Old 01-14-2018, 11:34 PM   #251
1971_c10
1971_c10's Avatar
Re: C10CJ: A Pro-touring '71 Stepside on a No Limit Pro-C10 Chassis
Originally Posted by nuke1 View Post
Great build so far!!!!!! loving how it is turning out.
Thanks James!
Chris
Build Thread for my '71 Pro-Touring: http://67-72chevytrucks.com/vboard/s...d.php?t=722029
My C10 has it's own facebook page! www.facebook.com/c10cj - it is a public page so no facebook account required to browse through.
1971_c10 is offline   Reply With Quote
Old 01-14-2018, 11:47 PM   #252
1971_c10
1971_c10's Avatar
Update ...
I'm getting really close to firing this thing up. The electrical system is 99% done. A few ground wires to finish off and then testing. After testing, finish up the wire braid and get everything mounted with cushion clamps.
Over the last few days I completed the PDM.
Here it is painted up. I also added a mounting hole for my coolant recovery tank.
The back side.
Start of wiring. All metri-Pack 280 terminals so easy to assemble. Just takes time.
All wired up.
All the fuses, relays and circuit breakers installed. All in all this set of boxes houses 12 additional circuits and 6 relays, as planned. Here you can really see the amount of expansion room I've got. I could have crammed it all in one box, but I figured I'd have some expansion room. Notice I also had to go from one hole to 2 holes. Lots of big wires in the bottom hole, like several 10 ga and one 8 ga. So if I need to expand, probably wind up with a 3rd hole or make the top one a little bigger.
Chris
Old 01-15-2018, 12:08 AM   #253
1971_c10
1971_c10's Avatar
To feed that PDM, I needed a power feeding setup. If you recall from way back when, I mentioned I was going to install some studs so I could easily move the battery once I figure out where I want it. So here's the final solution. I still have some cleanup work to do, but this is good enough for testing and to get the engine fired up. I need to fab a new battery box/hold down as the current one over the years suffered from corrosion and was very thin in part. I wound up blowing the factory battery mount apart by drilling the spot welds out. The bottom was the only piece in bad shape. I'm currently thinking about getting one of these pre-cut units and welding it to the factory side pieces.
So here's the power feed board. There are two different power feeds here. The primary feed, which is the two large studs at the bottom, provide power to the fuse block and PDM as well as tie in the alternator. That circuit is protected by a 200 amp midi fuse. The other feed is the ECU feed. The ECU wants clean power. So to get clean power it needs to go straight to the battery. So that's the MAXI fuse up top. The MAXI provides power to the ECU and vintage air/Dakota digital controllers. It is a completely separate power circuit from everything, so the possibility of getting disrupting electrical transients should be minimized. Looks a little messy because I do plan to either paint or polish that aluminum backing plate so it will come apart shortly after I get the engine fired up. Plus found out my engine ground is too short if I put my inner fender in, but that's an easy fix.
I also got the transmission harness redone. Going to EFI, I'm letting the ECU control the bits of the trans it can control, which in this case is the torque converter clutch. But, I had to re-wire the guts and redo the harness to send the 4th gear signal to the ECU and so forth. It's also got my speedo tied in.
And the last harness to make was the fuel tank. Here it is. I may wind up dropping the tank so I can put a cable clamp down in there to keep the connector from beating itself up. Overall I'm pretty happy with how the electrical is turning out.
A couple shots just showing some more of the routing. I'm using the Painless Performance Classic Braid to cover everything up. I really like the look of it and it seems to almost look OEM like. Or maybe that's my OCD. Ha!
Chris
Old 01-15-2018, 02:22 AM   #254
nuke1
nuke1's Avatar
Chris, gotta love how wiring can be so time consuming hey, I try to tell customers that is is the worst job on the entire vehicle, so tedious and time consuming just to make it all look great, hidden and accessible at the same time. Love it btw!!!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-15-2018, 06:54 AM   #255
crakarjax
crakarjax's Avatar
Originally Posted by 1971_c10 View Post
Right on! Maybe we could do some code trading if you're up to it. Of course, I need to write some first. Are you switching to python b/c you're not familiar with the depths of C? In the arduino IDE, just make your own header file and include it and BAM! you've got the world of C open to you (until the compiler gets stuck). I find C much more realtime friendly and I can control memory way better with C if I need to. Or if you're running out of space in the Arduino (assuming you're using an Uno or similar?) the Teensy is an arduino conforming board but that's it. 32 bits, 96 MHz clock speed, tons of memory and I/O out the wazoo on a smaller form factor. The thing that amazes me is how fast the Teensy boots compared to my Uno. I have a simple test code for RGB pixels, and when I plug the Uno in to the USB it boots in about a second from once the USB makes initial contact. The Teensy boots and is running before I even get the USB fully plugged in. You could also check out the adafruit feather series boards as you can get wifi and bluetooth on those things. Seems you could replicate the Accuair e-level setup if you got sporty enough (and wanted to go that far). The boot time is the only thing I'd caution on the Pi. Even stripped down, the Pi still takes several seconds to boot. I digress ...
Yeah, would love to collaborate! That teensy looks awesome, I really needed more I/O ports and you're right, that thing has plenty! I'm most likely going to do a hybrid arduino/pi setup because of that startup time issue (which I hadn't though of!), the lack of many I/O ports on the pi, and the expected complexity of the codebase. I wrote a library for the arduino to do wear-leveling in the EEPROM because I was going to store ride height data in it, but after finishing that project I realized how much time I had just spent so that I could do something that is natively available on the pi... and I hope to run a ton of stuff on the pi, be able to update the code remotely via wifi, put together a bluetooth app etc..
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-16-2018, 11:57 PM   #256
1971_c10
1971_c10's Avatar
Thanks again! Yes Sir! You know it!
Chris
Old 01-17-2018, 12:04 AM   #257
1971_c10
1971_c10's Avatar
Nice! I took a scan at the lib, you already know what I'm talking about! And I don't mean to knock the Pi. I love my Pi B v2. It ran my Christmas lights this year like a champ and is still out in the garage chugging away running a flood light until I pull it down. I'm hoping things settle down so I can tackle some of these other projects. You'll see the excitement in the next post ...
Chris
Old 01-17-2018, 12:32 AM   #258
1971_c10
1971_c10's Avatar
Ok all ... The electrical system is FINISHED! and TESTED!
It's been a long time since these gauges saw power. I've got all the circuits I can test before running the engine tested. I've intentionally had the fuel pump disconnected as there is no fuel in the tank and the pump would not like that.
Need to figure out where these two are going to go. That little Dakota Digital Heater/AC control is going to be awesome. Just set a temp and it adjusts the unit to maintain that temp.
Soon ... that tach will say something other than 0 RPM.
Priming the LS ... yep, it can be done. I followed some directions here loosely, and did not put a hose on the oil pan. That was why their system didn't work as it restricted the flow too much. They also used too large of a bucket so the oil pickup would come uncovered. My mods:
-3 gallon bucket
-No return tubes, just a funnel under the oil pan to catch the oil and return to the bucket
-Total cost, about $60.
The SBC oil pump is perfect. Why? because a 1/4" NPT taps goes right in to the pump output without any drilling. Seriously, I put the pump in a vise and tapped away. It was harder to install the pickup tube.
Oh, and boy was that fun at the autoparts store getting the SBC oil pump. I walked in, there were 3 of them, a younger one helped me (let's say early 20s):
Clerk:How can I help you?
Me: I need a SBC oil pump.
Clerk: What year vehicle?
Me: (holding a straight face) A 2017 Home Depot 3 gallon bucket
Clerk: (just stared at me)
The others: one started laughing, the other was dumbfounded
Me: (I finally smiled)
Clerk: Ok, seriously...
Me: I was being serious.
Clerk: (finally started laughing)
Me: It's a priming bucket for an LS
Clerk: I gotcha
Me: Let's just go with a 1972 Chevy 1/2 ton van with a 350
I'll say, this thing works great so far. I was getting around 40 psi of oil pressure as measured through the gauge/ECU. LS engines are actually a bear to prime. They can take over 15 minutes of constant priming and manual crank rotation to get all the circuits primed. Hence why many guys just pull the plugs and roll it over until they get pressure. I'm old school I guess.
The bucket just feeds right in to the plug on the driver side of the block at the oil pump.
Oh, and I did roll this thing over briefly when I checked the starter. Um, it's like a dragon stuck in a cave fighting to get out. I mean, it hit hard. I could feel EVERY.SINGLE.COMPRESSION.STROKE. Three to be exact. I don't know if my 10 yr old yellow top Optima is going to like this one.
Chris
Old 01-17-2018, 10:19 AM   #259
67cheby
67cheby
67cheby's Avatar
very cool build, nice work on all the details!
67cheby is offline   Reply With Quote
Old 01-17-2018, 10:53 PM   #260
1971_c10
1971_c10's Avatar
Thank you sir! Much respect for you and your builds!
Chris
Old 01-18-2018, 11:12 AM   #261
aggie91
I'm just glad to be here!
aggie91's Avatar
Just finished checking out your build thread. Great job. Thanks for sharing the info on the PDM's. Looking back, I wish I would have done it with the parts you used. I did a quick and dirty set up that works, but just does not look as clean. I might have to redo it some day when I decide that looks are important...lol.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-18-2018, 05:11 PM   #262
1971_c10
1971_c10's Avatar
Thanks Karl! An old quote (not mine) from back in the day seems fitting ... "Looks don't make it go and paint just make it slow" -on some dudes drag car back in the '90s at Bandimere Speedway in CO.
Chris
Old 01-22-2018, 12:03 AM   #263
1971_c10
1971_c10's Avatar
C10CJ is ALIVE!!!!
That Don Hardy Stroked LS fired right up the 1st try!
A major milestone for the truck.
Now setting the sites on the LMC C10 Nationals in May. Who wants to join me?
Chris
Old 01-22-2018, 08:21 AM   #264
jus2qwk
jus2qwk's Avatar
coreyjonesdesigns sells panels that go in place of the factory heater controls that fit that heater control
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 01-22-2018, 11:39 AM   #265
gringoloco
A guy with a truck
gringoloco's Avatar
Beastly, congrats!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-22-2018, 09:20 PM   #266
1971_c10
1971_c10's Avatar
Thanks for the info! To be honest, I haven't decided where to put it as I really want it where the ash tray is located. So as part of phase 2, I'll probably (purists cringe) cut out the whole center area and make a new layout that houses a double DIN radio, the AC controller, and then blends down to the console. But that's a few years down the road at this point, but things change and a good buddy now has what he needs to make dies for his pullmax. Hence why I'm dragging my feet some.
I've never dealt with aluminide material. Can it be sanded smooth? I'll definitely keep you in mind though when I get to deciding on something for the near term.
Originally Posted by gringoloco View Post
Beastly, congrats!
Thanks Chris!
Chris
Old 01-23-2018, 04:30 PM   #267
jus2qwk
jus2qwk's Avatar
thats cool brother. just thought Id pass along some info. yes it can. its super easy to sand.
Corey Jones Designs
Old 01-23-2018, 11:15 PM   #268
1971_c10
1971_c10's Avatar
Thanks again! If I stick to the "stock" location you're at the top of the list for sure!
Chris
Old 01-23-2018, 11:17 PM   #269
1971_c10
1971_c10's Avatar
Hey all ... I tossed together a short video on that priming bucket in case you have some interest in seeing a few more details.
Chris
Old 01-23-2018, 11:26 PM   #270
crakarjax
crakarjax's Avatar
Ok, back to seriousness. Here's the PDM parts list
Just re-read this and wanted to say that you saved me like 5 evening of research with that post, I'm always unfortunately becoming an expert on mods I make and that takes up most of the time in my build. So thanks, that level of detail is much appreciated!
Old 01-23-2018, 11:38 PM   #271
1971_c10
1971_c10's Avatar
No Problem! Glad to help!
Chris
Old 01-27-2018, 01:24 AM   #272
1971_c10
1971_c10's Avatar
Ok Guys! It's Official!! C10CJ is signed up for the C10 Nationals May 4-5 @ Texas Motor Speedway. The first major goal has been set!
Chris
Old 01-27-2018, 07:27 AM   #273
Ramjet51
C10CJ is ALIVE!!!!
C10CJ 1st Fire Up - YouTube
Fan-damn-tastic Chris!!! You had to be just trembling when that happened! This is one prime truck and we appreciate all the great information, I wish you speed in making that May date....you’re giving me ideas for a trip! Received my Waytek order the other day.....going to be fun! Thanks a million...
You'll never know unless you try
Ramjet51 is offline   Reply With Quote
Old 01-29-2018, 12:55 PM   #274
crakarjax
crakarjax's Avatar
Originally Posted by kxmotox247 View Post
Do you remember what your overall rear end width was with your brakes? I ordered mine a little more narrow than stock to get maximum backspace.
Out of curiosity, why would you want maximum backspace? I know on the front you'd want a backspace that minimized scrub radius if possible but I've never given the rear much thought.
Old 01-30-2018, 05:31 PM   #275
knomadd
knomadd's Avatar
Congratulations Chris! That's a great milestone achievement!
I'm guessing here, but since he said he ordered a slightly narrower than stock rearend, I think he meant minimum backspacing to get a bigger wheel lip.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
