Old 04-01-2017, 11:06 AM   #251
MMcMasters
MMcMasters's Avatar
Re: 1970 Med Olive Project
That's good to know, thanks Rob! My VA kit won't be here until first of the week. I'm going to try to find some local today.
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 04-01-2017, 11:09 AM   #252
Jason7121
Jason7121's Avatar
Lowe's has those push nuts if there what I'm thinking of.
Jason7121 is offline   Reply With Quote
Old 04-01-2017, 11:17 AM   #253
MMcMasters
MMcMasters's Avatar
I'm headed there now
Mike
Old 04-01-2017, 11:21 AM   #254
Jason7121
Jason7121's Avatar
Good luck hope you find them
Old 04-01-2017, 01:46 PM   #255
MMcMasters
MMcMasters's Avatar
I found the push nuts at my local farm store and I have it back together up to the point where the faceplate goes on. The Vintage Air system has a new faceplate so I will wait for that to finish assembly.
Mike
Old 04-01-2017, 02:00 PM   #256
Jason7121
Jason7121's Avatar
Awesone mike glad it worked out
Old 04-01-2017, 02:19 PM   #257
MMcMasters
MMcMasters's Avatar
Thanks Jason!
Mike
Old 04-02-2017, 09:03 PM   #258
sprint_9
sprint_9's Avatar
Great looking build you have going. Saw some ideas for my own, think Ill probably smooth my core support too, that looks so much better with those creases smoothed out.
sprint_9 is offline   Reply With Quote
Old 04-02-2017, 09:07 PM   #259
GR8-68
GR8-68's Avatar
Funny thing is I looked at my aftermarket support and it isn't like that on it, it is smooth
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 04-02-2017, 09:09 PM   #260
Phill0406
Phill0406's Avatar
Looking good!
Phill0406 is offline   Reply With Quote
Old 04-03-2017, 11:33 AM   #261
MMcMasters
MMcMasters's Avatar
That is definitely the ugliest core support GM has ever produced
Well at least the aftermarket figured it out
Originally Posted by Phill0406 View Post
Looking good!
Thanks man!
Mike
Old 04-04-2017, 09:00 PM   #262
MMcMasters
MMcMasters's Avatar
I'm kind of in limbo waiting on a few pieces to show up on the porch so I got a really good start on bodyworking the firewall. I have a few pin holes and a couple low areas to work yet but it looks really good considering as a body man, I'm a hack. Vintage Air should be here this week and hopefully the pieces I have at Powdercoat are finished this week as well.
Mike
Old 04-04-2017, 09:30 PM   #263
GR8-68
GR8-68's Avatar
Firewall is looking great
Larry
"Project 68"
paypal.me/ldgrant
Old 04-05-2017, 08:21 AM   #264
Bennett68C10
Bennett68C10's Avatar
Firewall looks great Mike, but boy am I dreading doing that again
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-05-2017, 09:31 AM   #265
MMcMasters
MMcMasters's Avatar
Thanks Larry!
I hear ya! My biggest problem with it is I just don't like doing bodywork and its not fun for me.
Mike
Old 04-05-2017, 09:44 AM   #266
Lorne
Lorne's Avatar
Mike,
Not only can I not do bodywork, but I pretty much can't do anything but pay someone to do all the work for me haha..
I know what I can do is burn the tires off of the truck when it's done!!
Lorne
Si vis pacem, para bellum
48 Ford F100 Panel
67 Chevy C10
71 Camaro RS
73 Camaro RS (in progress)
Lorne is offline   Reply With Quote
Old 04-06-2017, 03:15 PM   #267
knomadd
knomadd's Avatar
If you haven't installed the vintage air unit, I highly recommend you STOP working on the passenger side of the firewall. If you don't want two bolts poking through, you'll need to do some welding and you'll ruin your bodywork. If you're good with the bolts, then by all means, proceed. The kit is set up for 4 connections for the heat and a/c stuff, all arranged vertically, but those can be modified and moved, but the mounting brackets are kind of stuck where they end up. I just did that mod to my firewall, so I know about what you'll be going through. I just want to save you from having to redo something if you really want to get rid of the two mounting bolts on the engine side of the firewall.
Nice work thus far!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-06-2017, 03:34 PM   #268
MMcMasters
MMcMasters's Avatar
Nice work thus far!
Duane,
I appreciate your advice sir. I have not done any body work on the passenger side yet. I have been waiting on the corner firewall piece from PB which should be on the porch when I get home. My Vintage Air came yesterday as well so I should be able to make some good progress this weekend.
So did you just weld the evaporator bracket to the inside of the firewall instead of using the bolts?
Mike
Old 04-07-2017, 07:02 AM   #269
builtbyKane
builtbyKane's Avatar
Your truck is turning out great. I am enjoying every subtle detail. I may have missed this before but do you plan to cut down the long bed or get a new short bed?
builtbyKane is offline   Reply With Quote
Old 04-07-2017, 08:09 AM   #270
MMcMasters
MMcMasters's Avatar
Thank you very much! I definitely want to cut down and retain the original bed if at all possible.
Mike
Old 04-07-2017, 10:34 PM   #271
MMcMasters
MMcMasters's Avatar
All of this monotonous work on the firewall is finally paying off. I received my firewall piece form PB yesterday. They make it oversize so I made a template out of poster board, trimmed it to fit and got it welded in. I finished the wire gutter cap and body worked the passenger side. I have great respect for paint and body guys because they make it look so easy, its not!
Then it was primer, block....repeat
Next was some primer sealer and I taped off the toe board area of the firewall and sprayed the lower section with bed liner. It works great as a stone guard and the texture looks good to me.
I also got the floor cut tonight and the mounting holes drilled for a factory high hump. Tomorrow I will finish masking the cab and I will put color on the firewall. It has definitely been a good two days.
Mike
Old 04-08-2017, 01:24 AM   #272
Jason7121
Jason7121's Avatar
Looks great to me! Keep us posted.
Old 04-08-2017, 06:03 AM   #273
GR8-68
GR8-68's Avatar
Looking great Mike, I need to get back at it and catch back up to you. I lost some time these past couple weeks
Larry
"Project 68"
paypal.me/ldgrant
Old 04-08-2017, 06:44 AM   #274
Lorne
Lorne's Avatar
Looking awesome Mike!
Lorne
48 Ford F100 Panel
67 Chevy C10
71 Camaro RS
Old 04-08-2017, 07:39 AM   #275
Metaldoc
Metaldoc's Avatar
That's a good idea, I did mine like that and the road noise is a lot quieter
Metaldoc is offline   Reply With Quote
