12-09-2022, 04:22 PM | #251 |
2WD Jimmy
Re: My winter project
If those seals ever come loose, this will do the trick. Much stronger than the regular 3m stuff.
12-09-2022, 04:45 PM | #252 |
Thanks, Jim.
Just for the fun of it |
12-09-2022, 04:53 PM | #253 |
Tom I used the 3M, and seems to stick good but I had it everywhere. I will give that a shot if I have problems.
01-18-2023, 10:23 PM | #254 |
Fitting the carpet and cutting holes has taken a lot of time.
01-19-2023, 08:25 PM | #255 |
Awesome work
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-05-2023, 11:22 PM | #256 |
2WD Jimmy
Gonna have this puppy ready for the national show in Salt Lake at end of June?
04-06-2023, 08:24 PM | #257 |
Tom won't make it, still a ways out. I'm in sanding the old paint off and some bodywork stage. I plan to paint myself because of the cost. I did put a fuel tank skid plate on, it didn't have one to start with but I had it so.. think it needs one.
05-08-2023, 08:24 PM | #258 |
I got the heat stove on, sometimes just little details.
05-09-2023, 07:27 PM | #259 |
Great job, I always enjoy watching your attention to detail
06-17-2023, 08:34 PM | #260 |
Thanks, Jim, I moved it out and dusted it off. I was bored and don't have a bunch of dollars for chrome plating interior pieces so for now I painted it (chrome) yes I know but I had to know how it would turn out.
06-17-2023, 08:45 PM | #261 |
Another one.
06-17-2023, 11:19 PM | #262 |
Chrome paint looks pretty good in the pictures!
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
11-07-2023, 09:05 PM | #263 |
Very small update: bodywork stuff so it takes me a long time. I did get epoxy on.
11-07-2023, 09:11 PM | #264 |
Few more.
12-04-2023, 09:35 PM | #265 |
I started setting some trim pieces in place, all the original holes were welded so should drill new holes or try the adhesive clips? I have read some stuff about the stick-on kind but has anyone had luck with them?
Thanks guys.
Just for the fun of it Last edited by 7D2N; 12-05-2023 at 09:01 PM. |
12-05-2023, 10:04 PM | #266 |
I have been working on my wing windows. I'm pleased with how it went with the new seals.
12-19-2023, 08:56 PM | #267 |
2WD Jimmy
All the new vehicle trim is affixed with tape. I don't think you need worry. What's the worst that could happen? If it comes loose, then drill. I think you'll be fine.
12-19-2023, 09:53 PM | #268 |
I think the 3m VHB double sided tape is what you need. Have you restored any trim? Any ideas how to get dents out etc....
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
12-20-2023, 08:31 AM | #269 |
That anodized aluminum trim is a huge PITA to restore. It get cloudy with exposure, dent and scratches easily. About the only restoration you can do with them is apply new woodgrain tape to them and repaint the black if they are otherwise nice. I have seen guys strip the anodizing off, then polish the aluminum to a high shine. Without the anodizing in place, the trim will dull easily just with the ambient humidity.
Fortunately, there are a lot of NOS trim out there for most of the sections. The hardest ones are the Blazer specific forward quarter panel pieces. Mar-K makes good repro trim if you can't locate NOS. As for the retention of these, I would stick with the OEM steel clips, either the threaded or push in variety depending on location. Some locations on the trim used the plastic adhesive clips, mostly in the middle of the longer side trim such as the door and quarter panel pieces.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
12-20-2023, 09:20 PM | #270 | |||
01-21-2024, 01:17 PM | #271 |
Well, I've been putting off the door repairs, finished welding the cracked hinge area and the screw holes I will get the filler going.
01-21-2024, 01:34 PM | #272 | |
Looks great! I wish I was better at body work. I would have saved myself a fortune. I read about your dilemma on the side trim. I went to ebay and purchased extra plastic adhesive pieces, and I ordered some more small black screws that match the original screws. I plan on going the adhesive tape/screw route at this point. Although, since you are still in body work, you could make some Cardboard or Construction paper templates of the trim with the holes marked on the paper & drill them like that? They would be easy to tape to the body & line up. Have a good day, looking forward to the next update!
Full top blazer or bust.... |
01-21-2024, 07:02 PM | #273 |
01-25-2024, 10:41 PM | #274 |
I'll have to look, this is the finished repair of the cracks.
01-25-2024, 10:55 PM | #275 |
I started the filler and sanding.
