a bunch of holes. Welded a bunch of cracks in my fenders. Stripped one front fender and painted it to look like the other old one. Turned out better than I hoped. Not done yet.
Old 04-25-2011, 08:12 PM   #255
99 to Life
99 to Life's Avatar
Re: Daverods 52
Love the trucks. all of them
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-26-2011, 10:37 PM   #256
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Got my bags and cups. Have no idea what the brackets/otherthings are for? Picked up a radiator. I'm thinkiing I'll need to get the outlet on the bottom rewelded to make it come out straight. Mounted my front cab mounts to my cab need to weld a piece of metal across the back suport before I can mount the rear one. Gave the ok on getting my engine work done. Still need a trans. I have a 350 and a 400 but I'm thinking a 700 would get better gas milage. Maybe a 2 for one deal.
Old 04-26-2011, 11:12 PM   #257
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Thanks Jeff. I did notice the back cap measurments should be 3.5 x 4. Nothing a cutting wheel could'nt handle. They worked great.
Old 04-27-2011, 10:12 AM   #258
Strodder
Daring to be Different
Strodder's Avatar
Re: Daverods 52
They are for relocating your shocks. But on our suspension you might not need them. It would depend on how much your going to drop it.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 04-27-2011, 02:57 PM   #259
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
thanks Dennis. I'll have to take a better look tonight. Both the brackets and the wing nut lookin things are for the shocks?
Old 04-27-2011, 03:12 PM   #260
MrDude_1
Re: Daverods 52
the original shocks were inside the springs.
obviously they dont fit there when you put airsprings in their place.
so the shock is relocated to the outside edge of the control arm.
the long part goes onto the frame and the top of the shock bolts to it.
im not postitive on the "wingnut wings", but they look kinda like the lower shock mount with bushings. i wouldnt be surprised if they fit inside the stock lower arm for bracing... you wouldnt use them in that case.. you also wouldnt use the lower cups.
as far as the shock mounts, I would look carefully at both the shock clearing the frame under travel, and the tire clearing the shock when turned at lock. if you're running larger wheels, you may want to recess the shock into the frame slightly so you dont lose turning clearance.
MrDude_1 is offline   Reply With Quote
Old 04-27-2011, 03:38 PM   #261
Strodder
Strodder's Avatar
Re: Daverods 52
On these trucks the shocks are mounted outside of the springs.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-27-2011, 03:58 PM   #262
ruffrida2005
Re: Daverods 52
Wrong crossmember Dennis, that's for a c10. remember he's using a s10.
Paul
Old 04-27-2011, 04:01 PM   #263
MrDude_1
Re: Daverods 52
oddly enough though, where the shock meets the LCA on that pic is very similar to how you would be mounting it to the S10 arm.
Old 04-27-2011, 04:03 PM   #264
Strodder
Strodder's Avatar
Re: Daverods 52
Duh, Sorry I stand corrected.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-27-2011, 07:28 PM   #265
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
It's OK we know, your old.: You still know a lot about s10's. You do still remember all that stuff right. Coolest old guy I know.
Old 04-27-2011, 07:29 PM   #266
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I'm thinking the wing nut things might weld on to the arms.
Old 04-27-2011, 07:42 PM   #267
ruffrida2005
Re: Daverods 52
yeah it might just weld to it. what I've seen some people do is either bolt the stud or weld it to the lca.
You still not get your rear kit yet? I've been messing with my rear bars, but I'm need to know where the bag sits on yours.
About to update pics of my truck.
Paul
Old 04-27-2011, 09:33 PM   #268
Strodder
Strodder's Avatar
Re: Daverods 52
I used to drill a hole in the lower arm, and weld a plate to reinforce where the bolt goes through. Even if the special shock bolt is welded in, it will crack the metal on the arm around the bolt.
BTW Thanks Dave. Why are you being so nice??? What do you want??
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-27-2011, 11:21 PM   #269
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Knowledge.
Old 04-27-2011, 11:33 PM   #270
Strodder
Strodder's Avatar
Re: Daverods 52
Originally Posted by daverod View Post
Knowledge.
I don't claim to know it all. I'm still learning myself. But will alway share what I think I know.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-28-2011, 12:09 AM   #271
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Daverods 52
How much time do you get to work on your trucks every week? Your rockin'!
Alan's Classic is offline   Reply With Quote
Old 04-28-2011, 09:43 AM   #272
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
Couple hours a day, 4 to 6 on the weekends. I run into a lot of dead ends and stuff that I'm not sure about so I jump around a lot. Anything to stay away from the bodywork and sanding. I have been getting some more parts ready to paint though.
Old 04-28-2011, 09:51 AM   #273
Strodder
Strodder's Avatar
Re: Daverods 52
I need to get on a regular schedule.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-28-2011, 10:06 AM   #274
daverod
SSN 706
daverod's Avatar
Re: Daverods 52
I heard this stuff works wonders. You need to eat the whole box to get started then about a half a box a day after that.
Old 04-28-2011, 10:11 AM   #275
Strodder
Strodder's Avatar
Re: Daverods 52
I don't need that yet. My poop comes out just fine, thank you.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
