1972 C10 Parting
We are now selling parts removed from a 1972 Chevy C10 pick up with a 350/SM465. This truck was a 127 inch wheel base truck with factory leaf springs.
If you do not see what you are looking for in the thread, please ask as we have a huge inventory of parts for these trucks. Please post your interest and questions in the thread. "I'll take it" holds your item for 24 hrs to allow time for payment. We accept paypal, money orders or credit card over the phone for payment. All prices are plus shipping. As always, we thank you for looking, Thomas Photo 1: small block fan shroud, non AC, nice...$ 45.00 air cleaner housing, correct for 69-72 small and big block...$ 35.00 air cleaner housing spacer with hose...$ 22.50 brake/clutch pedal assembly...$ 45.00 speedometer cable for 2wd 350 4 speed (SM465)...$ 15.00 gas pedal assembly without cable...$ 30.00 gas pedal cable...$ 15.00 2wd 4 speed (SM465) floor hump...$ 35.00 4 speed (SM465) shift handle with boot and ring and handle, very minor tear in boot, under fold...$ 40.00 complete clutch pedal linkage from clutch pedal to throw out fork, including the frame bracket and return spring...$65.00 front bumper brackets...$ 15.00 each left and right wiper transmissions, nice...$ 15.00 each door latches, left and right...$ 30.00 LH 25.00 RH air diverter??? for exhaust...$ 12.50 clutch/brake pedal stop bracket...$ 10.00 steering column, black for 4 speed, decent driver condition...$ 85.00 steering wheel, black, good project for a restoration, horn cap not included but available ...$ 40.00 sun visors, decent drivers with some clip marks...$ 20.00 each RH vent window, decent chrome, clear glass, need rubber, rust on the frame...$ 30.00 left inner fender brace...$ 7.50 Photo2: Complete drive line with center bearing bracket for 127 inch wheel base, small block with SM465 trans. Comes with bracket for cross member...$ 75.00 Complete disc brake conversion, includes, cross member, coils, upper and lower control arms, spindles, rotors with bearings, dust shields, calipers, idler arm, inner and outer tie rods. Center link not in the photo but will make one available with the sale...$ 250.00 (2) small block 4 speed transmission cross members (same as 3 speed manual trans) nice and clean...$ 65.00 each Photo3: Hood hinges, clean and ready for your finish...$ 30.00 each 350 engine stands, nice...$ 30.00 68-down single groove water pump pulley...$ 20.00 single groove crank pulley...$ 12.50 rear spring hangers (forward position)...$ 25.00 each rear spring hangers (rear position)...$35.00 each leaf spring shackles...$ 15.00 each rear upper shock mount brackets...$ 20.00 each door hinges, left and right, upper and lower, nice set...uppers 12.50 each lowers 10.00 each park brake pedal assembly...$ 25.00 127" wb 2wd park brake cable set including links and guides. does not include rear cables to backing plates...$40.00 complete under bed spare tire carrier with upper frame brace...$50.00 rag joint...$ 25.00 Photo4: (4) 15 x 6 5on5 steel wheels, tires will be dismounted for the sale, decent set...$ 85.00 Inside heater box...20.00 dash pad, black. has a split on top, curled ends but overall decent..$ 22.50 parchment door panels, decent driver set, no cracks, typical chalking condition...$ 50.00 Photo5: Front fender spheres, left/right, very nice...$ 20.00 each RH and LH Upper door trim, nice...$ 20.00 each upper cab trim, left/right...5.00 each door strikers, left/right with shims and correct bolts...$12.50 each headlight bezels, decent driver set...$ 25.00 or 15.00 each door edge guards, left/right, typical condition....$ 20.00 wiper arms...$12.50 each inside rear view, typical deterioration...$10.00 wiper motor...$ 25.00 outside door handles, left/right, Very nice driver quality...$ 65.00 pair park light housings...$12.50 each park light lenses, one has a chip on the edge and one has a rub mark...$10.00 each. I may have better ones, priced depending on condition. reverse light housings, left/right...$ 5.00 each tail light housings, left/right...$ 10.00 each tail light lenses, left/right not perfect but nice...$ 15.00 each reverse light lens, passenger side, decent driver...$ 8.00 center grill brace with hood latch...$ 25.00 hood latch striker...$ 10.00 oil fill tube with nice cap...$ 20.00 heater control, nice, tight with good arms...$ 50.00 front amber side markers, decent driver condition...$ 12.50 each rear red side markers, decent driver condition...$ 12.50 each ash tray with bracket...$ 15.00 head light switch...8.00 head light switch knob, deluxe...$3.00 wiper switch...8.00 wiper switch knob, deluxe...3.00 parchment visor hooks...4.00 each cargo light assembly chrome pitted driver quality complete with wiring and switch...$ 25.00 interior dome light, average condition with cover (cracked)...$ 8.00 cig lighter with housing...$ 15.00 cig lighter wiring harness...$ 6.00 radio power wire...$ 6.00 tail gate straps...$ 15.00 each custom 10 emblems, pair...$ 12.50 each 8-350 emblems, pair...$ 5.00 each deluxe fender emblems, pair...$ 5.00 each upper radiator supports for 3 core tank...$ 7.50 each inside door handles, decent drivers...$ 7.50 each window cranks, decent drivers...$ 7.50 each right door relay, nice condition...$ 10.00 under steering column cover...$ 5.00 air cleaner adapter...$ 7.50 washer bottle with bracket...$ 10.00 front light harness, nice, no splices...$ 60.00 engine harness, (4 speed) needs yellow coil wire repair on both ends. perfect for HEI converted truck...$ 40.00 under dash harness for gauges, nice...$ 65.00 double groove water pump pulley...$ 15.00 tripod mount mirrors, aftermarket heads and elbows, original brackets. nice glass...$ 40.00 very nice pair of exhaust manifolds, no cracks or heat check. these have been glass beaded...$ 125.00 pair Last edited by DLTruck1973; 06-04-2015 at 12:37 PM. |
Truckin' Krazy
![]() Join Date: May 2000
Re: 1972 C10 Parting
How much on the door panels thomas?
I see now, I'll take those when I'm up there> Thanks, Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
Photos of trim for kcsa75
This trim is super nice with only very minor blemishes. I good paint and polish and it would look very nice. Thank you, Thomas |
is this trim spoken for? if not what are you askin for it.
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Keith,
I have a pass on the trim so you are up. I will get you a ship quote for the air cleaner, spacer, upper trim do you want the cab pieces as well?), a equally nice set of window cranks. The bow tie is a GM part. I will give you a price total for everything plus shipping. If you do not want the bow tie, please let me know as soon as possible. I have other interest. Thank you, Thomas |
#7 | |
PITbut
How far are you from seatlle washington?
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
#8 | |
I would need full payment to pull it and cover paypal fees which would be $7.50 so $257.50 total. We are about 5 - 5.5 hrs from Seattle on Hwy 99S just a couple of miles north of Eugine airport. We are open until 5 pm Mon - Fri 91720 Hwy 99 S Junction City, OR 97448 Let me know, Thank you, Thomas |
how about the plug/connector and wires that go to the ac compressor. looks like a flat style connector...
can I get better pics of door handles inside and out and window rollers? Also pics of 8 350 emblems Thanks
i'll take the air cleaner and air cleaner housing spacer in pic 1. let me know shipping to 77504.
also what are you askin for the grill bow tie in the last pic? thanks keith
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 05-14-2015 at 07:20 PM. |
#13 | |
grill bow tie is $35.00. I can get you a shipping quote tomorrow morning if that is OK. |
#14 |
tomorrow will be fine, what is the condition of the bow tie?
#15 |
#16 |
Here are photos of the window cranks. Some good polish and these would be real nice. The knobs are nice and tight as well.
Thank you, Thomas |
#17 | |
Thank you, Thomas |
#18 |
![]() Join Date: Feb 2013
I'm interested in the high hump, brake cluch assembly, colum, shift handle and boot, and the stop bracket.
Basically all the parts to swap in the Muncie ![]() Let me know what the package price shipped to 34606 would be, I can do a commercial address if it helps as well. Andy |
#19 | |
Are you installing a Muncie or the Saginaw SM465 trans in your truck? The shift handle I have is for a SM465 trans. Also, do you need the clutch linkage from the pedal to the throw out fork? Let me know. I can work on a shipping quote for everything tomorrow for you. Thank you for the interest, Thomas |
#20 | |
I'm going to try and track down a Muncie locally, I figure I should be able to find something to rebuild without to much issue.
yes I would need the clutch linkage. let me know. Quote:
#21 |
I'll take the sun visors and please put me in line for the door panels. I'm sure t korinik's going to take them but just in case.
72 GMC Ochre and White 72 GMC Ol' Blue |
#22 | |
#23 |
That's good. I'm interested in the other set of door panels. Just send me a price and pic when you get time. I also posted on the heat stove post if you want to combine.
#24 | |
Thank you, Thomas |
#25 | |
