Old 07-01-2019, 06:37 PM   #251
TA_C10
TA_C10's Avatar
Re: 1972 SWB Build
Thank you sir
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 07-15-2019, 04:38 PM   #252
beaterku
beaterku's Avatar
Re: 1972 SWB Build
I've been driving it for the last couple weeks when the heat is not too oppressive. Still have a few kinks to work out. My brakes stop the truck, but lack the power to really stop it to the full extent the Wilwood's should. I am only pulling about 14.6" of vacuum. I have power bled the brakes, manually bled and swapped boosters to see if I can get any improvement. I talked with Wilwood and they said I should go to full manual or hydroboost. I am leaning towards the hydroboost. I've been digging in to them and doing some research. Simple setup, just not cheap. We shall see. Maybe a project for the winter.
I've also got a weird blip in the idle when first starting it up. It idles up to 1700 for a split second and then drops in to it's normal startup routine. It acts like there is a slight vacuum leak. I need to dig in to it and check for leaks. Hopefully something simple.
Other than that, just trying to put some miles on it. Went to a car show on Saturday night. Didn't win anything, but had a line of people asking about all aspects of the truck. That was pretty cool.
beaterku is offline   Reply With Quote
Old 07-16-2019, 01:32 PM   #253
TA_C10
TA_C10's Avatar
Re: 1972 SWB Build
Looks great man. Really enjoy all the detail. Where are you getting your battery cables? What sizes are you using for the main feeds like battery to - ALT, STARTER, ETC. I'm still going through your thread so apologies if you posted this info, I may be jumping ahead of my progress ...
"It's only money".
Old 07-16-2019, 03:02 PM   #254
beaterku
beaterku's Avatar
Re: 1972 SWB Build
The battery cables are both AC Delco side post
Positive: 2SD60XA
Negative: 2SD45X
Alternator to battery is from American Autowire: https://www.americanautowire.com/sho...connection-kit
Starter wire was part of the American Autowire body wiring harness. I believe it is 12ga. Same for the bulkhead feed wire from the starter, it is a 10ga.
Hope this helps.
Old 07-16-2019, 09:27 PM   #255
TA_C10
TA_C10's Avatar
Re: 1972 SWB Build
Positive: 2SD60XA
Negative: 2SD45X
Hope this helps.
Thanks for the info. Interesting I just got my american autowire kit from brotherstrucks today and it has that alternator kit inside of it. I bought their deluxe 20. I am relocating my battery under the frame though so I need to find cables. I heard welding wire is really good stuff so I may go see what airgas may have after work tomorrow.
Keep up the good work sir.
"It's only money".
Old 07-17-2019, 10:32 AM   #256
beaterku
beaterku's Avatar
Re: 1972 SWB Build
No problem at all
Old 07-19-2019, 12:21 PM   #257
beaterku
beaterku's Avatar
Re: 1972 SWB Build
A little update on my brakes. I swapped the booster for another tuff-stuff unit and low and behold, the brakes are working much better. It's hotter than hades here, so I have only tested a little. I need to re-bleed the brakes. When I slam on the brakes, the front left and rear right lock up (shortest lines on the front and rear systems). So that is promising.
Also picked up a set of TR5's to swap out these AC Delco plugs.
Just waiting for it to cool down. We are in our typical inferno season of 95+ 70%+ humidity.
Old 07-19-2019, 12:42 PM   #258
MDPotter
MDPotter's Avatar
Re: 1972 SWB Build
We need more engine videos! I loved hearing your dyno pulls. It's motivation to keep me going so I can hear mine some day.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 07-20-2019, 09:26 AM   #259
beaterku
beaterku's Avatar
Re: 1972 SWB Build
It’s been so dang hot out. I definitely need AC. As soon as it cools down I’ll get some video!
Old 09-09-2019, 03:45 PM   #260
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Sorry, I've been slacking on my build thread. Here are some videos I put together about the build. I've been trying to drive it as much as possible. Went to my hometown car show this past weekend. Didn't win anything, but had a steady stream of people wanting to talk about the truck and the swap. It was wild.
Old 09-09-2019, 04:25 PM   #261
MDPotter
MDPotter's Avatar
Re: 1972 SWB Build
I was just watching your videos yesterday. What happened when you were doing the burnout and then the eagle call comes in? Choice words?
I'm hoping your randomizer picks me for the injectors giveaway.
Old 09-09-2019, 04:26 PM   #262
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Haha, I was checking my britches. It shifted to third and started going towards the ditch. I puckered a little.
Old 09-09-2019, 05:02 PM   #263
TA_C10
TA_C10's Avatar
Re: 1972 SWB Build
I've been following along with your videos man. Keep it up. I'm ready to be puckering myself.
"It's only money".
Old 09-09-2019, 10:40 PM   #264
TA_C10
TA_C10's Avatar
Re: 1972 SWB Build
Crazy. I just saw your blue gift to UBT on YouTube. Nice. You selling those shirts?
"It's only money".
Old 09-10-2019, 03:50 PM   #265
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Not yet. I did a run of 20 last fall and gave them away to friends and family. I am planning on making another run soon. I'll keep you updated.
Old 09-11-2019, 10:05 AM   #266
cornerstone
cornerstone's Avatar
Re: 1972 SWB Build
Just subbed to you channel, really enjoyed it all. Keep it up! I too am thoroughly ready for some serious puckerage.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 09-11-2019, 10:24 AM   #267
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Thank you for your support! Your build looks like its going to be great. 4:11 with a 6180 is going to be a burnout machine and a highway cruiser!
Old 09-12-2019, 10:44 PM   #268
cornerstone
Re: 1972 SWB Build
Thanks for that! I have to admit, I have second guessed my 4:11 choice a bunch. I ran the numbers and in 6th gear with my tire height it will be spinning a tad over 2200rpm at 70 MPH. It's not as low as I'd like to cruise at, mainly for the extra noise it will produce. Call me juvenile, but I hope to do my share of stomping anyone with a giant useless wing bolted on the back of their 4 door import. Plus, as my daily driver I usually just stay within a 50 mile radius, so not too many long drives.
Brian
Old 09-13-2019, 02:15 PM   #269
beaterku
beaterku's Avatar
Re: 1972 SWB Build
I have a 3:73 in mine with a 4L80e and I am running around 2200 at 70.
Old 11-05-2019, 12:52 PM   #270
67C10GS
67C10GS's Avatar
Re: 1972 SWB Build
subbd for future refrence
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10”
67C10GS is offline   Reply With Quote
Old 11-14-2019, 01:43 PM   #271
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Thanks. I hope it can help you out.
Old 12-07-2019, 02:54 AM   #272
mdelosrey
Re: 1972 SWB Build
Nice build. Enjoying the videos you put up. Sorry if I missed it but what are the wheel/tire specs?
mdelosrey is offline   Reply With Quote
Old 12-07-2019, 09:11 AM   #273
WIDESIDE72
WIDESIDE72's Avatar
Re: 1972 SWB Build
Originally Posted by Jason7121 View Post
Nice work so far. You cant go wrong with red and white with a 6.0 swap.
Do you mind if I ask what air intake kit you used? I am swapping an f body LS1 into my 70 c10 swb.
WIDESIDE72 is offline   Reply With Quote
Old 12-07-2019, 11:27 AM   #274
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Thanks for watching. The wheels are 18x9 0 offset all around with 265/50/18 tires.
I actually fabbed it up myself. I bought a 4” 180deg bend from summit and used some silicone couplers to make it all work. I did weld on a little support tab. I think a page back in this thread there are some pictures of it.
Old 03-22-2020, 12:47 PM   #275
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Afternoon all, just uploading some pictures of how I ran my starting wiring with the Speed Engineering shorty headers. I've had some questions about routing, so I thought I would add some photos.
