#251 |
Re: Out of the Ditch = The Rebuild Begins ('72 GMC)
Yea you don't need anything but a standard oil pump.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#252 |
![]() Join Date: Dec 2012
Awesome work man. Loving the progress
1971 GMC Sierra 1959 GMC 100 |
#253 |
Metal work looks awesome!!
Scott |
#254 | ||
"I ain't nobody, dork."
Thanks you'se guys!
Ugh... welder crapped the bed last night. On/off switch no worky. Welder is 8 years old and out of warranty. Part is only 6 bucks. So I need to order it and put the new switch in. I'm only assuming that's what it is as the rocker in the on/off switch feels loose. If this doesn't fix it, I'll have to take it in to the dealer for repair. Which is about a 3 to 4 week turn around time. ![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#255 |
Take the switch out and test it?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#256 | ||
Will do that when I get home from work. The internal breaker wasn't tripped either. Hoping that it's just this bad switch.
Gary
#257 |
Well, was it the switch?
Skip
For those that have fought for it, Freedom has a flavor the protected will never know. |
#258 |
You are doing some good metalwork, I'm glad to see that you are still at it, keep up the good work!
#259 | |||
I forgot to come back here to tell you guys. Yep... I had tested the switch and it indeed was bad. Got a new one today finally from my Lincoln dealer (Central Welding Supply), installed it and I'm back in business!
![]() ![]() Quote:
![]() Gary
#260 | ||
Buttoned up the oil pan and pump issue today. So I'm hopeful to have the engine and transmission in the rig soon!
![]() Gary
#261 | ||
Spent a day and a half removing all of the thick black overspray on the lower half of the firewall from the factory undercoating. What a PITA. Used a heat gun and some soft wooden paint sticks as scrapers. Then after I got most of the thickest stuff off, I used rags soaked in mineral spirits to get the rest off. I used a little Goof-off too, but the mineral spirits worked better. Here are a few pics of the during and after.
This week should be engine and tranny install week! Slow and steady wins the war! ![]() Gary
#262 |
![]() Join Date: Oct 2011
Yeah, I have some of that on the lower cab/tunnel area of my truck too.
Was that simply overspray from the factory when they gave a couple of quick sprays from below onto the frame? or was it applied earlier and 'strategically'? Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#263 |
![]() Join Date: Nov 2004
Well, if you ever want to do a perfect factory color match... there's where you take your sample from
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#264 | ||||
![]() Quote:
![]() Gary
#265 | ||
Well whaddaya know... it still fits!
![]() Had 3 of my good buddies over last night for the reinstall of the 355 and TH350 back into the frame. What a happy day! ![]() Gary
#266 |
That's awesome! Glad to see more progress.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#267 |
Whoot Whoot!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#268 | |||
![]() Gary
#269 | ||
As promised... here is the skinny on the drivers side outer rocker panel. I received the panel from Wes at Classic Heartbeat lickety split. I did a trial fit and was pleased with how it was lining up. So after a few hammer shots here and there and some slight tweaking to get the front to line up, I had it fit in place with a few sheet metal screws in about a half an hour!
![]() I lined up the fender and the door, but need to get new hinges to set it right before I drill holes for "spot welds" and do the final weld in. I, for the life of me, cannot get the hinge pins out of these rusty old hinges. Even using the biggest BFH I own. So I have new hinges on order from Wes. Now for the particulars. The outer rocker panel I received from Wes is made by Key Parts/Tri-plus. The other I had was made by Dynacorn. After going back through some threads and doing more research, I found I had the "double sticker" panels that ended up being factory rejects that were put back into circulation. So if you get ANY panels with the double stckers from Dynacorn... avoid them like the plague! I have included some pics of the fitment of the new panel and a couple of the labels from each panel. It took me 3 days of fab work (probably about 10 to 12 hours) to fit the Dynacorn panel on the passenger side and I'm really not all that happy with it. But it is staying in place for now. So far I have half an hour into the fitment of this new panel from Key Parts/Tri-plus. So... there ya go! Thanks for the recommendation and fast shipping Wes! Gary
#270 | ||
Pics of the labels.
Dynacorn = 2 labels ![]() Key Parts/Tri-plus = 1 label ![]() Gary
#271 |
And the double labels are being sold by a number of different places, I won't mention where I got mine but lesson learned.
#272 | |
Skip
#273 | ||
I bought mine at Dreamers Rods and Pickups in Everett, WA. Whether they knew about it or not, I don't know. But I will buy stuff from them again if I need it. They are close enough for me to drive there. So I can now check to see if there are double labels on parts. I would also still recommend them for other parts if you live in the North Puget Sound area.
Gary
#274 |
I bought floor pans from Dreamers, Dynacorn, yea not very good stuff.
#275 | ||
So I got after the surface rust on the cab floor. Then sprayed some etching primer on the bare metal on the cab floor today. Next up will be some seam sealer and then a bit more primer. Then some paint. After that I will lay down some Fat Mat.
![]() Gary
